10th November 2010, 02:17 | #962 | Link |
*nix
v2.13 unable to load some m2v files
Hi, I am having a problem loading some m2v files using v2.13 and v2.14. v2.12 is ok. Thought I would post here to mention I've logged details and provided a sample here:
http://code.google.com/p/ffmpegsourc...s/detail?id=32 |
10th November 2010, 06:48 | #963 | Link | |
13th November 2010, 17:42 | #965 | Link |
Hello. I have a problem, maybe somebody could help me out. Ffmpegsource2 2.14mt and non mt version are giving me kind of "deadlocks", it stops responding in VirtualDub when seeking. I have put the ffms2.dll in system32 folder. Source is a Bluray which was remuxed into mkv with gsdmux from haali media splitter instalation package.
FFVideoSource("D:\Encoding\00000.track_4113.mkv", cache=true, cachefile="D:\system\00000.track_4113.mkv.ffindex") It opens fine but when seeking and encoding it will just stop responding. Thanks Last edited by SilaSurfer; 13th November 2010 at 17:54. |
13th November 2010, 20:58 | #966 | Link | |
Excessively jovial fellow
Also, provide a sample file. |
14th November 2010, 05:55 | #967 | Link |
hey im using FFMS2 for the first time and im having some difficulties...
im trying to load an avi with this FFVideoSource("video.avi", int threads=2, int width=640, int height=272, string resizer="SPLINE", string colorspace="YV12") and as a result i am getting http://i52.tinypic.com/116j0ch.jpg any ideas what im doing wrong? im sure its something simple...thanks! |
14th November 2010, 07:02 | #968 | Link |
Use
FFVideoSource("video.avi", threads=2, width=640, height=272, resizer="SPLINE", colorspace="YV12") In case you don't know: most of these parameters are optional, so if you don't want to do any resizing you can also simply use: FFVideoSource("video.avi") |
14th November 2010, 18:10 | #969 | Link |
Hey Thanks guys for your response. Last night Windows crashed on me, so I spend the whole day doing a fresh install. I tried it again and now it works. I don't know what was the reason for the issue, maybe the old windows installation. Thanks
16th November 2010, 08:17 | #970 | Link |
Hi all!
please advice how i can use mt version FFMpegSource Code:
A = FFAudioSource(X) V = FFVideoSource(X) AudioDub(V, A) SetMTMode(2,4) filter() Code:
SetMTMode(5,4) A = FFAudioSource(X) V = FFVideoSource(X) AudioDub(V, A) SetMTMode(2,4) filter() |
17th November 2010, 12:36 | #971 | Link |
Avisynth language lover
Framerate for FLV files in FFVideoSource
As I understand it, FFVideoSource sets the framerate to a value calculated from the duration of the first frame (except for MKV files, where it uses the average frame duration).
In principle, this should give the correct rate for CFR sources. However, in the case of FLV files, where timestamps have only millisecond accuracy, the calculated framerate can be out by enough to cause audio sync problems. For example, if the correct rate is 30fps, the first frame will appear to be 33ms long (instead of 33.333...), giving a frame rate of 30.303fps, an error of ~1%. Similar problems arise with 29.97, 24 and 23.976fps sources (there is no problem with 25fps, since frame duration is exactly 40ms). Sure, you can manually add AssumeFPS() to your script, but you have to discover the correct framerate yourself by other means. Would it not be possible for FFVideoSource to use the average frame duration for these sources too? In the meantime, I have devised a workaround you can use in your script: Code:
# Set frame rate from average frame duration, assuming CFR - use after FFVideoSource() # Useful for sources such as FLV which have only millisecond accuracy on timestamps function FFAssumeCFR(clip c) { cc = c.Crop(0, 0, 16, 2) # use small clip for efficiency # get timestamps of first and last frames - use runtime function to force frame access current_frame = 0 dummy = c.IsYUV() ? cc.AverageLuma() : cc.RGBDifference(BlankClip(cc)) ts1 = FFVFR_TIME current_frame = c.frameCount-1 dummy = c.IsYUV() ? cc.AverageLuma() : cc.RGBDifference(BlankClip(cc)) ts2 = FFVFR_TIME ts2 == ts1 ? c : c.AssumeFPS(current_frame*1000.0/(ts2-ts1)) } |
17th November 2010, 12:44 | #972 | Link |
Professional Code Monkey
Sounds reasonable, I guess. Let's see what TheFluff can come up with...
19th November 2010, 00:07 | #974 | Link |
The binaries at http://code.google.com/p/ffmpegsource/downloads/list aren't compiled with postprocessing support. Is there a PP-enabled version somewhere?
20th November 2010, 02:10 | #976 | Link |
http://mod16.org/ffms2/ffms2-r362.7z
Built with 100% more libpostproc. Note that the syntax for enabling UTF8 support in the Avisynth plugin has changed to a more boring and mundane utf8=true. Changelog since 2.14:
21st November 2010, 01:16 | #978 | Link |
That's what I get for copypasting code without looking at it and posting releases without testing them. http://mod16.org/ffms2/ffms2-r363.7z should fix the problem.
6th December 2010, 20:25 | #979 | Link |
User of free A/V tools
Lossless UtVideo Codec support
Dear developers, is there any chance you could add Ut Video Codec 8.5.0 source decoder support into FFMS? That way x264 would benefit from ability to directly import lossless AVI files encoded with UtVideo. Otherwise I suppose the only way to import such files is to use DirectShowSource() via Avisynth
Thanks for any reply, even the rejective one, much appreciated! |
6th December 2010, 21:08 | #980 | Link | |
That said there's a VfW codec for UTVideo so it should work just fine with avisource(). |
