Old 3rd September 2020, 05:20   #2561  |  Link
wanezhiling
I just need a GT3005 card.
Old 3rd September 2020, 06:18   #2562  |  Link
chros
chros's Avatar
Or 3000.01
Old 3rd October 2020, 10:39   #2563  |  Link
NikosD
Has anyone kept a recent copy of MS HEVC Video Extension decoder or know a way to download it for free ?
Recent changes to MS policy prohibit free download of the HEVC decoder, even from the device manufacturer page:
https://www.microsoft.com/en-us/p/he...ot:overviewtab
HEVC decoding benchmarks
H.264 DXVA Benchmarks for all
Old 3rd October 2020, 12:39   #2564  |  Link
Klaus1189
I am not sure, but I think I found it
Old 3rd October 2020, 17:42   #2565  |  Link
NikosD
It works like a charm, thank you!
Old 15th March 2021, 03:04   #2566  |  Link
wanezhiling
who has 8k hevc 8-bit 60p clips?
Old 16th March 2021, 16:31   #2567  |  Link
VictorLS
I have not - I have just 4K H265 60fps 8bit
But if you really need 8K H265 60fps 8bit do it by yourself
VictorLS is offline   Reply With Quote
Old 14th April 2021, 12:14   #2568  |  Link
littleD
littleD's Avatar
Interesting. Vulkan +Video hardware Acceleration.
https://www.phoronix.com/scan.php?pa...ovisional-Spec
littleD is offline   Reply With Quote
Old 17th April 2021, 14:41   #2569  |  Link
wanezhiling
DXVA Checker 4.5.2
Version 4.5.2 (04/17/2021)
Fixed incorrect parameters when blitting in DXVA2 Video Processor under specific situations
(this)
Old 26th April 2021, 11:57   #2570  |  Link
littleD
littleD's Avatar
https://www.saschawillems.de/blog/20...3.01-released/
This version also adds support for the video decode and encode queue family flags that have been introduced with the provisional Vulkan Video acceleration extensions.
Old 29th April 2021, 10:08   #2571  |  Link
Its important to note that Vulkan video acceleration currently only supports H264 and HEVC, so it still has ways to go to become even remotely viable by supporting a much wider variety of codecs that we all expect by now.
Old 17th May 2021, 20:15   #2572  |  Link
pureocean
The least latency when seeking non-keyframe
The display times of subtitle lines don't usually occur in keyframes.
I can't read subtitle lines fast. I get back frequently when playback. When I jump to the previous/next line of the subtitle (HOME+END key in PotPlayer / CTRL+Left/Right Arrow key in mpv), I cannot tolerate a little lag of the frame refresh. Because of this reason I always turn off H/W (DXVA) for H264 decoding, which it causes the image to be slow displayed in Radeon R7 240.
Which of the both cards below that support H/W 1080p 10-bit HEVC decoding does the least latency when seeking non-keyframe, even if DXVA2/D3D11 is on?
Is GeForce GT 1030 or Radeon RX 550?
pureocean is offline   Reply With Quote
Old 18th May 2021, 04:57   #2573  |  Link
i can't remember anyone doing seek tests but polaris cards can barely do 60 FPS UHD meaning the nvidia cards are massively faster in terms of decoding but and here we go yet again i can remember a 1030 test and the Vram of that card can be a problem for real world playback.
if you want the fastest seeks a better CPU is what you want.
Old 18th May 2021, 05:44   #2574  |  Link
Asmodian
The DDR4 or GDDR5 GT 1030? If you do get a GT 1030 make sure it is not the DDR4 one, the memory is simply too slow for great hardware decoding (or great anything). Most listings do mention the type of memory used.
I agree with huhn, a faster CPU with software decoding is better for seeking.
madVR options explained
Old 18th May 2021, 23:44   #2575  |  Link
pureocean
@huhn and @Asmodian,
Thank you both for your informations and advices.
I upgraded my old CPU (Phenom II X3) to Ryzen 5 3600 last summer. The non-keyframe seeking performance has really improved.
On my old CPU, non-keyframe seeking performance of FFMpeg-based decoders (LAV and MPC-BE's MPCVideoDec) was not good. That's why I was using Lentoid HEVC Decoder. I easily use LAV and MPCVideoDec on the Ryzen 5 3600. Moreover, in combination with MPC VideoRenderer and Bluesky Frame Rate Converter.
Actually, my R7 240 is still enough for me. Recently I removed the fan jumper (noising). But the card came overheating when playing 10-bit HEVC 1080p. I replaced the fan. Also flashed the lastest VBIOS.
AMD's Oland (GNC1.0 series, UVD 4) lacks H/W 10-bit support. My goal to use DXVA2 / D3D11 in both H264 and HEVC without lag when non-keyframe seeking.
If I buy a new card, I will prefer GT 1030 (Of course, GDDR5 is very important. MPN Model: V809-2498R, GTIN/EAN: 4719072520113).
Also, Nvidia pays more attention to video codec decoding and encoding. They have documentation listing supported models for this.
https://developer.nvidia.com/video-e...ort-matrix-new
https://docs.nvidia.com/video-techno...lication-note/
https://developer.nvidia.com/nvidia-video-codec-sdk
https://developer.nvidia.com/blog/nv...scoding-guide/
They even recently added the Vulkan Video Hardware Acceleration mentioned here to the GT 1030.
If I buy Geforce, I will be deprived of AMD's Fluid Motion but there are alternatives (madVR, SVP).
Old 22nd May 2022, 07:03   #2576  |  Link
mariner
Greetings.
8K AV1: Intel Iris XE or UHD 750?
1. The built-in IRIS XE GPU of Tiger Lake 1165G7 has added support for 8K AV1 decoding. While decoder performance suggests it could handle it, playback performance struggled at 50fps. Does anyone have success with this? Would faster/more ram help? Memory used is 16GB 2666MHz DDR4.
2. Does the UHD 750 GPU have AV1 support? Would it perform better?
3. What about AMD GPU?
Thanks and best regards,
mariner is offline   Reply With Quote
Old 22nd May 2022, 08:45   #2577  |  Link
v0lt
Intel UHD 750 supports AV1 decoding.
The adapter plays 4k AV1 10-bit HDR 60fps from YouTube stably.
I don't need 8k.
Old 22nd May 2022, 12:49   #2578  |  Link
clsid
When support for a higher resolution gets added in a GPU decoder it is usually just 30 fps. Later generation then improves performance further to support 60 fps.
I doubt you will find 8k60 content beyond demo stuff. So who cares.
MPC-HC 2.2.1
Old 25th May 2022, 09:42   #2579  |  Link
mariner
8K/60p AV1 HDR YT video: more testing with Iris XE Graphics
Thanks for the kind reply, v0lt and clsid.
1. While DXVAchecker struggled with 8K AV1 video, w10 built-in movies player handled it beautifully with 90% GPU usage. As the decoder used by both is presumably the same, does anyone have any insight how w10 managed this?
2. Potplayer's AV1 decoder could handle 4K AV1 video, but struggled at 8K.
3. LAV filters could not deal with even the 4K version as it doesn't seem to have AV1 decoding capability. As I'm new to using w10 for video playback, would appreciate any advice setting up the filter: Should DXVA2(native) or D3D11/Intel Iris XE Graphics be selected?
4. Any idea if UHD 750/770 would offer similar w10 performance?
5. What about RYZEN CPU?
Old 25th May 2022, 10:08   #2580  |  Link
v0lt
1. What file did you play? (only a file and not a stream from the network)
2. Is it 8-bit or 10-bit?
3. How did you check the output frame rate?
