6th January 2017, 21:48 | #25441 | Link | |
After you select the disc as your source, go to the BATCH tab and right click on it. Select "Add multiple Playlists to Queue" and choose the playlists for each of the episodes. Then just run the batch job. When it's done you will have all 3 or 4 episodes each in a separate MKV file. Repeat for all discs. Last edited by jdobbs; 6th January 2017 at 21:52. |
6th January 2017, 22:48 | #25442 | Link |
MKV Import Issues
I am trying to create a BD with menu from a collection of mkvs and I am having some issues and I am not sure if they are bugs or me not setting things up properly.
1. The files all import OK, the menu shows all the files and allows me to edit the menu titles, however, one of the files is just under 3 mins long but even with both Import time & Menu time set to 1 the BD created includes the option on the menu but the m2ts is not included in the Stream directory. When the menu option is selected nothing happens (no crash). I can copy the m2ts file and associated cli files from the import directories into the BD directories and everything works. 2. In another set of files I have an audio track that imports OK but the timing delay is ignored, so although in sync when playing the mkv it is not in sync in the BD 3. In another set everything is fine except I can't get a required subtitle track to be forced even though it works in the mkv file (I tried both Full Backup & Quick Play) A query, if I import an mkv file (of say 17Gb) and specify a custom target the BD is expanded to be close to this size (importing a BD direct does not do this) so the question is, is this supposed to happen and does it result in a better picture? (I am assuming that the bit rate is increased to cause this) Thank you in advance for any advice. Config ini for Set 3 but apart from the Menu Background I do not change anything Code:
[Options] VERSION=0.50.0.20 ENCODER=0 MODE=2 ENCODE_QUALITY=0 ONEPASS_ENCODING=0 AUTO_QUALITY=1 AUDIO_TO_KEEP=eng;jpn; SUBS_TO_KEEP=eng;jpn; SD_CONVERT=0 OPEN_GOP=0 RESIZE_1080=0 RESIZE_1440=0 RESIZE_720=0 DEINTERLACE=1 SD_TO_1080=0 IGNORE_3D=0 CONVERT_WIDE=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=1 AUDIO_DRC=0 DECODER=0 AVCHD=1 REMOVE_WORKFILES=0 REMOVE_OUTPUT=0 USE_FILTERS=0 BDMV_CERT_ONLY=0 IVTC_PULLDOWN=0 ASSUME_DVD_PAL=1 FRIMSOURCE=0 COMPLETION_BEEP=0 OUTPUT_SBS=0 NEROAAC=1 SUPTITLE=0 PGSTOSRT=0 AUDIO_TRACK_LIMIT=0 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=24400 AUTO_BURN=2 IMPORT_THRESHOLD=1 QUICK_PLAY_THRESHOLD=1 IMPORT_LIMIT_LANG=0 IMPORT_KEEP_PLAYALL=0 MENU_BACKGROUND=F:\Film\Ghost in the Shell Arise\Menu Background.png MENU_AUDIO=E:\Video Utility\BD Rebuilder\tools\blankclip\blank.ac3 MENU_FONT=Arial Rounded MT Bold MENU_AUTO_BACKGROUND=1 MENU_AUTO_DVDAUDIO=0 MENU_PLAY_SEQUENTIAL=0 MENU_START_WITH_MENU=1 MENU_ACTIVE_COLOR=YELLOW MENU_TOP=300 TARGET_SIZE=24400 [Paths] NeroAACPath=E:\Video Utility\EAC3to\neroAacEnc.exe WORKING_PATH=H:\WORKING\ SOURCE_PATH=H:\WORKING\IMPORTS\GHOST_IN_THE_SHELL_ARISE\ |
6th January 2017, 23:26 | #25443 | Link | |
Screens Full mode Movie only |
6th January 2017, 23:52 | #25444 | Link | |
Recoding to a larger size can not, and will not, improve the quality. That is not the way digital works. You can't get something from nothing. If you go back thru the posts, you will find a posting from me describing what it takes to build a Blu-ray from imported MKV files, without any recoding. If I have issues with a video, I do all of my recoding myself. The steps I takes to build a disc, may, or may not, solve your issues. But, it sounds like it won't. |
6th January 2017, 23:55 | #25445 | Link | |
Post your INI config file. |
7th January 2017, 00:11 | #25446 | Link |
You have to select Movie-Only in order to set an ALTERNATE output. That's the only way you can create an MKV. You can then select a playlist one at a time if you want to. But, when you want to do all the episodes at once, you can just go to the Batch tab, right click, and select "Add multiple Playlists to Queue" and select the ones you want to process. That way you can add all the episodes in a single step (they will be processed one-at-a-time automatically).
7th January 2017, 00:14 | #25447 | Link | |
7th January 2017, 00:33 | #25448 | Link | |
That is all my problem, I select Only movie and Bd rebuilder appears that, if I select full movie, appears all three |
7th January 2017, 01:09 | #25449 | Link |
Elit Amans
Have made some more thinking and testing..
multiAVCHD puts a couple of avchd folders on the structure, but AVCHDCoder don't so those are not the issue. The only thing I could think of was the index.bdmv and MovieObject.bdmv and after comparing I definately can see they differ from the BD-RB generated ones. I must say though, that I don't have the knowledge as to what these files really do. Also there is probably more files that come into play, that I don't know of. Anyhow just to test I copied the multiAVCHD ones to the BD-RB discs folder and the result is no more error message on the old Sony. Ofcourse the movie didn't start but hey it's a tiny bit of progress, right? //LD |
7th January 2017, 14:32 | #25451 | Link | |
8th January 2017, 01:17 | #25452 | Link | |
An example, the disc as you know has three episodes and when I right click on BATCH I should see the playlist for each one for each episode (please tell me if I get wrong?) but when click right this appears (only one playlist with almost 3hs So, I honestly do not want to bother you but I have this problem. And I do not know what else to try all I need is to extract each episode |
8th January 2017, 04:19 | #25453 | Link | |
9th January 2017, 13:19 | #25455 | Link | |
9th January 2017, 23:36 | #25457 | Link |
Now you see me 2: audio sync issues
I'm having an audio delay when backing up "Now you see me 2" as alternatate output. Movie is multi-part (00003.mpls) and consists of 3 M2TS files: 1. studio logo clip (23 sec) 00003.m2ts 2. movie (2:09h) 00006.m2ts 3. short clip (1 sec) 00005.m2ts Audio seems to be off exactly by the length of the first file. I also tried to import the original rip and created a quick authored BD which behaves the same. Just wanted to see if a single M2TS has the same issue. If I demux 00003.m2ts manually with TSMuxerGUI there are audio files with 23 sec of silence. Along some screenshots from BD-RB and BDEdit if that helps. It is the German version of that movie. Maybe someone has the same disc... Just doing a BD 25 backup. Curious how that one comes out. Thank you in advance ggtop Last edited by ggtop; 9th January 2017 at 23:42. |
10th January 2017, 10:32 | #25460 | Link |
Just created an MP4 with intact video and AAC from BD-RB processed BD25 output and it has the same ~ 23 sec delay.
Obviously the audio from segment 00003.m2ts is not taken into account on demuxing as I can see/hear that extracted file 00003.track_4352.dts does not contain 23 sec silence in the beginning. ggtop Last edited by ggtop; 10th January 2017 at 10:38. |
