17th November 2021, 20:21 | #62367 | Link |
It seems to differ with individual setups.
If you have no need for the new multi plane overlay - just disable it with the .reg file from nvidia and then never worry about it. I did all the worrying for everyone else on this forum over this issue... https://nvidia.custhelp.com/app/answ...tail/a_id/5157 |
17th November 2021, 22:32 | #62369 | Link |
So, finally sat down just to enjoy a flick after all this last weeks stressing, and had something wackily different happen to me.
After about an hour and 15 minutes of straight watching, I noticed a 'click' in the sound - like a sound glitch. I am bit-streaming through my Denon. Then, out of the blue, ALL the sound started coming out of just one of my rear speakers. I put the movie back 10 seconds, and bam, all sound normal again. Could maybe just be the encode I was watching - but does this scream anything else to anyone? Never experienced anything like it before, but haven't really gotten to sit down and watch something more than 20 mins since getting this all straightened out. |
18th November 2021, 10:42 | #62370 | Link | |
However, there's still a problem with UHD HDR rips. I've set the Primaries/Gamut to DCI-P3 for the 2160p23 and 2160p60 profiles and unticked "Report BT.2020 to dislpay". But the display still interprets the material from madVR as being HDR and then switches to high-lamp and HDR Frame Adapt and BT.2020. In the the madVR OSD it says BT.2020 ->DCI-P3. How come madVR shows one thing and the JVC N5 reports another? I'm a bit confused as to whether I should use BT.2020 for HDR material or if I should convert from BT.2020 to DCI-P3 and then just set the lamp to high. When I play series that are in HDR10+ it works fine. MadVR plays these and the projector recognizes these as DCI-P3. Any thoughts as to why this is happening? Thanks for any suggestions. |
18th November 2021, 15:43 | #62371 | Link | |
I use the tone mapping, and then I go to calibration and tell MadVR that I am calibrated for BT.2020. I tried the 'report bt.2020 to display' - and on ONE of my projectors, it works, and on my Sony, it doesn't (I have to manually switch the Sony to BT.2020). With those settings done, you will be outputting SDR BT.2020 (MadVR will still always show BT.2020 -> DCI-P3), and the projector should never switch to HDR. Alternatively, in your PJ settings, you may be able to just SET the picture mode to SDR (e.g. NOT auto) (or conversely turn HDR off) depending on how your PJ menus work. |
18th November 2021, 18:14 | #62372 | Link | |
It is my understanding that I need different profiles but if I don't gain anything from it, I'd be just as happy with just one. I mostly watch movies that are either 1080p23 or 2160p23 (some SDR and some HDR). I also watch some sports games that are 720p60 or 1080p60. Do you need the different profiles to assign different color gamuts (DCI-P3 and BT.2020? |
18th November 2021, 19:11 | #62373 | Link |
@Ultimathor, I use 2 profiles for DCI-P3 (HDR) and BT.709 (SDR). I know the rule of thumb is to use the same for whatever the display is calibrated to but they look better on my display to my eyes and nowhere near as good when simply applying one or the other for everything.
Tbh, I never thought I'd use so many multiple profiles for various things but as I apply them, my diverse collection of titles just keeps looking and performing better and better - automatically with no hands on required due to applying through profiles. Thank you madshi for accommodating every setting and so many keywords, operators, numerical, boolean, and string values to define profiles.
HOW TO-Kodi 2D-3D-UHD (4k) HDR Guide Internal & External Players W11 Pro 24H2 GTX960-4GB RGB 4:4:4 @Matched Refresh Rates 8,10,12bit KODI 22 MPC-HC/BE 82" Q90R Denon S720W Last edited by brazen1; 18th November 2021 at 19:33. |
18th November 2021, 20:41 | #62374 | Link | |
you are using profile without even knowing how things work in the first place get it working first and then think about profiles |
20th November 2021, 04:26 | #62375 | Link |
I noticed some interesting things watching the spears and munsil video a couple of times.
At around 4:30 seconds the shot where the cars are zipping by on a highway in super speed drops and repeats a frame (or 2 each). Every time. Repeatable. Like I can click back 10 seconds and it happens again and again on that scene. I tried three different versions of the video. All the same thing. Render times are not over the 41.7ms mark (or at least not showing they are in the stats). But I don't think it's a render time issue since I backed down the Chroma setting as a test and it STILL happened. Speaking of rendering times - I am noting large fluctuations (maybe normal???). The videos I am watching with my current HDR settings are averaging right around 31/32ms render times, with normal 5s high spikes up to 34-36ms. However, I am noticing some spikes up to the 39/40ms level. Is it normal to have 10ms rendering jumps like that? Also, SOME of the spikes went ABOVE the 41.7ms cut off, with NO effect on dropped frames or present cue. How can that be? UPDATE: This morning I went through a blitz of tests (I have a 2nd hard drive for the HTPC that I installed a fresh copy of Win10 on so I could do driver and lav filter tests without messing up my main HTPC system). When this dropped/repeat frame happens, there IS a 1 frame lowering of the present cue. No matter what I did, that scene always drops and repeats frames. I installed older drivers. I installed an older version of MPC-HC which had an older version of LAV Filters. I tried D3D11 Copyback, I tried DXVA Copyback (I regularly use D3D11 Native). I dropped NGU from High all the way to Low... At this point I feel like I am chasing my tail... UPDATE: I can't handle not being able to test the old drivers. The 3060 is becoming a nightmare. I just ordered a 3080 - which I should be able to put back to driver version 457.xx - the one I used to use. Let's see if that solves EVERYTHING. If not - I will be back! hah Last edited by LordX2; 21st November 2021 at 02:37. |
21st November 2021, 09:02 | #62377 | Link |
Has anyone ever experienced dropped frames and presentation glitches caused by... a perfectly still wireless mouse?
I experienced linked (ie : happening at the same time) dropped frames / presentation glitches every 20 seconds or so. Couldn't solve it no matter what settings I tried. At one point I just had a hunch and switched off my mouse (Logitech MX Anywhere 2S, there is a on/off switch on it). Problem solved, but the mystery remains…
Charky "Rule #1 : If it works, don't change anything." |
21st November 2021, 18:57 | #62379 | Link |
Unifying reciever here. Don't know the firmware number but I believe it's up to date.
TBH between OS and drivers quirks, with custom res and DTM, madvr is starting to be more trouble than what it's really worth, especially for a piece of software that's clearly been sidelined...
21st November 2021, 20:08 | #62380 | Link |
I do know I’ve updated the firmware of either my mouse or keyboard before. You should check for updates rather than just assume it’s updated.
If you think MadVR is getting troublesome you’re free to look around for alternatives. Depending on what you want they’re out there. If you do find an alternative I’d love to hear about it! |
