15th December 2019, 23:31 | #441 | Link |
That option would be rather rarely useful as you need to convince your TV thats its receiving YCbCr when everything is telling it that its receiving RGB (which very few display can even do), plus it screws up anything but madVR output, ie. Windows and player UI to boot.
16th December 2019, 00:11 | #442 | Link |
I'm confused with what you're saying. Are you saying using the ycbcr option in madvr and setting the GPU to RGB (why would anyone do that?) would cause that? Or are you saying just sending YCbCr from the GPU causes it? From what I can see, the GPU is sending YCbCr and the TV is accepting that. I think iSeries was proposing that instead of madvr outputting RGB and having the GPU convert it before sending it to the TV, that we'd have madvr output YCbCr instead. Would that not work? Is that what you're saying?
16th December 2019, 05:58 | #443 | Link |
He's talking about this here:
Hidden Options An empty folder or file in the madVR program directory with a specific name will trigger a hidden option, these are options you probably do not want to use. YCbCr: Outputs YCbCr data instead of RGB, as if it was RGB. I have not messed with that, so I can't say if it's beneficial.
16th December 2019, 09:11 | #444 | Link | |
Hence, everything thinks its handling RGB, the GPU and the screen, so you have to convince one of them that its not RGB, and thats not easily possible. Basically, a PC is not designed for a direct YCbCr path.
16th December 2019, 11:40 | #446 | Link | ||
The video processing path will be different for different bit depths so various displays will handle 10 bit better or worse but the total dynamic range should never change.
madVR options explained |
16th December 2019, 12:57 | #447 | Link | |
Sent from my SM-G975U using Tapatalk
16th December 2019, 17:25 | #448 | Link | ||
I'm like Asmodian (probably worse, with HDR), I won't abandon PC mode (We are busy with playing calibration, really frustrating )
16th December 2019, 17:56 | #449 | Link |
PC mode is a mess. I wanted very badly to get it to work but it's not usable imo. If you can live with the issues that's awesome. For me even with my ub820 it's a mess.
16th December 2019, 20:02 | #450 | Link | |
I used to spend days with the meter in front of my screens, but with the C7 I've only done it a couple of times. My SDR LUT is still good, although it might be time to redo it. As far as HDR is concerned, I tried when my set was new, but I realized quickly that a LUT via DisplayCAL just wasn't possible due to the instability of the display. So I dialed in the white point and called it a day I'll start playing with calibration again once I get a better meter and the C10 next year.
17th December 2019, 02:54 | #451 | Link | |
Other pixel artifacts do not mean it is not "proper 4:4:4" it just means it has other pixel artifacts. It is possible on the C9 but only in SDR. The behavior is different compared to my C7, and I think the C8 is like the C7.
17th December 2019, 03:27 | #452 | Link |
That's at least some progress. Let's see how the C10 turns out. Too bad we don't have any Sony owners here. I'd like to know firsthand how those behave (the panels, not the owners)
17th December 2019, 04:15 | #453 | Link |
Just noticed that myself. Is this another Nvidia bug, or intentional? Visually, there is no difference, which makes sense now.
17th December 2019, 05:03 | #454 | Link |
Kid for Today
Hey guys, about to finally jump on the OLED bandwagon and here chros claims that even latest Pana's can't do proper 24p, I also read Asmodian here in this thread saying that only C9 can do 444 24p, so if I get a 8 series I'd have to go 422 huh?
Samsung TV's 444 is not manageable because it disables BFI and most post-processing, no such thing on LG OLED? |
17th December 2019, 05:18 | #455 | Link | |
17th December 2019, 05:45 | #456 | Link | |
QB the Slayer
Also, you don't want BFI (Motion Pro) on the OLED, it's terrible. I suggest going to RTings and looking up the TV you want, it has very detailed breakdowns on just about every facet of the TV QB
17th December 2019, 08:27 | #457 | Link | |
It also depends on what bit rate madVR is set to. That's what makes testing this tedious. There seems to be a bug in madVR still, where sometimes, when set to 10-bit, it switches to 8-bit, and once it does that you have to reboot Windows in order to get it back into 10-bit mode. Had me question my sanity until I realized what was going on, because only when in 10-bit does 4:2:2 look the absolute smoothest out of all combos. Went through PC mode as well again tonight. I gotta say that YCbCr 4:4:4 8-bit throughout the chain actually looks fairly decent in HDR, and pretty smooth in SDR. Add dithering back in, and perhaps a bit of "reduce banding artifacts", and it's the best choice if you can't live without PC mode. As Asmodian pointed out earlier, things might be (slightly) different with the newer LGs, so it's always best to do your own testing.
17th December 2019, 10:00 | #458 | Link | |
these panel run at 100 or 120 hz adn you can't BFI using a backlight because there is no backlight so you have to send real black frames. i don't have to say more. even if you get 4:4:4 working is far from optimal thanks to the WRGB used in these screen which can create interesting patterns... that seems to be a bigger issue on the sony(defeat able) which supposed to have a relative good BFI and as always 4:4:4 for everything. |
17th December 2019, 10:14 | #459 | Link | ||
I have no idea how my TV looks without dithering, but if madVR dithering to 8 bit has less banding than sending the TV dithered 10 bit isn't that the better mode regardless of what it looks like with dithering disabled? The results without dithering are very interesting when trying to understand the TV's video processing but what is important for watching is the results with dithering enabled.
17th December 2019, 11:19 | #460 | Link |
Kid for Today
Figures, so what does it matter whether 24p isn't smooth? If anything, it prolly is because all post-processing is disabled duh.
444 is not manageable on TV's IME due to this constraint, I'll trade full chroma for post-processing anytime. Last edited by leeperry; 17th December 2019 at 13:57. |
