Old 7th May 2015, 01:52   #2021  |  Link
Originally Posted by mrcorbo View Post
No. But that exits fullscreen and being in fullscreen is part of the trigger. The other seems to be either having the menu open or the exit option specifically as alt+f4-ing exits with no crash.
Not display driver related is it? Try a clean install? or previous versions?
Have you checked your .NET installation with the repair tool?
Old 7th May 2015, 03:00   #2022  |  Link
Scyna
Originally Posted by Zachs View Post
What is your present duration like? It should be less than 1ms. If not you could play around with new render path on/off, DWM sync on/off, go into full screen exclusive mode to see if it changes present duration.
I tried all that and i still get delayed frames. Average render times is between 6-7ms
Scyna is offline   Reply With Quote
Old 7th May 2015, 03:11   #2023  |  Link
Zachs
Suptitle, MediaPlayer.NET
What was your present time?
Old 7th May 2015, 04:13   #2024  |  Link
Scyna
.6-.7 was present time
Old 7th May 2015, 04:15   #2025  |  Link
Zachs
That looks OK. Besides the delayed frame count, does it actually feel like it's stuttering when you have fluid motion enabled?
Old 7th May 2015, 04:46   #2026  |  Link
Scyna
I only notice it when its a lot of delayed frames. When its 1 delayed frame I don't notice it.
Old 7th May 2015, 05:32   #2027  |  Link
Zachs
Max present duration is also less than 1ms?
Old 7th May 2015, 06:50   #2028  |  Link
Scyna
Max present is very random its 6-15ms
Old 7th May 2015, 06:53   #2029  |  Link
Zachs
That's the problem!
The only time I've seen that is if the hardware is overclocked a little too much, or a driver that is misbehaving.
Old 7th May 2015, 07:07   #2030  |  Link
Scyna
I tried stock settings for my gpu and its still the same Max present times. So you think its a driver issue?
Old 7th May 2015, 07:15   #2031  |  Link
Zachs
Try different driver versions perhaps? My old ATI card had this problem too but changing those settings I pointed out earlier, I managed to find some that the driver was happy with. Oh maybe try direct 3d 11 too. But in exclusive mode I've never seen it with any GPUs.
Oh and try changing back buffer counts too.
Old 7th May 2015, 13:30   #2032  |  Link
mrcorbo
Hmm, perhaps I could do something to make sure it exits full screen exclusive mode first before closing. It only happens in exclusive mode right?
No, it does it even if exclusive mode is disabled. I think MPDN exits exclusive mode when you activate the right-click menu anyway, or at least it seems like it does.
mrcorbo is offline   Reply With Quote
Old 7th May 2015, 13:39   #2033  |  Link
mrcorbo
I haven't tried different drivers yet. The crashes have been in ntdll.dll or clr.dll, so probably .NET related. I'll check out the repair tool when I have some time. Thanks.
Old 8th May 2015, 03:33   #2034  |  Link
Zachs
Just a quick heads up. I've updated the OpenCL NNEDI3 scripts on github. Let me know if it's faster / slower for you.
Old 8th May 2015, 04:02   #2035  |  Link
Anime Viewer
Troubleshooter
Anime Viewer's Avatar
The updated OpenCL NNEDI3 is completely unusable for me. When I first tried to set it I got a black screen (no video) with 3-4ms being listed. When I exited MPDN, went back in changed to the original NNEDI3 (to confirm it still worked), and then tried to go back to OpenCL NNEDI3 it had a frozen video screen and the hour glass spinning indefinitely. I couldn't escape the freeze or shut down MPDN, and had to log off then re-log in to get it to close.
System specs: Sager NP9150 SE with i7-3630QM 2.40GHz, 16 GB RAM, 64-bit Windows 10 Pro, NVidia GTX 680M/Intel 4000 HD optimus dual GPU system. Video viewed on LG notebook screen and LG 3D passive TV.
Anime Viewer is offline   Reply With Quote
Old 8th May 2015, 04:16   #2036  |  Link
Zachs
Hmm, might have encountered an NVIDIA OpenCL compiler bug there. I don't have access to my 560 GTX at the moment so I think I'll revert the changes until I can fully test it on NV's latest drivers.
EDIT: I tested this on an NV 8400GS with driver v341.44 and it's fully working... What version are you running by the way?
EDIT2: Anyone else with the same problem?
Old 8th May 2015, 05:53   #2037  |  Link
Can confirm you borked it.
Old 8th May 2015, 05:55   #2038  |  Link
Zachs
OK I'll revert it then, at least until I get a chance to test it on my 560 GTX.
It does run on your Intel HD4000 though right?
Old 8th May 2015, 06:02   #2039  |  Link
Yup, fine on HD graphics.
Old 8th May 2015, 06:11   #2040  |  Link
Anima123
Same here as 'Anime Viewer'.
Anima123 is offline   Reply With Quote
direct3d, mpdn, nnedi3, opencl, reclock
