7th February 2014, 18:44 | #19141 | Link | |
[Edit] Have you tried the "ForceSEI" option instead? The original is H.264 encoded (not VC-1 or MPEG-2), right? Last edited by jdobbs; 7th February 2014 at 19:06. |
7th February 2014, 19:25 | #19142 | Link |
Yes, video is H.264. I don't know where ForceSEI option is? Is that in BD Rebuilder or tsMuxeR?
Do you mean "Always rebuild SEI and VUI data" in tsMuxer? If so, then yes I tried all settings and the only one that worked was "do not change SEI and VUI data". Last edited by Audiophile1178; 7th February 2014 at 19:32. |
7th February 2014, 20:13 | #19145 | Link | |
I'll see what I find from the clip. [Edit] I can confirm that the output of that clip is a mess... although I'm not sure why yet. I really can't do anything about TSMUXER, but I can certainly change the muxing parameters in BD-RB for intact sources. Last edited by jdobbs; 7th February 2014 at 20:42. |
7th February 2014, 20:47 | #19146 | Link | |
Test File (Created using v1.10.6): Plays fine BD Rebuilder Output (No encode): There's sound but no picture. Worse results than software players. BD Rebuilder Output (Encoded): Plays fine Further testing on stand alone using only tsMuxer 2.6.12 output Blu-ray folders: Do not change SEI: Plays fine Always rebuild SEI: There's sound but no picture. Insert SEI if absent: There's sound but no picture. BD-RE discs sure come in handy! |
7th February 2014, 23:57 | #19147 | Link |
@slvrsrfrI ran "The Wire" today. It completed with absolutely no problems. As I expected might happen, everything was perfectly in-sync. I would check your system and make sure you don't have anything else installed that is interfering with processing. The most likely candidate is "CODEC Packs".
8th February 2014, 03:31 | #19148 | Link | |
Thanks for digging into it so quickly! Sorry for your troubles - i'll pick up the wire for you and any overages...paypal payment on its way! I'll see what i can find on my machine re: codecs and post back for posterity... |
8th February 2014, 06:17 | #19149 | Link |
You don't need to do that. I've been meaning to get it anyway. I need to go back through and watch the entire series again. Funny, I just saw "Avon Barksdale" on another show tonight.
8th February 2014, 23:44 | #19150 | Link | |
Anyway, these are the codecs that i found on my machine - do any of them look off? Are there any i should definitely remove? |
8th February 2014, 23:56 | #19151 | Link | |
Often it can be fixed by simply reinstalling BD-RB, AVISYNTH, FFDHOW, and HAALI. But if the offending software is executed again -- you might be right back where you started. |
9th February 2014, 10:30 | #19152 | Link |
RE version 4611
Want to make sure all the required add-ons versions are the same. I noticed there is no "inspect" program included in this download like the previous versions. The readme file in the download package says to use FFdshow 3326 but the first page in this thread says to use 4504. thx. |
9th February 2014, 10:37 | #19153 | Link | ||
9th February 2014, 10:39 | #19154 | Link |
Jdobbs recommends that you use the versions linked here. In the meantime he has given but also the version 4515 free in BD, but linked on the first page.
If you are unsure, use the linked version of FDDShow here and you're on the safe side. if BD is open, you gehtst on Help / Show Settings (Inspect) and see whether all the settings and codecs are ok Edit: Sharc was faster Last edited by inge70; 9th February 2014 at 10:41. |
9th February 2014, 10:57 | #19155 | Link | |
9th February 2014, 15:27 | #19156 | Link | |
9th February 2014, 23:15 | #19157 | Link |
hello
bd rebuilder (standard settings?) FRIMDecode.exe" -ts -i::mvc "K:\BDMV\STREAM\00098.m2ts" "K:\BDMV\STREAM\00104.m2ts" -o \\.\pipe\bdrb.yuv -sw | "C:\Programok\BD_Rebuilder\tools\FRIMEncode.exe" mvc -i \\.\pipe\bdrb_L.yuv -i \\.\pipe\bdrb_R.yuv -viewoutput -o "D:\TEMP4\WORKFILES\VID_00098.AVS.264" -o "D:\TEMP4\WORKFILES\VID_00098.AVS.mvc" -sw -w 1920 -h 1080 -f 23.976 -u 2 -cpbsize 3750 -l 6 -profile high -level 4.1 -vbr 31046 45000 -gop 24 4 0 S -maxdpb 4 -u 2 = quality... -l 6 = slices, 6? no 4? |
10th February 2014, 16:18 | #19158 | Link | |
