24th August 2020, 13:30 | #1262 | Link |
Long time, no post
I'd like to ask for some help. I've just upgraded to an AMD Ryzen 4000-based laptop with integrated Vega graphics, on dGPU. On my previous laptop I had a crappy Nvidia dGPU, but it still was a tremendous help with transcoding stuff through DGIndex. With this laptop this is out of the picture obviously. What would be the syntax with L-SMASH in Avisynth to utilize the AMD VCN core for HW decoding, to free up the CPU for x264 encoding? If it's not possible with the current compiled binaries, can I build one that includes the capability to use the VCN core? Thanks! |
24th August 2020, 14:54 | #1263 | Link | |
24th August 2020, 14:55 | #1264 | Link | |
Edit: through DXVA and/or D3D11 I believe, unless I've totally misunderstood. Sent from my SM-G973F using Tapatalk Last edited by Boardlord; 24th August 2020 at 15:02. |
25th August 2020, 06:32 | #1265 | Link |
We need proper api like cuvid or quicksync not some hacks via dxva. AMD should stop acting like some special princes and allow third party programmers access to their decoder.
25th August 2020, 19:26 | #1266 | Link | |
random user
However, AMF decoder is not yet integrated in ffmpeg (but encoder is): https://github.com/GPUOpen-Libraries...AMF/issues/199 Btw. on Linux encoding and decoding works with ffmpeg through vaapi.
BeHappy Audio Transcoder > <Doom9 forum> <Gleitz forum> <GitHub> MP4.tool GUI for MP4Box & L-SMASH muxer > https://www.mediafire.com/folder/3i6y6cbkyhblm/MP4.tool |
18th October 2020, 08:31 | #1267 | Link |
there are frame properties PR by Asd-g since a week https://github.com/HolyWu/L-SMASH-Works/pull/12
I think HolyWu is not active these days, so anyone else can build it?
See My Avisynth Stuff |
18th October 2020, 13:11 | #1271 | Link | |
27th October 2020, 05:27 | #1272 | Link | |
error: https://drive.google.com/file/d/1ZNB...ew?usp=sharing file test: https://drive.google.com/file/d/1yHA...ew?usp=sharing |
27th October 2020, 14:11 | #1273 | Link | |
anyway, let's see what the Developers said about it
27th October 2020, 14:57 | #1275 | Link | |
FFMS L-SMASH
30th October 2020, 09:18 | #1276 | Link | ||
#The latest official build (20200728) lwlibavvideosource("Letter - SHE'S.mkv") Number of frames: 6518 Length (hh:mm:ss.ms): 00:04:31.855 Frame width: 1920 Frame height: 1080 Framerate: 23.976 (24000/1001) Colorspace: i420 Frames processed: 6518 (0 - 6517) FPS (min | max | average): 122.0 | 2021 | 448.1 Process memory usage (max): 105 MiB Thread count: 37 CPU usage (average): 13.3% Time (elapsed): 00:00:14.547 Code:
#my build lwlibavvideosource("Letter - SHE'S.mkv", threads=2) Number of frames: 6518 Length (hh:mm:ss.ms): 00:04:31.855 Frame width: 1920 Frame height: 1080 Framerate: 23.976 (24000/1001) Colorspace: i420 Frames processed: 6518 (0 - 6517) FPS (min | max | average): 104.0 | 2487 | 424.9 Process memory usage (max): 104 MiB Thread count: 24 CPU usage (average): 10.8% Time (elapsed): 00:00:15.340 Code:
#ffms2 - no seek issue ffvideosource("Letter - SHE'S.mkv", threads=8) Number of frames: 6518 Length (hh:mm:ss.ms): 00:04:31.855 Frame width: 1920 Frame height: 1080 Framerate: 23.976 (24000/1001) Colorspace: i420 Frames processed: 6518 (0 - 6517) FPS (min | max | average): 167.8 | 2205 | 1077 Process memory usage (max): 133 MiB Thread count: 30 CPU usage (average): 29.3% Time (elapsed): 00:00:06.049 |
30th October 2020, 11:53 | #1277 | Link |
Thanks for looking into it...
I can confirm that the problem disappears when "threads=2" is specified. Still I think that this should be fixed because the HolyWu builds and also FFVideoSource do not have a problem with the default value for Threads (which means to use the number of threads reported by Windows with a ceiling of 16). |
30th October 2020, 21:30 | #1280 | Link | |
I got curious and made a couple of tests using different source filters with Atak's SeekTester 1.2. I used the default frame limit of 1000 frames. As the source I took the "Letter - SHE'S.mkv" (VP9 Video 1080p). My CPU is a Core i5 third generation (2 physical cores plus hyperthreading). I used the default thread values for all source filters which would be 4 for this CPU. FFMS2 StvG from Oct. 2020: There were 12 corrupted frames out of 1000 frames. FFMS2 StvG from Aug. 2020: Same FFMS2 StvG from April 2020: Same FFMS2 StvG from Nov. 2019: Same FFMS2 C-Plugin latest 2.31 by qyot27 Perfect FFMS2 C-Plugin by Reino: Both available versions fail miserably. Mainly corrupted or inserted frames FFMS2 official version 2.40 by Myrsloik: Fails miserably. Mostly corrupted or inserted frames DirectShowSource with LAV Filters: Many inserted frames DSS2Mod with LAV Filters (preroll=15): Perfect LWLibavVideoSource by HolyWu: Perfect Ok, these results are only for this specific VP9 source file. Other source formats may behave differently, but I find this very interesting. Any comments? |
