24th May 2010, 18:48 | #3201 | Link | |
Acid fr0g
Staxrip can't change the command line.
@turment on Telegram Last edited by tormento; 24th May 2010 at 19:12. |
24th May 2010, 19:43 | #3202 | Link | |
24th May 2010, 20:17 | #3203 | Link |
No...
x264 log explained || x264 deblocking how-to preset -> tune -> user set options -> fast first pass -> profile -> level Doom10 - Of course it's better, it's one more. |
25th May 2010, 06:49 | #3206 | Link |
http://www.7-zip.org/ |
25th May 2010, 07:22 | #3207 | Link | |
If there is a patch that changes an existing option, you can also change it. For example, if there were a new AQ patch that added AQ mode 3 for testing (and this has been done in the past)!, you can't change it via the standard gui options. What you do is leave/change AQ mode to 1 in the gui (typical default), in which case its not specific in the command line. You can then add --aq-mode 3 in the command line section and you will see it with all the options selected at the bottom of that tab. This has been a feature of Staxrip for a long while, but if you haven't got the very latest version, it would still be a good idea to update Of course, you can use later versions of any component Staxrip uses by replacing the ones that come with Staxrip. You can then accept the message saying its newer and it should be ok! (unless the updated version of the programme changes the required command line syntax or function). Last edited by burfadel; 25th May 2010 at 07:24. |
26th May 2010, 20:52 | #3209 | Link |
x264 0.96.1612M x64 & x86
gcc 4.5.1 20100523 prerelease ffmpeg svn 23327 swscale svn 31217 ffms2 svn 312 pthreads 2.9.0.0 static x264 0.96.1612M x86,x64,amdfam10,fprofiled patches used : 04_x264_thread_pool_v2.9.r1602.diff x264_demuxer_threads.diff x264_sws_typecast.diff x264_avi_output.v4.diff |
27th May 2010, 07:18 | #3211 | Link |
Strange Memory Leak bug?
from some time, i'm facing a strange problem. I'm not able to complete an encode whetever parameters i set, because of the error after some time (first pass) "ratecontrol _init: can't open stats file" After investigation, i found that pheraps there is a memory allocation problem. That is, actually i'm doing an encoding, first pass, and x264.exe has allocated already 1.575.233 bytes, and is slowly but constantly increasing. Now the memory user space on a 32bit system is 2GB, so i can assume that when the allocation reaches the 2GB, the encoder fails because _malloc can't allocate anymore. I could try with the /3G switch but i think it's not normal to allocate for an encoding such a huge amount of memory (and i suspect that even with the /3G the encoder would reach the limit). Any confirm on this from someone? Possible solution? I'm on Windows 2003 intel i7 6 cores. Thanks Last edited by 3ngel; 27th May 2010 at 07:20. |
27th May 2010, 07:45 | #3212 | Link | |
x264 developer
27th May 2010, 10:44 | #3213 | Link |
He's trying to get the filter patch working via staxrip. The change he needs is that the input resolution must be given with --input-res instead of just the argument after the input file name.
27th May 2010, 14:35 | #3218 | Link |
All raw input needs the resolution set. I had forgotten about the filename parsing though.
27th May 2010, 14:46 | #3219 | Link |
Toolchain:
x264 Builds:
Patches:
h.264, x264, x264 builds, x264 patches, x264 unofficial builds |
