26th January 2017, 10:13 | #1061 | Link |
I'm Siri
the latest OpenCL driver should be shipped with the latest video card driver, download the latest video card driver and reinstall it.
and also the Intel OpenCL package for CPUs, https://software.intel.com/en-us/art...opencl-drivers, no x86 version since that crap is obsolete and we're all on x64 now after the driver reinstallation, copy Program Files\NVIDIA Corporation\OpenCL\OpenCL.dll to SysWOW64 folder and rename Program Files\NVIDIA Corporation\OpenCL\OpenCL64.dll to OpenCL.dll and copy it to System32 |
26th January 2017, 11:15 | #1062 | Link |
Maybe your graphics card is not supported. What card do you have?
Groucho's Avisynth Stuff |
26th January 2017, 16:31 | #1063 | Link | |
If you're still tring with 32bit avisynth and 32bit knlmeanscl, did you copy the 32bit opencl.dll to the right folder? (or at least first tried with the version already on your system, the supplied .dll file is only for troubleshooting). |
26th January 2017, 17:40 | #1064 | Link |
My graphic card is the Nvidia GeForce 9800GTX 512M PCIe2.0 16x.
My computer is dual boot, with WinXP Pro 32-bit on one drive and Win7 64-bit on a second drive. I have tried both installations, and they both behave the same. The XP installation has the OpenCL.DLL in the c:\windows\system32 folder. It is dated 7/9/2010. The Win7 installation has OpenCL.DLL in the c:\windows\SysWOW64 folder. It is dated 2/25/2013. There is also an nvopencl.dll in that folder as well as a IntelOpenCL32.DLL. The first two also appear in the c:\windows\system32 folder along with IntelOpenCL64.DLL. The OpenCL.DLL in my XP installation is version 1.0.0 and is signed by the Khronos Group. We are all focusing on this as the problem, and perhaps it is, but the fact that it exists and is in the correct folder makes me think I'd get a different error message than the one which says the KNLMeansCL.DLL won't load. BTW, my NVidia drivers are not the latest for my older card because the newer drivers don't work with Sony Vegas, the NLE I use every day. |
26th January 2017, 17:52 | #1065 | Link | |
I'm not sure about the minimum required driver version but I think it has to be at least something like 3xx.xx. Edit: Just googled - it should be at least 258.19 for OpenCL 1.1. Edit2: As for the correct OpenCL.dll - There should be one in "Program Files\NVIDIA Corporation\OpenCL". This is in most cases the right one to use. If you have an older version in your system32 directory, make a backup of it and then overwrite it with the one from the NVIDIA directory.
Groucho's Avisynth Stuff Last edited by Groucho2004; 26th January 2017 at 18:10. Reason: typo |
27th January 2017, 00:29 | #1066 | Link | |
The older version, coupled with the older redistributable works. Many thanks. |
27th January 2017, 10:11 | #1067 | Link | |
For example mixing old and new, 2.5 and 2.6 versions of plugins is not recommended: Code:
[CPP 2.5 / 32 Bit plugins] C:\Program Files\AviSynth 2.5\plugins\mt_masktools-25.dll [2.0.48.0] C:\Program Files\AviSynth 2.5\plugins\mt_masktools-26.dll [2.0.48.0] C:\Program Files\AviSynth 2.5\plugins\RoboCrop.dll C:\Program Files\AviSynth 2.5\plugins\RT_Stats.dll [CPP 2.6 / 32 Bit plugins] C:\Program Files\AviSynth 2.5\plugins\masktools2.dll [2.1.0.0] C:\Program Files\AviSynth 2.5\plugins\RoboCrop26.dll C:\Program Files\AviSynth 2.5\plugins\RT_Stats26.dll
28th January 2017, 15:01 | #1069 | Link |
Also these are conflicting, pick only one (SSE2).
C:\Program Files\AviSynth 2.5\plugins\RemoveDirt.dll C:\Program Files\AviSynth 2.5\plugins\RemoveDirtSSE2.dll
28th January 2017, 15:49 | #1070 | Link |
Uhm, I don't know if it was already covered, but I'm getting the following problem:
OpenCL Platform ------------------------------------------------------------ CL_PLATFORM_VENDOR: Advanced Micro Devices, Inc. CL_PLATFORM_NAME: AMD Accelerated Parallel Processing CL_PLATFORM_VERSION: OpenCL 2.0 AMD-APP (2236.10) CL_PLATFORM_PROFILE: FULL_PROFILE OpenCL Device ------------------------------------------------------------ CL_DEVICE_VENDOR: GenuineIntel CL_DEVICE_NAME: Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz CL_DRIVER_VERSION: 2236.10 (sse2) CL_DEVICE_VERSION: OpenCL 1.2 AMD-APP (2236.10) CL_DEVICE_PROFILE: FULL_PROFILE CL_DEVICE_IMAGE_SUPPORT: 1 CL_DEVICE_IMAGE2D_MAX_WIDTH: 8192 CL_DEVICE_IMAGE2D_MAX_HEIGHT: 8192 CL_DEVICE_IMAGE_MAX_ARRAY_SIZE: 2048 Program Build ------------------------------------------------------------ CL_PROGRAM_BUILD_OPTIONS: -cl-single-precision-constant -cl-denorms-are-zero -cl-fast-relaxed-math -Werror -D NLM_CLIP_TYPE_STACKED -D NLM_CLIP_REF_LUMA -D NLM_WMODE_WELSCH -D VI_DIM_X=1440 -D VI_DIM_Y=1080 -D HRZ_RESULT=3 -D VRT_RESULT=3 -D HRZ_BLOCK_X=16 -D HRZ_BLOCK_Y=8 -D VRT_BLOCK_X=16 -D VRT_BLOCK_Y=8 -D NLM_D=1 -D NLM_S=4 -D NLM_H=1.200000 -D NLM_WREF=1.000000 Warnings being treated as errors "C:\Users\usr\AppData\Local\Temp\OCL123264T1.cl", line 19: error: global variable declaration is corrected by the compiler to have addrSpace constant const sampler_t nne = CLK_NORMALIZED_COORDS_FALSE | CLK_ADDRESS_NONE | CLK_FILTER_NEAREST; ^ "C:\Users\usr\AppData\Local\Temp\OCL123264T1.cl", line 20: error: global variable declaration is corrected by the compiler to have addrSpace constant const sampler_t clm = CLK_NORMALIZED_COORDS_FALSE | CLK_ADDRESS_CLAMP | CLK_FILTER_NEAREST; Is the card not supported? Thanks. |
28th January 2017, 16:59 | #1071 | Link | |
The final version will work normally.
github.com |
28th January 2017, 17:06 | #1072 | Link |
When the API has bugs: https://www.khronos.org/bugzilla/show_bug.cgi?id=397
github.com |
31st January 2017, 16:39 | #1076 | Link |
I'm thinking about what formats to support, probably the same as VapourSynth.
Greyscale: 8-bit, 16-bit, 32-bit YUV: 8-bit, 10-bit, 16-bit, 32-bit Packed RGB: 8-bit, 16-bit, 32-bit All other formats are useless.
github.com Last edited by Khanattila; 31st January 2017 at 16:42. |
31st January 2017, 17:00 | #1077 | Link |
Soul Architect
I was also considering the exact same question for AviSynthShader. Since the GPU processing is done with UINT16 and half-float data, converting to-from 10, 12 or 14 bits is useless. If the user wants 10-bit output, he'll get a 16-bit output from the GPU, then he can ditter it down to 10-bit.
31st January 2017, 17:38 | #1080 | Link |
I'm Siri
bullshit, GPU works with different sizes of floats, half is a very low precision one and should not be used for processing, it was designed to reduce the bandwidth of data transferring (storing, not processing, half precision arithmetics are not any faster than single precision arithmetics)
