20th May 2016, 12:34 | #24241 | Link |
with this confg ( 32,3gb to 23,1gb) in archive_ mode with x265
TWEAK_X265=--output-depth 10 --profile main10 --tune grain --uhd-bd ARCHIVE_MODE=1 ARCHIVE_CRF=13.7 ARCHIVE_QUALITY=5 ARCHIVE_LIMIT=0 ARCHIVE_265=1 ARCHIVE_ENABLE=1 |
22nd May 2016, 01:05 | #24242 | Link | |
24th May 2016, 19:56 | #24245 | Link |
subtitle issue after alternate output from DVD import
Hi jdobbs,
I have to say that this issue might be strange but anyway... I have some issues with MP4s streaming from my NAS to TV using DLNA. Normally I create MP4s from my DVDs with Handbrake/Vidcoder which works OK in 99% of all cases. Lately I converted some movies with AAC and AC3 Audio and hardcoded subs. Sometimes streaming these to my TV fail at some point. I did dozens of new encodes using different settings. To make it short it seems the muxing is the issue: After demuxing and simple remuxing using MP4Box the files play fine (so far). Fingers crossed! While testing different settings BD Rebuilder came to my mind because I use it very successfully for BD to MP4 conversion. So I imported the DVD which was restructured into (pseudo) BD format. I then chose alternate output. 1 subtitle stream marked as "forced on". x264 stopped encoding 15 frames before end reproducably. At the very end 1 last subtile should be shown. Examining the stream with Subtitle Edit showed the length under 1 second. Could that be the issue? Previewing the avs file in MPC dumped sometimes, not always... Encoding without subs works as expected. Right now I have no idea what to check. If you have an idea please let me know. BTW This post might be a Feature request for DVD Rebuilder allowing x264 MP4 Encoding :-) ggtop Last edited by ggtop; 24th May 2016 at 19:58. |
25th May 2016, 09:49 | #24246 | Link |
@jdobbs
You could help me try to use a command to TWEAK_X265 = s in archive_mode for backup hvec I wish I could do 2 pass and custom target (24280 mb), I do not want to use crf (always different sizes) or is it not possible? * diferences in --cu-lossless, --no-cu-lossless ? thanks Last edited by lauguru; 25th May 2016 at 09:53. |
26th May 2016, 22:28 | #24247 | Link | |
27th May 2016, 09:08 | #24252 | Link | |
I would like to make the whole structure of a BD50 / h264 and use all the space BD25 using the potential of HVEC / X265 using 2 pass custom target.
I guess just missing that bdrebuilder, default encoding in X265, instead of x264, if @jdobbs could add that option in another version of bdrebuilder, would be appreciated. Since archive_mode only leaves one pass and crf Quote:
[00037] caption=MKV Container, HEVC 1920x1080, Intact Audio vEncoder=1 vBitrate=2000 vKeyint=Auto aType=2 vFormat=5 cType=1 Last edited by lauguru; 27th May 2016 at 09:12. |
29th May 2016, 17:10 | #24253 | Link |
HI
i'm italian sorry for my bad english maybe for newbie with me is prefer that the settings are automatic o fit inside bd rebuilder for simplify the set i use win7 64bit can you check if the settings are correct ? my backup are slightly out of sync, for example with REVENANT http://postimg.org/delete/qysqhp8rk/ http://postimg.org/delete/mzwl6sb4w/ i use ffdshow maybe i must to try with LAV Directshow Filters and disinstall ffdshow ? [04/29/16] BD Rebuilder v0.50.12 [14:30:25] Source: REVENANT - Input BD size: 37,18 GB - Approximate total content: [02:36:21.371] - Target BD size: 23,88 GB - Windows Version: 6.1 [7601] - MOVIE-ONLY mode enabled - Quality: High Quality (Default), Two Pass - SHUTDOWN at completion enabled - Decoding/Frame serving: X264/LAVF - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [14:30:25] PHASE ONE, Encoding - [14:30:25] Processing: VID_00000 (1 of 1) - [14:30:25] Extracting A/V streams [VID_00000] - [14:41:10] Reencoding video [VID_00000] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 224.928 frames - Bitrate: 19.450 Kbs - [14:41:10] Reencoding: VID_00000, Pass 1 of 2 - [15:43:21] Reencoding: VID_00000, Pass 2 of 2 - [18:58:35] Video Encode complete - [18:58:35] Processing audio tracks - Track 4352 (ita): Keeping original audio [18:58:35]PHASE ONE complete [18:58:35]PHASE TWO - Rebuild Started - [18:58:35] Rebuilding BD file Structure [19:12:10] - Encode and Rebuild complete - Computer SHUTDOWN initiated. [Status] LABEL=REVENANT VERSION=v0.50.12 SOURCE_SIZE=39926083584 SOURCE_VIDEO_SIZE=39926083584 TARGET_SIZE=25637683200 REDUCTION=.642128676258997 RESIZE_1080=0 RESIZE_1440=0 AUDIO_TO_KEEP=eng;ita; KEEP_HD_AUDIO=-1 SUBS_TO_KEEP= BACKUP_MODE=1 MOVIEONLY_TYPE=0 USE_LAVF=-1 INSTANCES=1 DGDECNV=0 DGDECIM=0 FRIMSOURCE=0 FFMS2=0 SSIF_MODE=0 QUICK=0 ENCODE_STEP=0 COMPLETED=1 REBUILD_COMPLETE=1 [00000] AUDIO=1000 PGS=1100 APULLDOWN=0 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=25637683200 RATE=19450 SPLITS=1 NSIZE=0 FLINK=0 MLINK=0 [05/29/16] Checking System Settings - BD-Rebuilder v0.50.14 - Windows Version: 6.1 [7601] - Working Path Free Space: 11,33GB - AVISYNTH Version: 2.5.8.0, Ok - HAALI Splitter: 1.9.42.1, Ok - FFDSHOW: 4504, Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [05/29/16] Systems Settings Check complete [Options] VERSION=0.50.0.14 ENCODER=0 MODE=3 ENCODE_QUALITY=2 ONEPASS_ENCODING=0 AUTO_QUALITY=0 QUICK_EXTRAS=1 TARGET_SIZE=23500 PRIORITY_CLASS=0 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=all SD_CONVERT=0 OPEN_GOP=0 RESIZE_1080=0 RESIZE_1440=0 RESIZE_720=0 DEINTERLACE=1 SD_TO_1080=0 IGNORE_3D=0 CONVERT_WIDE=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=1 AUDIO_DRC=0 DECODER=0 AVCHD=1 REMOVE_WORKFILES=0 REMOVE_OUTPUT=0 USE_FILTERS=0 BDMV_CERT_ONLY=0 IVTC_PULLDOWN=0 ASSUME_DVD_PAL=0 FRIMSOURCE=0 COMPLETION_BEEP=0 OUTPUT_SBS=0 NEROAAC=0 SUPTITLE=0 PGSTOSRT=0 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=1 CUSTOM_TARGET_SIZE=24500 THANK YOU Last edited by gamete; 29th May 2016 at 17:51. |
29th May 2016, 17:51 | #24255 | Link |
what do you advise ? http://postimg.org/delete/mzwl6sb4w/ disinstall FFDSHOW and install LAV ? OR KEEP only ffdshow and set "use directshowsource for frame serving" ? ps in case FFDSHOW is set correctly? Last edited by gamete; 29th May 2016 at 17:56. |
29th May 2016, 22:31 | #24257 | Link | |
30th May 2016, 13:56 | #24260 | Link | |
2. No. 3. No. Just install it (see the first post of this thread). |
