Old 9th June 2010, 13:22   #581  |  Link
Tdr
Hi buzzqw,
excuse my english, not often used since scool
I use automen for quite a time, starting with 3.3. The produced files (mostly XVID with mp3) work well on my ELTA 8848. I also like the look of the new gui.
Is there any plan to install a function, for thew starting and ending point of the encoding in a file? I guess, mencoder offers this function? This is the only function, i am missing so far.
Thanks a lot and keep going on.
Tom
Tdr is offline   Reply With Quote
Old 9th June 2010, 14:58   #582  |  Link
buzzqw
HDConvertToX author
Hi Tdr
do you mean the EDL (edit decision list) ?
if so.. i can look at it
BHH
HDConvertToX: your tool for BD backup
MultiX264: The quick gui for x264
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
buzzqw is offline   Reply With Quote
Old 10th June 2010, 08:11   #583  |  Link
Tdr
Hi buzzqw,
thanks for the quick reply, I am speaking of this mencoder function:
-ss <time>
Seek to given time position. (Start encoding here)
EXAMPLE:
-ss 56
Seeks to 56 seconds.
-ss 01:10:00
Seeks to 1 hour 10 min.
-endpos <[[hh:]mm:]ss[.ms]|size[b|kb|mb]>
Stop encoding at the given time or byte position.
EXAMPLE:
-endpos 56
Encode only 56 seconds.
-endpos 01:10:00
Encode only 1 hour 10 minutes.
-endpos 100mb
Encode only 100 MBytes.
Can you make an special Tab?
I could open the file with MPUI, note the time I want to encode and put it in the fields in the Tab.
Tom
Old 10th June 2010, 08:13   #584  |  Link
buzzqw
HDConvertToX author
afaik SS option isn't well working on windows build of mencoder...
do you use sherpya build's or others build ?
BHH
Old 10th June 2010, 09:08   #585  |  Link
Tdr
Hi buzzqw,
I think its Sherpya, but I havent used this function by myself. I just was looking in the docs, if mencoder offers this function, because it would helpfull for me.
What is meant by "isn't well working on windows build of mencoder"?
I did - 5 Minutes ago - a test with an old GUI (Mencoder GUI by Milan Vondra), there You can edit the command line. It worked well.
Tom
Old 15th June 2010, 04:56   #586  |  Link
markanini
Could you add SPP, USPP and PP7 filters from mencoder/mplayer in your GUI, buzzqw?
markanini is offline   Reply With Quote
Old 15th June 2010, 18:35   #587  |  Link
Marshy
I cant get GUI to work with dvd or preview using Mencoder. Handbrake and other options preview, encode. Anyone else with this problem?
Also: There's a GUI bug with shutdown option. It does not work if you enable it.
Marshy is offline   Reply With Quote
Old 25th June 2010, 17:09   #588  |  Link
EnderEOC
I just tried this soft to convert a mkv i had trouble playing on my home cinema.
It worked fine !!!
Thank you so much for making it
There's some things i don't get though. When i open the mkv with media info, it says 23.810 fps for 23.09min. Since i needed to replace the subtitles, i extracted the stream, edited the sub then used mkvmerge.
I had to manually set the fps but when i put 23.810fps, it's out of sync. I have to select 24000/1001 for it to be perfect.
Then i need to use AutoMen to convert the audio from AAC to MP3 and it shows 23.976fps for the same duration. Weird....
I'll have to try see if it can convert VC-1 to AVC, if it does it'll be awesome
edit : It would be great if when you convert a video, the software could keep the font in attachment for the subtitles :/
I have to reuse mkvmerge after to attach the font file.
EnderEOC is offline   Reply With Quote
Old 4th July 2010, 11:59   #589  |  Link
Marshy
autocrop buggy!
The autocrop feature is not working correctly??? in the top and bottom parameters. With a 720:480 3:2 apect, cropping comes to using a 624x352 resolution:
left 0 top 62 bottom 56 right 0
Thing is using same resolution autocrop in Handbrake program, the crop of top and bottom comes out reverse with:
0, 56, 62, 0
I have reconfirmed this with some others using auto cropping. Automen gets confused using top and bottom numbers in some aspects! Is this feature buggy or does it just use a different math system to work out crop? Despite a few bugs, thankyou for great software.
Old 18th July 2010, 04:16   #590  |  Link
feeling_enhancer
feeling_enhancer's Avatar
No Audio
I tried converting an MKV file to AVI but after the conversion there was no Audio... Audio file was (A_AAC), -aid 0, -alang und. which i tried to convert to CBR.
I download the lastest Automen v6.1568.240
Please Help.
feeling_enhancer is offline   Reply With Quote
Old 18th July 2010, 11:52   #591  |  Link
feeling_enhancer
No Audio
I'm here to confirm that Automen V6 is having trouble converting Audio from MKV to AVI. I tried older Automen to convert the same file of MKV to AVI and result was good. But Automen V6 Cannot convert Audio of MKv to AVI.
Please fix this problem.
Old 27th July 2010, 07:18   #592  |  Link
buzzqw
HDConvertToX author
i need the mplayer.log in automen folder
launch automen, load your file.
next in automen folder you will see a mplayer.log (and automen.log)
Please Help.
please try download new beta package i have bundled latest mencoder
http://www.64k.it/andres/data/automen/AutoMen6_beta.rar
Is this tool supported anymore? Maybe guy who updates it is ill or busy with other projects.
it's supported. feel free to update to latest package
BHH
BHH
Old 28th July 2010, 20:32   #593  |  Link
Marshy
Thankyou
MPlayer SVN-r31743-4.2.5 (C) 2000-2010 MPlayer Team
158 audio & 346 video codecs
Playing D:\Horror.Films\Test.avi.
AVI file format detected.
ID_VIDEO_ID=0
[aviheader] Video stream found, -vid 0
ID_AUDIO_ID=1
[aviheader] Audio stream found, -aid 1
VIDEO: [XVID] 720x480 12bpp 30.000 fps 994.7 kbps (121.4 kbyte/s)
Clip info:
Software: Encoder 1.0pre8-3.4.2
ID_CLIP_INFO_NAME0=Software
ID_CLIP_INFO_VALUE0= Encoder 1.0pre8-3.4.2
ID_CLIP_INFO_N=1
ID_FILENAME=D:\Horror.Films\Test.avi
ID_DEMUXER=avi
ID_VIDEO_FORMAT=XVID
ID_VIDEO_BITRATE=994696
ID_VIDEO_WIDTH=720
ID_VIDEO_HEIGHT=480
ID_VIDEO_FPS=30.000
ID_VIDEO_ASPECT=1.7793
ID_START_TIME=0.00
ID_LENGTH=6256.60
ID_SEEKABLE=1
ID_CHAPTERS=0
Opening video filter: [cropdetect=24:2]
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
Selected video codec: [ffodivx] vfm: ffmpeg (FFmpeg MPEG-4)
ID_VIDEO_CODEC=ffodivx
Audio: no sound
Starting playback...
Movie-Aspect is 1.78:1 - prescaling to correct movie aspect.
VO: [null] 720x480 => 854x480 Planar YV12
The cropping data figures below YV12.. with this report were too big to put in post.
Last edited by Marshy; 29th July 2010 at 13:10. Reason: New build was tested: same crop problem
Old 28th July 2010, 21:09   #594  |  Link
buzzqw
HDConvertToX author
i need at least some line of crop.. just to understand the switch between crops value
BHH
Old 29th July 2010, 13:03   #595  |  Link
Marshy
[CROP] Crop area: X: 719..0 Y: 479..0 (-vf crop=-718:-478:720:480).
And so on as above many times..
[CROP] Crop area: X: 719..0 Y: 236..240 (-vf crop=-718:4:720:236).
[CROP] Crop area: X: 719..0 Y: 234..242 (-vf crop=-718:8:720:234).
[CROP] Crop area: X: 719..0 Y: 233..245 (-vf crop=-718:12:720:234).
[CROP] Crop area: X: 719..0 Y: 232..246 (-vf crop=-718:14:720:232).
[CROP] Crop area: X: 719..0 Y: 230..248 (-vf crop=-718:18:720:230).
[CROP] Crop area: X: 719..0 Y: 229..249 (-vf crop=-718:20:720:230).
[CROP] Crop area: X: 719..0 Y: 228..250 (-vf crop=-718:22:720:228).
[CROP] Crop area: X: 719..0 Y: 226..252 (-vf crop=-718:26:720:226).
[CROP] Crop area: X: 719..0 Y: 225..253 (-vf crop=-718:28:720:226).
[CROP] Crop area: X: 719..0 Y: 223..255 (-vf crop=-718:32:720:224).
[CROP] Crop area: X: 719..0 Y: 222..256 (-vf crop=-718:34:720:222).
[CROP] Crop area: X: 719..0 Y: 221..256 (-vf crop=-718:34:720:222).
[CROP] Crop area: X: 719..0 Y: 219..257 (-vf crop=-718:38:720:220).
[CROP] Crop area: X: 719..0 Y: 218..258 (-vf crop=-718:40:720:218).
[CROP] Crop area: X: 719..0 Y: 217..259 (-vf crop=-718:42:720:218).
[CROP] Crop area: X: 719..0 Y: 216..260 (-vf crop=-718:44:720:216).
[CROP] Crop area: X: 719..0 Y: 215..261 (-vf crop=-718:46:720:216).
[CROP] Crop area: X: 719..0 Y: 214..262 (-vf crop=-718:48:720:214).
[CROP] Crop area: X: 719..0 Y: 213..263 (-vf crop=-718:50:720:214).
[CROP] Crop area: X: 719..0 Y: 212..263 (-vf crop=-718:52:720:212).
[CROP] Crop area: X: 719..0 Y: 211..264 (-vf crop=-718:52:720:212).
[CROP] Crop area: X: 719..0 Y: 209..264 (-vf crop=-718:54:720:210).
[CROP] Crop area: X: 719..0 Y: 208..264 (-vf crop=-718:56:720:208).
[CROP] Crop area: X: 719..0 Y: 207..266 (-vf crop=-718:58:720:208).
[CROP] Crop area: X: 719..0 Y: 206..266 (-vf crop=-718:60:720:206).
[CROP] Crop area: X: 719..0 Y: 205..266 (-vf crop=-718:60:720:206).
[CROP] Crop area: X: 719..0 Y: 204..267 (-vf crop=-718:64:720:204).
[CROP] Crop area: X: 719..0 Y: 203..267 (-vf crop=-718:64:720:204).
[CROP] Crop area: X: 719..0 Y: 202..267 (-vf crop=-718:66:720:202).
[CROP] Crop area: X: 719..0 Y: 201..267 (-vf crop=-718:66:720:202).
[CROP] Crop area: X: 719..0 Y: 200..268 (-vf crop=-718:68:720:200).
[CROP] Crop area: X: 719..0 Y: 198..269 (-vf crop=-718:72:720:198).
[CROP] Crop area: X: 313..319 Y: 196..271 (-vf crop=6:76:314:196).
[CROP] Crop area: X: 280..391 Y: 193..272 (-vf crop=112:78:280:194).
[CROP] Crop area: X: 260..427 Y: 190..272 (-vf crop=168:82:260:190).
[CROP] Crop area: X: 135..427 Y: 187..273 (-vf crop=292:86:136:188).
[CROP] Crop area: X: 124..437 Y: 184..273 (-vf crop=314:90:124:184).
[CROP] Crop area: X: 115..437 Y: 181..273 (-vf crop=322:92:116:182).
[CROP] Crop area: X: 102..437 Y: 178..273 (-vf crop=336:96:102:178).
[CROP] Crop area: X: 100..437 Y: 176..273 (-vf crop=338:98:100:176).
[CROP] Crop area: X: 100..437 Y: 173..273 (-vf crop=338:100:100:174).
[CROP] Crop area: X: 99..437 Y: 169..273 (-vf crop=338:104:100:170).
[CROP] Crop area: X: 97..437 Y: 163..273 (-vf crop=340:110:98:164).
[CROP] Crop area: X: 97..468 Y: 159..273 (-vf crop=370:114:98:160).
[CROP] Crop area: X: 96..468 Y: 153..273 (-vf crop=372:120:96:154).
[CROP] Crop area: X: 94..468 Y: 148..273 (-vf crop=374:126:94:148).
[CROP] Crop area: X: 72..468 Y: 143..273 (-vf crop=396:130:72:144).
[CROP] Crop area: X: 68..468 Y: 137..273 (-vf crop=400:136:68:138).
[CROP] Crop area: X: 65..495 Y: 133..276 (-vf crop=430:142:66:134).
[CROP] Crop area: X: 65..717 Y: 128..284 (-vf crop=652:156:66:128).
[CROP] Crop area: X: 65..719 Y: 122..288 (-vf crop=654:166:66:122).
[CROP] Crop area: X: 65..719 Y: 112..288 (-vf crop=654:176:66:112).
[CROP] Crop area: X: 65..719 Y: 102..288 (-vf crop=654:186:66:102).
Old 29th July 2010, 13:05   #596  |  Link
Marshy
[CROP] Crop area: X: 65..719 Y: 90..288 (-vf crop=654:198:66:90).
[CROP] Crop area: X: 65..719 Y: 76..288 (-vf crop=654:212:66:76).
[CROP] Crop area: X: 65..719 Y: 64..288 (-vf crop=654:224:66:64).
[CROP] Crop area: X: 65..719 Y: 56..288 (-vf crop=654:232:66:56).
[CROP] Crop area: X: 64..719 Y: 56..311 (-vf crop=656:256:64:56).
[CROP] Crop area: X: 64..719 Y: 56..320 (-vf crop=656:264:64:56).
[CROP] Crop area: X: 62..719 Y: 56..320 (-vf crop=658:264:62:56).
[CROP] Crop area: X: 60..719 Y: 56..323 (-vf crop=660:268:60:56).
[CROP] Crop area: X: 58..719 Y: 56..333 (-vf crop=662:278:58:56).
[CROP] Crop area: X: 57..719 Y: 56..333 (-vf crop=662:278:58:56).
[CROP] Crop area: X: 56..719 Y: 56..355 (-vf crop=664:300:56:56).
[CROP] Crop area: X: 37..719 Y: 56..387 (-vf crop=682:332:38:56).
[CROP] Crop area: X: 35..719 Y: 56..410 (-vf crop=684:354:36:56).
[CROP] Crop area: X: 29..719 Y: 56..412 (-vf crop=690:356:30:56).
[CROP] Crop area: X: 20..719 Y: 56..412 (-vf crop=700:356:20:56).
[CROP] Crop area: X: 0..719 Y: 56..416 (-vf crop=720:360:0:56).
[CROP] Crop area: X: 0..719 Y: 56..417 (-vf crop=720:362:0:56).
[CROP] Crop area: X: 0..719 Y: 56..418 (-vf crop=720:362:0:56).
And so as above many times until:
Exiting... (End of file)
ID_EXIT=EOF
I've moved to new build and preview using Mencoder does not work with DVD too. Thankyou for your time and help.
Old 30th July 2010, 04:19   #597  |  Link
feeling_enhancer
Resize & Subtitle Problem
I've using Automen for more than a year and half but I find it difficult to resize according to my desire. Resize definitely needs to be fixed. I tried resizing an 720*304 file into 640*352but it wont happen, while other software like mediacoder, it can be done easily there.
Subtitle cant be selected from the Harddisk. Why ? Automen should have the ability to manually select the Subtitle file .SRT file from Harddisk and mux in the conversion. Mediacoder software has this facility.
Can you please fix it in Automen.
Old 30th July 2010, 07:17   #598  |  Link
buzzqw
HDConvertToX author
@Marshy
your crop values are "dancing"..
this could be due to very different black bars across video.
there isn't much mplayer could do. you can try using "Do autocrop" in that case many more frames are analyzed..
@feeling_enhancer
about resized: on video panel, change aspect ratio from 2.36 to 1.85
and support for external subtitle isn't planned early
EDIT: uploaded a new automen/full and beta exe
added sanity check for missing profile.txt
fixed preview of dvd source
fixed autocrop of dvd source
BHH
Old 30th July 2010, 17:31   #599  |  Link
Marshy
Preview works fine. Thankyou.
Old 31st July 2010, 20:15   #600  |  Link
tipsypenguin
Thanks. I just started using this. it's a great program.
tipsypenguin is offline   Reply With Quote
automen, ffmpeg, handbrake, mencoder, x264
