Go Back   Doom9's Forum > Capturing and Editing Video > Capturing Video
Old 29th August 2020, 11:21   #21  |  Link
StainlessS
StainlessS's Avatar
Parallel Interface Kit BDKW-509 (50-pol (Centronics ?) cable
Centronics, was a company name, used as a generic term for parallel printer [EDIT: port or] cable (as is Hoover to mean vacuum cleaner).
There are many types of parallel ports, but the term has become most closely associated with the printer port or Centronics port found on most personal computers from the 1970s through the 2000s.
It was an industry de facto standard for many years, and was finally standardized as IEEE 1284 in the late 1990s, which defined the Enhanced Parallel Port (EEP) and Extended Capability Port (ECP) bi-directional versions.
Today, the parallel port interface is virtually non-existent because of the rise of Universal Serial Bus (USB) devices, along with network printing using Ethernet and Wi-Fi connected printers.
https://en.wikipedia.org/wiki/Parallel_port
EDIT: Google finds nothing for "BDKW-509". [ Not even in this thread ??? (well it does find a web page full of letters and numbers "bdkw ;509", but thats all) ]
Google:- https://www.google.co.uk/search?sour...4dUDCAg&uact=5
Bing:- https://www.bing.com/search?q=BDKW-5...E5D0A10997D7F0
Yandex:- https://yandex.com/search/?text=%22BDKW-509%22&lr=10393
Swisscows:- https://swisscows.com/web?query=%22B...2&region=en-GB
Duckduckgo:- https://duckduckgo.com/?q=%22BDKW-509%22&t=hk&ia=web
I sometimes post sober.
Old 31st August 2020, 08:17   #22  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
http://www.classicbroadcast.de/Sony-DVW-A500-Manual.pdf
https://docs.sony.com/release/bkdw515_380054104_om.pdf
https://pro.sony/s3/cms-static-conte...3800542041.pdf
Poor Google ;-)
And I assumed wrongly, the 50-pin wasn't a Centronics-50, it was a D-Sub 50 female
(OM 10000+ en, 1995.05.13, page 44/156, paragraph 19 and page 146/156)
Old 3rd September 2020, 19:52   #23  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
You can also install multiple RS422 serial controllers in your PC. Then your capture software will need to be able to run 4 capture sessions in parallel complete with deck control for each, of course!
At this point you're making a video ingest server
Old 17th September 2020, 12:48   #24  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
I finally inserted the 9 pin cable for the remote and it's working just fine!
I was so happy, but then, today, as I was working on a 1989 BetaCAM, something bad happened...
Old 17th September 2020, 17:03   #25  |  Link
Emulgator
Emulgator's Avatar
Send it to me and have it cleaned.
