10th April 2008, 22:25 | #2082 | Link | |
Thanks jmartinr. Is there a problem with seeking in mp4 and mkv containers? What would be a reasonable gop size range? |
11th April 2008, 03:44 | #2083 | Link |
Mr. Sandman
in that case you should report that behaviour to the mkvtoolnix devs
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! |
11th April 2008, 04:28 | #2084 | Link |
"One Click" + no cropping?
I am trying to encode regular dvd (tv shows) with megui and use the one click encoder, but am having an issue in that I don't quite understand how to do this right.
I don't want to resize or crop (therefore I want to end up with an 853x480 video as it displays in mplayer when I play the VOBs). With AutoMKV I can do this by just selecting it's anamorphic option and telling it to use original resolution. however, one click encoder forces me to select a resolution. any ideas? |
11th April 2008, 07:46 | #2085 | Link | |
The slower your computer is the smaller your GOP-size must be. Try it, it doesn't work really smooth and flawless. You can download and try one of my files (with keyint 125, still quite large, I tried to keep the files small) from: http://www.nkbv.nl/sportklimmen/medi...deos/4237.html Last edited by jmartinr; 11th April 2008 at 07:59. |
11th April 2008, 12:57 | #2086 | Link | |
Mr. Sandman
So in Advanced config, select 720 as resolution and check Signal AR.
12th April 2008, 03:44 | #2087 | Link | |
Any one got a player, splitter, decoder set up that can frame step backwards with mkv containers? Or would mp4 be better. Thanks again. Last edited by #2; 12th April 2008 at 03:49. |
12th April 2008, 08:02 | #2088 | Link | |
If you find other solutions I would really like to know about them. |
12th April 2008, 11:34 | #2089 | Link | |
I just got so used to always using MPC that I totally forgot about zoomplayer being able to do frame step backwards too. A newer version of zoomplayer will probably be able to do the same trick. Last edited by jmartinr; 12th April 2008 at 11:35. Reason: Typo |
12th April 2008, 13:08 | #2090 | Link |
Small bug I think with Kurtnoise13's build (when the B-Frames part was moved to the Main tab to introduce AQ in the Advanced tab): In the x264 configuration dialog, changes made to settings in the B-Frames section of the main tab aren't reflected in the command line display below (until you open the dialog again. The changes to the settings are saved okay.)
12th April 2008, 15:01 | #2091 | Link |
Mr. Sandman
yep, i think that build was made just to show the new b-frames options placement.
dont use it for "production"
14th April 2008, 13:53 | #2092 | Link |
Did I miss an update of MeGUI 3?
There were several complaints about the unnecessary update message of MeGUI about .Net 2.0 SP1 in combination with Vista SP1 (the log page showes .Net SP1). I thought, I read something about "the next update will fix it". This was some weeks ago. As I still have 0.3.0.1004 and nothing changed in weeks, I put a bug in the bug tracker: https://sourceforge.net/tracker/?fun...roup_id=156112 But the bug was closed without any comment. |
14th April 2008, 16:18 | #2093 | Link |
Mr. Sandman
no... still no updates.
the bug is fixed though (the stable version is just working without problems) and it will not be present in the next builds. Remember megui 0.3.x is a developmental and unstable version while 0.2.x is stable and working.
14th April 2008, 16:41 | #2095 | Link |
Mr. Sandman
there was no 0.3.x build since it is missing some stuff (profiles refactor)
once the refactor is complete i will make new 0.3.x builds.
14th April 2008, 22:34 | #2096 | Link |
Banned
I get an error during second pass encoding and I don't know why.
I am using the fully updated MeGUI 0.2.6.1046. I input an AviSynth script which has uncompressed video and no audio. I am using CE-Baseline profile. The only modified value is the bitrate, which I chose to be 800. It encodes the first pass just fine, but then the 2nd pass simply says "error" and it is not specific at all. Log file says nothing. Edit: Log File Last edited by Neillithan; 14th April 2008 at 23:33. |
14th April 2008, 22:45 | #2097 | Link |
Mr. Sandman
you better post the logfile... even if you say it says nothing...
15th April 2008, 16:44 | #2098 | Link |
Hi. Im new to this program and encoding in h264 so please excuse me if this is a really stupid question. I have a DVD that i want to rencode to h264 nad keep the DD sound and mux them ino a MKV file. I have demuxed the audio and i have made the avisyth script using the editor included in MeGUI.
My problem is when im encoding the video. The first pass works fine. However the secound pass is aborted and the file is never finished. In the Queue window is just say "error" with no futher explanation. I have tried several times and it alsways end up with error, but no errormessages. The strange thing is that the encoding can runm for everything from 10minutes to 45min. Once i got to about 40% but most of the time, it end at 10-20% completion. Am i doing somthing wrong? Can it be because im changing resolution? The orginial DVD is in 720x480. But the aspect ratio gets wacked, so im using 720x400 (16:9). Please guys. I need some help here. Log file say this: Log for job job8 Job commandline: "D:\DVD\megui\tools\x264\x264.exe" --pass 2 --bitrate 3000 --stats "F:\Test\cloverfield.stats" --ref 10 --mixed-refs --no-fast-pskip --bframes 16 --b-pyramid --b-rdo --bime --weightb --direct auto --filter -2,-1 --subme 6 --trellis 2 --partitions p8x8,b8x8,i4x4,i8x8 --8x8dct --me umh --threads auto --thread-input --sar 1:1 --progress --no-dct-decimate --no-psnr --no-ssim --output "F:\Test\cloverfield.mp4" "F:\Test\cloverfield.avs" avis [info]: 720x400 @ 23.98 fps (121798 frames) x264 [info]: using SAR=1/1 x264 [info]: using cpu capabilities: MMX MMXEXT SSE SSE2 SSE3 SSSE3 Cache64 mp4 [info]: initial delay 2002 (scale 24000) ------------------------------------------------------ End of log for job8 ------------------------------------------------------ |
15th April 2008, 18:29 | #2100 | Link |
Mr. Sandman
it's not megui.
try updating x264. i just uploaded a newer version to the auto-update server. also, if you're using vista ensure you run megui with admin rights.
megui |
