Old 2nd April 2016, 19:14   #41  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Originally Posted by ddubya View Post
I have fixed a bunch of bugs in vsrawsource and almost done adding tests. Also I have added capability to read from a pipe (not tested on windows yet).
I have not compiled or tested on windows yet, if you want to help go for it.
https://github.com/walisser/vsrawsource
I've had a go at making it compile on windows. Btw, snprintf works just fine in vs2015 so don't just mindlessly copy and paste compatibility stuff.
I'm going to test my changes and then make a pull request I guess.
Old 2nd April 2016, 19:27   #42  |  Link
Efenstor
Originally Posted by jackoneill View Post
video = core.raws.Source("/dev/stdin", 1920, 1080, 30000, 1001)
Ouch. Never though it would be that simple and obvious.
Efenstor is offline   Reply With Quote
Old 4th April 2016, 02:54   #43  |  Link
ddubya
Use "/dev/stdin" as the file path (it needs to be a path) instead of sys.stdin
ddubya is offline   Reply With Quote
Old 29th July 2016, 19:31   #44  |  Link
Myrsloik
Myrsloik's Avatar
Here are compiled windows binaries.
Old 30th July 2016, 15:50   #45  |  Link
kolak
Going to try.
Old 30th July 2016, 23:27   #46  |  Link
kolak
import vapoursynth as vs
import sys
core = vs.get_core()
clip = core.raws.Source("/dev/stdin")
clip = core.fmtc.bitdepth (clip, bits=10)
clip.set_output()
enable_v210 = True
with:
ffmpeg -i C:\Users\Andy\Desktop\50i.avi -f yuv4mpegpipe - | "C:\Program Files (x86)\VapourSynth\core64\vspipe.exe" --y4m C:\Users\Andy\Desktop\rr.vpy - | C:\ffmpeg.exe -i - -c:v v210 C:\Users\Andy\Desktop\vv.mov
doesn't work, giving error:
Output #0, yuv4mpegpipe, to 'pipe:':
Metadata:
encoder : Lavf57.44.100
Stream #0:0: Video: wrapped_avframe, yuv422p, 1920x1080, q=2-31, 200 kb/s, 2
5 fps, 25 tbn, 25 tbc
Metadata:
encoder : Lavc57.51.100 wrapped_avframe
Stream mapping:
Stream #0:0 -> #0:0 (utvideo (native) -> wrapped_avframe (native))
Press [q] to stop, [?] for help
Script evaluation failed:
Python exception: raws: source does not exist.
File "src\cython\vapoursynth.pyx", line 1491, in vapoursynth.vpy_evaluateScrip
t (src\cython\vapoursynth.c:26897)
File "C:\Users\Andy\Desktop\rr.vpy", line 5, in <module>
File "src\cython\vapoursynth.pyx", line 1383, in vapoursynth.Function.__call__
(src\cython\vapoursynth.c:25204)
vapoursynth.Error: raws: source does not exist.
looks like /dev/stdin doesn't work.
Old 30th July 2016, 23:47   #47  |  Link
sl1pkn07
Pajas Mentales...
/dev/stdin sounds a linux
[AUR] Vapoursynth Stuff
[AUR] Avisynth Stuff
sl1pkn07 is offline   Reply With Quote
Old 30th July 2016, 23:55   #48  |  Link
kolak
Yes, but been told it should work here also I've read it won't on Windows.
More issues:
clip = core.raws.Source("C:\Users\Andy\Desktop\vv.raw", 1920, 1080, 30000, 1001, src_fmt='YUV422P10')
gives strange error:
Python exception: (unicode error) 'unicodeescape' codec can't decode bytes in po
sition 2-3: truncated \UXXXXXXXX escape (rr.vpy, line 4)
File "src\cython\vapoursynth.pyx", line 1490, in vapoursynth.vpy_evaluateScrip
t (src\cython\vapoursynth.c:26883)
File "C:\Users\Andy\Desktop\rr.vpy", line 4
SyntaxError: (unicode error) 'unicodeescape' codec can't decode bytes in positio
Is this complaining about actual video data?
Old 31st July 2016, 01:09   #49  |  Link
ddubya
No, if you want to use a literal backslash in a string, you must escape it with another backslash.
You can use forward slash instead or format like this
"C:\\folder1\\folder2\\file.raw"
etc.
Old 31st July 2016, 01:19   #50  |  Link
ddubya
Yes, it needs the hack that treats the empty dash (-) as stdin, as is the usual convention.
In theory, you could run a pipe server and use names pipes as the ffmpeg ouput / vs input. I don't know of any command offhand that provides this.
Old 31st July 2016, 01:52   #51  |  Link
ddubya
Changes pushed for opening from stdin, using "-"
Old 31st July 2016, 12:31   #52  |  Link
kolak
etc.
OK, but this is related only to raw reader. Other plugins are fine with "normal" paths.
Old 31st July 2016, 12:33   #53  |  Link
kolak
Cool, need to wait for myrsloik to compile new version.
How I meant to use it after this change? Still:
Old 31st July 2016, 20:15   #54  |  Link
ddubya
It isn't the plugin, its python. The backslash by itself is the escape character.
Old 31st July 2016, 20:15   #55  |  Link
ddubya
clip = core.raws.Source("-")
Old 31st July 2016, 20:59   #56  |  Link
kolak
Ok, but other filters (ffms2, avi source) handle "normal" paths fine without any workaround (at least form the end user).
Old 31st July 2016, 20:59   #57  |  Link
kolak
Easy enough
Old 2nd August 2016, 12:56   #58  |  Link
Myrsloik
Myrsloik's Avatar
Updated binaries
Old 2nd August 2016, 15:03   #59  |  Link
kolak
Thanks, but still no luck:
Python exception: raws: failed to open source file stdin in binary mode (for both rawvideo and y4m)
Old 4th August 2016, 10:40   #60  |  Link
Myrsloik
Myrsloik's Avatar
I have a vague memory the code has to do it the windows api way. Using portable stuff won't work.
Or that it works often enough if you simply skip it on windows. That's what x264 seems to do anyway.
