Old 7th April 2019, 14:54   #6141  |  Link
Klaus1189
Which latest versions? Latest stable or latest nightlies?
Old 7th April 2019, 21:21   #6142  |  Link
Originally Posted by tormento View Post
Is it only me or the latest versions get lot of time when launching?
I don't get why you just didn't download the stable 1.5.3 release and just test for yourself. Nobody has mentioned anything and most of us use SSDs so many apps are basically instant.
Old 8th April 2019, 09:37   #6143  |  Link
tormento
Acid fr0g
tormento's Avatar
Downloaded both stable and nightly. Same effect. Tried to delete every .ini and other setting and at first launch it's almost instant, from the second, when settings are saved, get slower. I have 2 Samsung 850 Pro here, so storage is not the bottleneck.
@turment on Telegram
Old 8th April 2019, 10:14   #6144  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Only for you.
I7 2600K@4.2 /Asrock P67 Extreme4 Gen 3 /Kingston HyperX 8Gb 1866 (4x2) Kit /OCZ Vertex 3 256Gb /Gigabyte GTX 960 /BenQ EW2430 /LG 47LM620T /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Old 8th April 2019, 12:27   #6145  |  Link
Qotscha
Same thing for me too. Tested nightlies (x64) and 1.5.3.4373 seems to be the last build launching practically instantly. Builds starting from 1.5.3.4378 take several seconds.
Qotscha is offline   Reply With Quote
Old 8th April 2019, 12:32   #6146  |  Link
tormento
Acid fr0g
tormento's Avatar
Thanks for the working version hint.
I confirm it is opening instantly for me too (x64 version).
Old 8th April 2019, 16:58   #6147  |  Link
lvqcl
1.5.4.4508: startup time < 1 second.
Old 8th April 2019, 22:43   #6148  |  Link
BetA13
cosmic entity
BetA13's Avatar
hy all,
i have a little problem with Subtitles in h265 Files..
they allways display in White and default size, if try to change anything in the Standart style, lets say color to red, it doesnt change it, same with the Size.
Using the standart internal subtitle renderer in MPC BE..
With h264 Files it does work like it should..
is there a reason for that? maybe a limitation of some sort?
Use Standart style is enabled..
or should i use a different subtitle renderer? If yes, wich would be recommend?
Thanks..
BetA13 is offline   Reply With Quote
Old 8th April 2019, 22:45   #6149  |  Link
But do you have the slow startup on the build stated (4378)?
Old 9th April 2019, 01:45   #6150  |  Link
Aleksoid1978
Originally Posted by BetA13 View Post
hy all,
Thanks..
Subtitles style work only for text's subs. As i see on screen - it's PGS or VOBSUB subtitle. Show MediaInfo for this file.
Old 9th April 2019, 02:06   #6151  |  Link
BetA13
cosmic entity
BetA13's Avatar
Media Info - Subtitles part:
Text
Format : PGS
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Duration : 3 min 37 s
Bit rate : 48.6 kb/s
Count of elements : 128
Stream size : 1.26 MiB (1%)
Title : Uncle.Buck.1989.x265
Language : English
Default : No
Forced : No
Looks like PGS..
So, with an seperate external subtitle this would work? like srt? etc...
And for vobsubs, would there be another way to modify the subs? as in using a different subtitle renderer?
sorry for the questions, but i never really used subtitles, wich i do now increasingly..
Thanks for the Help
Old 9th April 2019, 04:48   #6152  |  Link
Qotscha
Every build (or at least 1.5.3 stable, 1.5.4.4508, and a couple of others I tested) since 4378 seems to take significantly longer time to start compared to 4373 (~5 s vs ~0.5 s). So probably there is something in commits 4374 - 4378 which has an effect on startup times at least for me and tormento.
I looked at these commits and there seems to be quite a lot of code changes in 4374 "Change: Transfer code from branches / playlist to the main branch." (Google translation). The other commits include changes to PlaylistNameDlg.cpp/.h introduced in 4374.
Old 9th April 2019, 04:55   #6153  |  Link
Aleksoid1978
Qotscha
Try to reset settings.
Old 9th April 2019, 05:16   #6154  |  Link
Qotscha
Originally Posted by Aleksoid1978 View Post
Qotscha
Tried with 4378, 4488 (stable), and 4508, all x64. Still takes about 5 seconds (sometimes almost ten) to launch. 4373 starts instantly.
Old 9th April 2019, 07:13   #6155  |  Link
kissglay
kissglay's Avatar
When playing a dvd ISO, can't load external subtitle through menu item (grayed out) or CTRL + L, but can be done by drag & drop the subtitle.
BTW, I only tested with a DVD ISO without its own subtitles.
kissglay is offline   Reply With Quote
Old 9th April 2019, 07:49   #6156  |  Link
Aleksoid1978
Fantasy For me load <=1 sec.
P.S. Do you have CD/DVD/BD-Rom ??
Try this - start MPC-BE, show playlist and delete "Explorer".
Old 9th April 2019, 08:59   #6157  |  Link
Arm3nian
1 - reset settings.
2 - try without LAV and madVR.
The problem was with madVR, as no crashes with EVR. But it seems to have been fixed with the latest MPC-BE and LAV builds.
Arm3nian is offline   Reply With Quote
Old 9th April 2019, 09:26   #6158  |  Link
tormento
Acid fr0g
tormento's Avatar
Fantasy
We are at least two users who have this issue.
I use (and abuse) dozens of programs on Windows and MPCBE is the only one that gives me that delay.
I'd like to have some feedback from authors, not "funny" comments from users. If more info about OS, drivers, logs whatever is needed, I can provide.
Old 9th April 2019, 09:28   #6159  |  Link
Aleksoid1978
I write what need to do, about playlist.
Old 9th April 2019, 09:37   #6160  |  Link
tormento
Acid fr0g
tormento's Avatar
My playlist is empty.
