12th September 2020, 05:19 | #29961 | Link |
BD Rebuilder Beta-только сообщения об ошибках
have a nice day. sorry for my english i use a translator. noticed such a problem. after deleting unnecessary audio tracks and playing in DUNE HD, the sound on the main movie does not work. When playing a movie with a menu (full menu), there is sound in the menu, additional materials, but there is no sound in the movie itself. When played without a menu (lite), there is sound in the movie. And so on any reassembled film. If you rebuild the movie with the multiAVCHD program, the sound works in the main movie, and in the menu, and in additional materials.
12th September 2020, 11:53 | #29962 | Link | |
I made a backup boot HD with my W7, and I had to use it a few times. I have a 2.5/3.5 HD "cassette" that I installed into my PC, so I can mount hard drives without having to open up my computer. I also installed a usb 3.1 card, and a SATA3 controller I have not even applied any "De-Bloat" "De-Crapifier" etc., W10 Privacy settings yet. I will make a backup image b4 I start applying those "tools". So, just saying that as a fellow "W7 forever" person, go ahead and make the jump! look up on youtube and google how to most probably be able to still use your W7 activation code to work with W10. I have a nVidia 1050ti installed, as much as I would like to play with a new GPU, unless the turing NVidia cards get real cheap, (or I win a lottery!), I will be keeping the 1050ti for a while. I know my GPU does not support "HEVC B Frame". So unless a 1660 or better nVidia card gets real cheap (come on Black Friday!), I will be keeping my 1050ti. Also, if I read the last few pages here correctly, there are no more "new" encoding features on the new nVidia cards, just much faster processing, and other playback and decoding improvements. One of the many reasons why I like BD-Rebuilder so much, is that I can apply all the "insane" "over kill" super slow video encoding settings in x265 to my MKV files! Oh, I have to say, check out "Open Shell", it will turn your W10 into the W7 look and feel you love! "Open shell" used to be called "Classic Shell", and the original developer stopped developing "Classic Shell", so a new person took over development of the same program. https://open-shell.github.io/Open-Shell-Menu/ Last edited by BuddTX; 12th September 2020 at 11:57. |
12th September 2020, 20:56 | #29964 | Link |
Back from holidays I just did the first encode with BDRB 0.61.13 and I swapped the nvenc files with the newest ones (version 5.15 ... which apparently was released just some hours ago) and now HDR10+ works and looks awesome on alternate encodes.
I used the hidden switch mentioned in the last release notes. Will do some more sources to confirm the results. |
12th September 2020, 22:17 | #29965 | Link | |
12th September 2020, 23:39 | #29966 | Link |
I posted and then removed v0.61.15 -- there's something that I forgot to test and I suspect it may have an issue.
If you downloaded it -- please don't upgrade/use it until I know it is working properly. Last edited by jdobbs; 12th September 2020 at 23:50. |
13th September 2020, 21:47 | #29967 | Link |
This might have been reported already?
If BDRB is set to NVENC, the encode stops on some sources with error, when the size-correcting second pass should be performed: Code:
... - [20:00:21] Processing: VID_00004 (5 of 21) - [20:00:21] Extracting A/V streams [VID_00004] - [20:00:26] Reencoding video [VID_00004] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 2.520 frames - [20:00:26] Performing CQM Prediction... - Analyzing 14,50 19,15 20,10 [20,12] - [20:00:36] Encoding using constant quality mode. - Performing size-correcting second pass... - [20:00:55] PredictAndEncode() 00011 2994 |
14th September 2020, 22:45 | #29969 | Link |
BD Rebuilder v0.61.16
I have updated the first post of this thread with a link to the most recent version of BD-RB (v0.61.16). Changes for this release:
- Handling of HDR10+ in NVENCC has now been enabled by default, the hidden option NVENC_ENABLE_10PLUS is no longer needed or supported. - Corrected an issue in which SD imports may not be reencoded with the correct aspect ratio under some (rare) circumstances. - Fixed an issue associated with incorrect subtitle PID values on UHD/HDR sources. - Added parameter to MKV creation that makes odd subtitle characters less likely. - Updated the version of NVENCC included with BD-RB to v5.15 -- enabling corrected HDR10+ support. - Other minor corrections and cosmetic fixes. |
14th September 2020, 23:47 | #29970 | Link | |
Elit Amans
This is my understandings, anyone feel free to correct me if i'm wrong. //LD |
15th September 2020, 01:14 | #29971 | Link | |
15th September 2020, 02:24 | #29972 | Link |
It is the same thing with 1080 video. In case you didn't know, 1080 is encoded at 1088, as it too needs to be a multiple of 16. In the early days of OTA HD, my local NBC affiliate had their encoder screwed up such that the 1088 was actually displayed as 1088. The VideoReDo software had to add a "feature" where this was detected and fixed so that I could edit 1080 material with this screwed up 1088 material.
15th September 2020, 23:15 | #29975 | Link |
I have an install question, and I apologize in advance if it has been answered before, or if the answer is obvious, but obviously it is confusing to me:
The instructions say: ================================= 2. While not required it is recommended you perform either one of the following (2A, preferred, or 2B): 2A. Download and install the LAV Directshow Filters. Use only the version linked here -- as other versions may result in out-of-sync audio. While not required for BD-RB to work, LAVFilters will improve functionality and are free. They are required for some functionality associated with HEVC import and processing. 2B. Download and install FFDSHOW and the Haali Matroska Splitter. While they are not required for BD-RB to work, they will improve functionality and are free. After the install, run "Video Decoder Configuration" for FFDSHOW from the "START/Programs" menu, and make sure MPEG2 decoding is enabled. Do the same using "Audio Decoder Configuration" to ensure "Uncompressed" is set to "All Supported". 2C. If you decide to install both 2A and 2B, make sure HAALI/FFDSHOW (2B) is installed first, followed by LAVFilters (2A). This will prevent issues with HEVC splitting. ================================= So the first line says "2A, preferred". OK that makes sense, I always want to do what the author recommends, right! But then in 2B it says: ======= While they are not required for BD-RB to work, they will improve functionality and are free. ======= So, does this mean I SHOULD ALSO install 2B? After all, who would not want "improved functionality". I am assuming that BD Rebuilder will work better if both 2A and 2B are installed, based on this statement, but the first statement says that 2A is preferred. Thanks in advance! |
16th September 2020, 13:55 | #29977 | Link | |
17th September 2020, 04:58 | #29980 | Link |
Elit Amans
I got this error with UHD The Natural. Did it before with previous version of BD-RB without fail, but as I got a bit of an undersize + the sub bug I decided to redo it comletely with the new version.
---------------------- [09-17-20] BD Rebuilder v0.61.16 [02:28:54] Source: NATURAL__THE_ - Input BD size: 84,78 GB - Approximate total content: [03:25:27.987] - Target BD size: 49,02 GB - Windows Version: 6.2 [9200] - Quality: Highest (Very Slow), Two Pass - Decoding/Frame serving: FFMPEG - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [02:28:54] PHASE ONE, Encoding - [02:28:54] Processing: VID_00001 (1 of 43) - [02:28:54] Extracting A/V streams [VID_00001] - [02:28:57] Reencoding video [VID_00001] - [02:28:57] Keeping original video (no reencode) - [02:28:57] Processing audio tracks - [02:28:57] Multiplexing M2TS - [02:29:01] Processing: VID_00080 (2 of 43) - [02:29:01] Extracting A/V streams [VID_00080] - [02:29:05] Reencoding video [VID_00080] - [02:29:05] Keeping original video (no reencode) - [02:29:05] Processing audio tracks - [02:29:05] Multiplexing M2TS - [02:29:08] Processing: VID_00081 (3 of 43) - [02:29:08] Extracting A/V streams [VID_00081] - [02:29:12] Reencoding video [VID_00081] - [02:29:12] Keeping original video (no reencode) - [02:29:12] Processing audio tracks - [02:29:12] Multiplexing M2TS - [02:29:15] Processing: VID_00082 (4 of 43) - [02:29:15] Extracting A/V streams [VID_00082] - [02:29:19] Reencoding video [VID_00082] - [02:29:19] Keeping original video (no reencode) - [02:29:19] Processing audio tracks - [02:29:19] Multiplexing M2TS - [02:29:22] Processing: VID_00100 (5 of 43) - [02:29:22] Extracting A/V streams [VID_00100] - [02:29:28] Reencoding video [VID_00100] - Source Video: HEVC, 3840x2160 - Rate/Length: 23,976fps, 346 frames - Bitrate: 11 918 Kbs - [02:29:28] Reencoding: VID_00100, Pass 1 of 2 - [02:31:59] Reencoding: VID_00100, Pass 2 of 2 - [02:34:58] Video Encode complete - [02:34:58] Processing audio tracks - Track 4352 (eng): Keeping original audio - [02:34:58] Multiplexing M2TS - [02:35:02] Processing: VID_00102 (6 of 43) - [02:35:02] Extracting A/V streams [VID_00102] - [02:35:06] Reencoding video [VID_00102] - Source Video: HEVC, 3840x2160 - Rate/Length: 23,976fps, 5 200 frames - Bitrate: 500 Kbs - [02:35:06] Reencoding: VID_00102, Pass 1 of 2 - [02:46:37] Reencoding: VID_00102, Pass 2 of 2 - [02:54:01] Video Encode complete - [02:54:01] Processing audio tracks - [02:54:01] Multiplexing M2TS - [02:54:05] Processing: VID_00104 (7 of 43) - [02:54:05] Extracting A/V streams [VID_00104] - [02:54:10] Reencoding video [VID_00104] - Source Video: HEVC, 3840x2160 - Rate/Length: 23,976fps, 1 frames - Bitrate: 48 000 Kbs - [02:54:10] Reencoding: VID_00104, Pass 1 of 2 - [02:54:11] Reencoding: VID_00104, Pass 2 of 2 - [02:54:13] Video Encode complete - [02:54:13] Processing audio tracks - [02:54:13] Multiplexing M2TS - [02:54:17] Processing: VID_00116 (8 of 43) - [02:54:17] Extracting A/V streams [VID_00116] - [02:54:21] Reencoding video [VID_00116] - Source Video: HEVC, 3840x2160 - Rate/Length: 23,976fps, 271 frames - Bitrate: 4 292 Kbs - [02:54:21] Reencoding: VID_00116, Pass 1 of 2 - [02:55:35] Reencoding: VID_00116, Pass 2 of 2 - [02:56:53] Video Encode complete - [02:56:53] Processing audio tracks - Track 4352 (eng): Keeping original audio - [02:56:53] Multiplexing M2TS - [02:56:57] Processing: VID_00208 (9 of 43) - [02:56:57] Extracting A/V streams [VID_00208] - [02:57:01] Reencoding video [VID_00208] - Source Video: HEVC, 3840x2160 - Rate/Length: 23,976fps, 262 frames - Bitrate: 3 863 Kbs - [02:57:01] Reencoding: VID_00208, Pass 1 of 2 - [02:58:02] Reencoding: VID_00208, Pass 2 of 2 - [02:59:00] Video Encode complete - [02:59:00] Processing audio tracks - Track 4352 (eng): Keeping original audio - [02:59:00] Multiplexing M2TS - [02:59:04] Processing: VID_00336 (10 of 43) - [02:59:04] Extracting A/V streams [VID_00336] - [02:59:08] Reencoding video [VID_00336] - [02:59:08] Keeping original video (no reencode) - [02:59:08] Processing audio tracks - [02:59:08] Multiplexing M2TS - [02:59:11] Processing: VID_00337 (11 of 43) - [02:59:11] Extracting A/V streams [VID_00337] - [02:59:46] Reencoding video [VID_00337] - Source Video: HEVC, 3840x2160 - Rate/Length: 59,940fps, 7 728 frames - Bitrate: 22 256 Kbs - [02:59:46] Reencoding: VID_00337, Pass 1 of 2 - [04:20:04] Reencoding: VID_00337, Pass 2 of 2 - [05:38:56] Video Encode complete - [05:38:56] Processing audio tracks - Track 4352 (eng): Keeping original audio - [05:38:56] Multiplexing M2TS - Error in attempt to multiplex: MUX_00337.meta - HEVC manual defined fps doesn't equal to stream fps. Change HEVC fps from 59.97 to 59.9401 [05:39:02] - Failed to build structure, aborted Code:
[Status] LABEL=NATURAL__THE_ VERSION=v0.61.16 SOURCE_SIZE=91036714291 SOURCE_VIDEO_SIZE=90696757248 TARGET_SIZE=52638515200 REDUCTION=.576630959517059 RESIZE_1080=0 RESIZE_1440=0 AUDIO_TO_KEEP=all KEEP_HD_AUDIO=-1 SUBS_TO_KEEP=all BACKUP_MODE=0 MOVIEONLY_TYPE=0 USE_LAVF=0 INSTANCES=1 DGDECNV=-1 DGDECIM=0 FRIMSOURCE=0 FFMS2=0 SSIF_MODE=0 UHD_V3_MODE=0 QUICK=0 ENCODE_STEP=4 COMPLETED=10 [00001] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=325939 USE_ORIGINAL=1 NSTART=27000000 NEND=28351349 NSIZE=589824 FLINK=0 MLINK=0 [00080] AUDIO= PGS=1 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=109827 USE_ORIGINAL=1 NSTART=27000000 NEND=27450449 NSIZE=196608 FLINK=0 MLINK=0 [00081] AUDIO= PGS=1 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=109827 USE_ORIGINAL=1 NSTART=27000000 NEND=27450449 NSIZE=196608 FLINK=0 MLINK=0 [00082] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=109827 USE_ORIGINAL=1 NSTART=27000000 NEND=27450449 NSIZE=196608 FLINK=0 MLINK=0 [00100] AUDIO=1 PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=24643860 RATE=11918 NSTART=27000000 NEND=27649398 NSIZE=24084480 FLINK=0 MLINK=0 [00102] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=4439154 RATE=500 NSTART=27000000 NEND=36759749 NSIZE=8294400 FLINK=0 MLINK=0 [00104] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=276340 RATE=48000 NSTART=27000000 NEND=27001876 NSIZE=430080 FLINK=0 MLINK=0 [00116] AUDIO=1 PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=6940386 RATE=4292 NSTART=27000000 NEND=27508632 NSIZE=6782976 FLINK=0 MLINK=0 [00208] AUDIO=1 PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=6079480 RATE=3863 NSTART=27000000 NEND=27491740 NSIZE=6070272 FLINK=0 MLINK=0 [00336] AUDIO= PGS=1 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=109827 USE_ORIGINAL=1 NSTART=27000000 NEND=27450449 NSIZE=196608 FLINK=0 MLINK=0 [00337] AUDIO=1 PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=390557002 RATE=22256 Code:
"C:\vidsoft\BD_Rebuilder\tools\ffmpeg.exe" -probesize 100MB -i "A:\UHDBD\THE NATURAL\BDMV\STREAM\00337.m2ts" -an -pix_fmt yuv420p10le -f yuv4mpegpipe -strict -1 - | "C:\vidsoft\BD_Rebuilder\tools\x265-64.exe" - --preset slow --profile main10 --uhd-bd --repeat-headers --vbv-bufsize 45000 --vbv-maxrate 48000 --hdr --chromaloc 2 --colorprim bt2020 --transfer smpte2084 --colormatrix bt2020nc --master-display "G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(40000000,50)" --fps 59.97 --sar 1:1 --qpfile "B:\WORK\WORKFILES\VID_00337.CHP" --keyint 60 --bitrate 22256 --y4m --stats "B:\WORK\WORKFILES\VID_00337.AVS.hevc.stats" --pass 2 --output "B:\WORK\WORKFILES\VID_00337.AVS.hevc" Code:
[09-17-20] Checking System Settings - BD-Rebuilder v0.61.16 - Windows Version: 6.2 [9200] - Working Path Free Space: 604,51GB - AVISYNTH Version: 2.6.0.5, Ok - LAVFILTERS: Ok - X264: Ok - X265: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [09-17-20] Systems Settings Check complete |
