Old 26th October 2016, 12:51   #841  |  Link
robl45
well I just did a hardware encode and it appears to be good. I uninstalled the graphics drivers this morning and reinstalled although I'm not really sure what made the difference. last night even the software encode of star trek was giving me all sorts of frame delays and pixelation throughout. Now scanning the created iso it all appears to be good and makemkv ripped it without any frame delay errors. Will try another tonight, hopefully problem solved.
robl45 is offline   Reply With Quote
Old 26th October 2016, 20:43   #842  |  Link
pistacho
Version 2.6.4 (10/26/2016)
  • Updated: Mkvmerge to version 9.5.0 and also included 64-bit version in installer.
  • New: on 64-bit systems, 64-bit version of Mkvmerge is used. This reduces to half or less the time needed for MKV muxing operations.
  • Updated: MVCenc and MVCdec versions and also included native 64-bit versions of two tools.
  • New: on 64-bit systems, 64-bit versions of MVCenc and MVCdec are used.
  • Improved: performance of 3D MVC encodes incremented by 40% on both 64-bit and 32-bit systems using HW mode.
  • Improved: workaround to avoid memory leak on 3D MVC transcoding present on Skylake systems using Intel Graphics Drivers 4501, 4530 and 4539 (due Intel's bug).
  • New: in MKV conversions "core" part of TrueHD audio (AC3 embedded track) can be extracted without re-coding (this was already possible for AVCHD conversions).
DOWNLOAD => BDtoAVCHD_v2.6.4.msi
pistacho is offline   Reply With Quote
Old 30th October 2016, 14:15   #843  |  Link
robl45
So I watched one of the movies I encoded with this with hardware last night. Finding Dory. I noticed I would get a quick white horizontal line every once in a while during the film. My kids didn't notice it, but I did. I also noticed this when watching HOU films that I downloaded but not when watching a straight rip of the bluray. I use DLP glasses and I'm guessing its just something inherent to the encoding process?
As for 2.6.3 and 2.6.4, is there any major difference that I really need to upgrade as 2.6.3 is working fine now and I'm afraid to create unnecessary problems again.
Old 31st October 2016, 16:53   #844  |  Link
cypher007
Originally Posted by robl45 View Post
subtitles field and click the one you want.
figured the bug out now.
I was scanning bitrates when clicking add to queue. this then changed the sub from 4608 to 4618.
if I scan bitrates using the can bitrates button it changes the selected sub from 4608 to 4618 in the sub field. so I can get round this by scanning using the button then changing the subs back to the correct one.
cypher007 is offline   Reply With Quote
Old 1st November 2016, 11:08   #845  |  Link
cypher007
quick question which will produce a better quality rip bdtoavchd set to avcdh 7.93gb dts core and very slow or ripbot set to mkv 7.93gb dts core and 2 pass?
at the moment it seems bdtoavchd produces the same overall file size but uses less bit rate for the video, even though the audio is the same size in both files, why? wheres the extra space gone?
so I'm wondering what will produce a better rip? slightly less bit rate but very slow setting or more bit rate and 2 passes?
Old 2nd November 2016, 11:17   #846  |  Link
robl45
Yes, scan bitrates, then make sure everything is the way you want it before you add job to queue.
Old 2nd November 2016, 11:20   #847  |  Link
robl45
I only use this for 3D, for 2D I use StaxGui as it does nvidia hardware encoding and can burn in hardcoded subs.
Old 4th November 2016, 01:37   #848  |  Link
robl45
I just had an issue where the system kept dying when going to mvc encode. I checked the media sdk analyser and it was showing software only, no hardware. I hadn't changed anything, but I tried reinstalling the driver and now it shows hardware enabled again. Windows 10 update maybe?
Old 14th November 2016, 12:17   #849  |  Link
robl45
There is a new driver available for HD530. Is it safe to use? came out 11/9.
Old 15th November 2016, 12:26   #850  |  Link
robl45
Second time this has happened. Anyone else have this issue?
and again I just had to reinstall the driver again as it said I wasn't enabled for hardware mode. Am I the only one with this issue?
Old 21st November 2016, 19:55   #851  |  Link
sergio2
Notebook under Windows 10
Processor i7 6700HQ with Intel HD 530 : driver 20.19.15.4444 from 22/04/2016.
3D MVC encoding works well except when 3D Blu-Ray unprotected .iso file is mounted from an external disk : in this latter case, BDToAVCH crashes at the beginning of step 2, just before 3D MVC encoding.
sergio2 is offline   Reply With Quote
Old 6th December 2016, 10:36   #852  |  Link
pistacho
Version 2.6.5 (12/06/2016)
  • Updated: Mkvmerge to version 9.6.0.
  • Updated: x264 encoder to version 148.2744.
  • Updated: x265 encoder to version 2.1.64.
DOWNLOAD => BDtoAVCHD_v2.6.5.msi
Old 12th December 2016, 04:51   #853  |  Link
robl45
2nd or 3rd time now I've had to uninstall and reinstall the graphics driver to get 3d to encode without frame sync errors. I had a movie that I encoded months ago with the program give continuous frame errors until tonight when it finally encoded correctly again using the same source from months ago. I find it hard to believe no one else has had this issue?
Old 5th January 2017, 12:03   #854  |  Link
pistacho
Version 2.6.6 (01/05/2017)
  • Updated: Mkvmerge to version 9.7.1.
  • Updated: x265 encoder to version 2.2.1.
DOWNLOAD => BDtoAVCHD_v2.6.6.msi
Old 3rd February 2017, 11:34   #855  |  Link
pistacho
Version 2.6.7 (02/03/2017)
  • Updated: x264 encoder to version 148.2762.
  • Updated: x265 encoder to version 2.2.30.
  • Updated: Mkvmerge to version 9.8.0.
DOWNLOAD => BDtoAVCHD_v2.6.7.msi
Old 17th February 2017, 01:48   #856  |  Link
robl45
Has anyone been able to 3d encode Transformers Age of Extinction or Captain America Civil War? I've tried for 2 weeks now and no matter what the encodes have errors. I've verified the original full disc copy doesn't have errors. Captain america civil war I got to encode without errors on Software encode but when watching it with my son, it didn't seem quite right. Was kind of giving me a headache. Transformers age of extinction I cannot get to encode no matter what I do without severe frame deformities around 1: 34 minutes or so. I know its not an issue with my system as between this time I've encoded 2 other 3d movies in hardware without issue.
Old 21st February 2017, 19:14   #857  |  Link
pistacho
Version 2.6.8 (02/21/2017)
  • Improved: GUI scaling on high DPI displays (prevents program window too small).
  • Updated: x265 encoder to version 2.3.1.
  • Updated: Mkvmerge to version 9.9.0.
DOWNLOAD => BDtoAVCHD_v2.6.8.msi
Old 5th April 2017, 09:53   #858  |  Link
pistacho
Version 2.6.9 (04/05/2017)
  • Updated: x265 encoder to version 2.3.28.
  • Updated: Mkvmerge to version 10.0.0.
DOWNLOAD => BDtoAVCHD_v2.6.9.msi
Old 27th April 2017, 10:44   #859  |  Link
pistacho
Version 2.7.0 (04/27/2017)
  • Improved: IMDb movie titles search more accurate and now is displayed a list of results when there are multiple possible matches.
  • Updated: x265 encoder to version 2.4.1.
DOWNLOAD => BDtoAVCHD_v2.7.0.msi
Old 21st May 2017, 13:21   #860  |  Link
iSeries
Hi Pistacho, could AC3 2.0 options be added for video remuxing?
avchd, bdtoavchd, blu-ray ripper, m2ts, ps3
