20th February 2011, 00:14 | #11302 | Link | |
One last question; so if I turn on DECOMB filter then it wont affect the original movie which is 1080p. The reason why I am asking is because I have heard people say that if you de-interlace a 1080p video then the quality degrades significantly. thanks |
20th February 2011, 00:50 | #11303 | Link | |
20th February 2011, 06:52 | #11304 | Link |
@jdobbs
Hi! Here's one that will knock your socks off - and I'm pretty sure I know the reason for the anomalous results: Background - The title of the Blu-ray is "Buried", with the ENTIRE movie shot inside a coffin, in which the lead (only) character is being buried alive. I'd guess that the BRIGHTEST lighting in any scene is no greater than 1 to 2 candlepower, including many interspersed moments of total darkness. (I'm guessing that the poor end result is due to the unusual lighting throughout the entire movie). Since I'd been getting extremely good results of late, using settings of "Good" and "CRF" to generate BD9s of movies of over two hours duration and BD5s for those of two hours or less, I thought I'd try this one at BD5 (due to the lack of action, light, and colors) with the same settings. The end result was a full disc of a whopping 1.34Gigs, with heavy duty blocking reminiscent of compressed videos we used to make using the ORIGINAL DivX hack of the MS codec. (I am presently re-doing it, using the "Automatic" setting, which I'm fairly certain will yield good results) This is the full log of "Good" "CRF" version: Code:
----------------------- [18:25:43] BD Rebuilder v0.37.05 (beta) - Source: BURIED - Input BD size: 27.46 GB - Approximate total content: [02:10:57.732] - Target BD size: 4.36 GB - Windows Version: 6.0 [6002] - Quality: Good (Very Fast), CRF - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [18:25:43] PHASE ONE, Encoding - [18:25:43] Extracting A/V streams [VID_00004] - [18:25:45] Reencoding: VID_00004 (1 of 18) - [18:25:45] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 528 frames - [18:25:45] Performing CRF Prediction... - Analyzing 23.77 36.89 34.99 34.06 33.59 [33.37] - [18:26:03] Encoding using constant rate factor. - [18:26:20] Video Encode complete - [18:26:20] Reencoding audio tracks (if req'd) - [18:26:21] Multiplexing M2TS - [18:26:22] Extracting A/V streams [VID_00005] - [18:26:24] Reencoding: VID_00005 (2 of 18) - [18:26:24] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 533 frames - [18:26:24] Performing CRF Prediction... - Analyzing 25.30 37.65 34.17 32.61 31.93 31.65 [31.54] - [18:26:43] Encoding using constant rate factor. - [18:27:00] Video Encode complete - [18:27:00] Reencoding audio tracks (if req'd) - [18:27:01] Multiplexing M2TS - [18:27:02] Extracting A/V streams [VID_00008] - [18:27:07] Reencoding: VID_00008 (3 of 18) - [18:27:07] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 29.970fps, 426 frames - [18:27:07] Performing CRF Prediction... - Analyzing 25.09 37.54 36.99 [36.70] - [18:27:29] Encoding using constant rate factor. - [18:27:55] Video Encode complete - [18:27:55] Reencoding audio tracks (if req'd) - [18:27:56] Multiplexing M2TS - [18:27:57] Extracting A/V streams [VID_00015] - [18:27:57] Reencoding: VID_00015 (4 of 18) - [18:27:57] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 1 frames - Bitrate: 9,777 Kbs - [18:27:57] Reencoding: VID_00015, Pass 1 of 2 - [18:27:59] Reencoding: VID_00015, Pass 2 of 2 - [18:28:01] Video Encode complete - [18:28:01] Reencoding audio tracks (if req'd) - [18:28:01] Multiplexing M2TS - [18:28:02] Extracting A/V streams [VID_00016] - [18:28:03] Reencoding: VID_00016 (5 of 18) - [18:28:03] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 358 frames - [18:28:03] Performing CRF Prediction... - Analyzing 26.53 38.27 30.39 28.73 [28.52] - [18:28:14] Encoding using constant rate factor. - [18:28:25] Video Encode complete - [18:28:25] Reencoding audio tracks (if req'd) - [18:28:26] Multiplexing M2TS - [18:28:27] Extracting A/V streams [VID_00019] - [18:28:30] Reencoding: VID_00019 (6 of 18) - [18:28:30] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 1,503 frames - [18:28:30] Performing CRF Prediction... - Analyzing 26.34 38.17 34.51 32.82 32.16 31.86 [31.75] - [18:28:50] Encoding using constant rate factor. - [18:29:36] Video Encode complete - [18:29:36] Reencoding audio tracks (if req'd) - [18:29:36] Multiplexing M2TS - [18:29:40] Extracting A/V streams [VID_00020] - [18:29:43] Reencoding: VID_00020 (7 of 18) - [18:29:43] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 1,440 frames - [18:29:43] Performing CRF Prediction... - Analyzing 26.33 38.16 34.20 32.58 32.01 [31.82] - [18:29:59] Encoding using constant rate factor. - [18:30:42] Video Encode complete - [18:30:43] Reencoding audio tracks (if req'd) - [18:30:43] Multiplexing M2TS - [18:30:47] Extracting A/V streams [VID_00450] - [18:30:51] Reencoding: VID_00450 (8 of 18) - [18:30:51] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,777 frames - [18:30:51] Performing CRF Prediction... - Analyzing 25.95 37.98 32.78 30.25 29.15 28.77 [28.66] - [18:31:21] Encoding using constant rate factor. - [18:32:50] Video Encode complete - [18:32:50] Reencoding audio tracks (if req'd) - [18:32:52] Multiplexing M2TS - [18:32:54] Extracting A/V streams [VID_00451] - [18:33:01] Reencoding: VID_00451 (9 of 18) - [18:33:01] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 3,289 frames - [18:33:01] Performing CRF Prediction... - Analyzing 25.95 37.98 33.44 32.09 [31.81] - [18:33:19] Encoding using constant rate factor. - [18:35:56] Video Encode complete - [18:35:56] Reencoding audio tracks (if req'd) - [18:36:01] Multiplexing M2TS - [18:36:02] Extracting A/V streams [VID_00452] - [18:36:10] Reencoding: VID_00452 (10 of 18) - [18:36:10] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 3,625 frames - [18:36:10] Performing CRF Prediction... - Analyzing 25.94 37.97 33.22 31.00 30.00 29.55 29.37 [29.29] - [18:36:42] Encoding using constant rate factor. - [18:39:27] Video Encode complete - [18:39:27] Reencoding audio tracks (if req'd) - [18:39:32] Multiplexing M2TS - [18:39:33] Extracting A/V streams [VID_00453] - [18:39:37] Reencoding: VID_00453 (11 of 18) - [18:39:37] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,897 frames - [18:39:37] Performing CRF Prediction... - Analyzing 25.95 37.97 36.84 35.92 35.16 34.56 34.08 33.70 33.42 33.22 33.07 32.98 32.91 [32.86] - [18:40:49] Encoding using constant rate factor. - [18:42:15] Video Encode complete - [18:42:15] Reencoding audio tracks (if req'd) - [18:42:18] Multiplexing M2TS - [18:42:19] Extracting A/V streams [VID_00454] - [18:49:01] Reencoding: VID_00454 (12 of 18) - [18:49:01] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 137,328 frames - [18:49:01] Performing CRF Prediction... - Analyzing 26.25 [38.13] - [18:50:39] Encoding using constant rate factor. - [20:01:08] Video Encode complete - [20:01:08] Reencoding audio tracks (if req'd) - [20:09:08] Multiplexing M2TS - [20:09:28] Extracting A/V streams [VID_00455] - [20:10:03] Reencoding: VID_00455 (13 of 18) - [20:10:03] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 32,343 frames - [20:10:03] Performing CRF Prediction... - Analyzing 26.34 18.17 25.84 25.55 25.39 [25.30] - [20:10:34] Encoding using constant rate factor. - [20:13:46] Video Encode complete - [20:13:46] Reencoding audio tracks (if req'd) - [20:13:46] Multiplexing M2TS - [20:13:48] Extracting A/V streams [VID_00456] - [20:13:51] Reencoding: VID_00456 (14 of 18) - [20:13:51] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,585 frames - [20:13:52] Performing CRF Prediction... - Analyzing 25.95 37.97 35.84 34.42 33.47 32.85 32.45 32.19 32.02 [31.91] - [20:14:38] Encoding using constant rate factor. - [20:15:53] Video Encode complete - [20:15:53] Reencoding audio tracks (if req'd) - [20:15:56] Multiplexing M2TS - [20:15:57] Extracting A/V streams [VID_00457] - [20:15:59] Reencoding: VID_00457 (15 of 18) - [20:15:59] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 769 frames - [20:15:59] Performing CRF Prediction... - Analyzing 24.80 37.40 36.65 36.11 35.74 35.49 35.32 35.21 [35.13] - [20:16:45] Encoding using constant rate factor. - [20:17:22] Video Encode complete - [20:17:22] Reencoding audio tracks (if req'd) - [20:17:23] Multiplexing M2TS - [20:17:24] Extracting A/V streams [VID_00458] - [20:17:30] Reencoding: VID_00458 (16 of 18) - [20:17:30] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 2,881 frames - [20:17:30] Performing CRF Prediction... - Analyzing 25.95 37.97 36.43 35.71 35.40 [35.26] - [20:17:55] Encoding using constant rate factor. - [20:20:14] Video Encode complete - [20:20:14] Reencoding audio tracks (if req'd) - [20:20:18] Multiplexing M2TS - [20:20:19] Extracting A/V streams [VID_00459] - [20:20:21] Reencoding: VID_00459 (17 of 18) - [20:20:21] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,777 frames - [20:20:21] Performing CRF Prediction... - Analyzing 36.00 23.00 16.50 13.25 11.63 10.81 10.41 10.20 10.10 10.05 10.03 [10.01] - [20:20:58] Encoding using constant rate factor. - [20:21:55] Video Encode complete - [20:21:55] Reencoding audio tracks (if req'd) - [20:21:55] Multiplexing M2TS - [20:21:56] Extracting A/V streams [VID_00460] - [20:22:00] Reencoding: VID_00460 (18 of 18) - [20:22:00] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 2,181 frames - [20:22:00] Performing CRF Prediction... - Analyzing 25.18 37.59 32.80 30.27 28.96 28.25 27.87 27.69 [27.61] - [20:22:37] Encoding using constant rate factor. - [20:24:15] Video Encode complete - [20:24:15] Reencoding audio tracks (if req'd) - [20:24:15] Multiplexing M2TS [20:24:16]PHASE ONE complete [20:24:16]PHASE TWO - Rebuild Started - [20:24:16] Rebuilding BD file Structure [20:24:21] - Encode and Rebuild complete [20:24:21]JOB: BURIED finished. Last edited by setarip_old; 20th February 2011 at 06:56. |
20th February 2011, 11:33 | #11305 | Link |
Have you seen this lucky punch for the by far largest segment:
- [18:49:01] Reencoding: VID_00454 (12 of 18) - [18:49:01] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 137,328 frames - [18:49:01] Performing CRF Prediction... - Analyzing 26.25 [38.13] |
20th February 2011, 14:50 | #11306 | Link | |
Bitter Old Geek
[Options] VERSION=0.37.0.3 MODE=1 ENCODE_QUALITY=0 ONEPASS_ENCODING=0 AUTO_QUALITY=1 TARGET_SIZE=8032 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=all SD_CONVERT=0 OPEN_GOP=0 RESIZE_1080=0 DEINTERLACE=0 SD_TO_1080=0 CONVERT_WIDE=0 DTS_REENCODE=1 AC3_REENCODE=1 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=0 AVCHD=0 REMOVE_WORKFILES=0 MOVIE_ONLY_LOOP=1 REMOVE_OUTPUT=0 USE_FILTERS=0 BDMV_CERT_ONLY=0 USE_LAVF=0 IVTC_PULLDOWN=1 ASSUME_DVD_PAL=0 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=1 CUSTOM_TARGET_SIZE=23500 MOVIEONLY_TYPE=2 ALTCRF=20 ALTMETHOD=0 [Paths] SOURCE_PATH=V:\PROCESSED HD\BD1_1080P_BD9\ WORKING_PATH=V:\PROCESSED DVDS\ |
20th February 2011, 14:53 | #11307 | Link | |
I am also reasonably certain that, at our age, there is not much left that jdobbs would say would "knock your socks off"! ( Perhaps a late night visit from Sofia Vergara!! Might ? ) |
20th February 2011, 15:09 | #11308 | Link | |
Bitter Old Geek
08:52:39] BD Rebuilder v0.37.03 (beta) - Source: BD_1_1080P_BD9 - Input BD size: 7.63 GB - Approximate total content: [01:46:07.583] - Windows Version: 6.0 [6002] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: DVD-5, 720x480/576, AC3 Audio - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [08:52:40] PHASE ONE, Encoding - [08:52:40] Extracting A/V streams [VID_00000] - [08:55:56] Reencoding: VID_00000 (1 of 1) - [08:55:56] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 152,669 frames - Bitrate: 5,223 Kbs - [08:55:56] Reencoding: VID_00000 [08:56:06] - Failed video encode, aborted I see I am behind a couple of revisions, so I will download and try again. EDIT- With the newest version, I get the same result. Last edited by larrsz; 20th February 2011 at 15:28. |
20th February 2011, 15:17 | #11309 | Link |
@larrsz;
is there a reason you are not using the latest version, BD Rebuilder v0.37.05? It may not correct your problem but there were some changes in that version related to DVD output. edit: I see you just caught this. |
20th February 2011, 17:14 | #11313 | Link | |
I just loaded your settings in to my INI -- and and got the same "no problem" results. This is now four BD-9 discs that I've converted to DVD-5 (and now DVD-9) that went perfectly. I'm sorry, but I have to mark this one as not repeatable and move on to something else. |
20th February 2011, 17:44 | #11314 | Link | |
Bitter Old Geek
20th February 2011, 17:54 | #11315 | Link |
@jdobbs;
Just curious, but I notice from the BDInfo report of Centurion, which is a uniquely authored Blu-ray in itself, that the original has this for 00004.mpls: Total Video Title Codec Length Movie Size Disc Size Bitrate Bitrate Main Audio Track ----- ------ ------- -------------- -------------- ------- ------- ------------------ 00004.MPLS AVC 1:37:41 0 29,458,776,053 0.00 0.00 DTS-HD Master 7.1 (48kHz/24-bit) And the BD-RB backup has: Total Video Title Codec Length Movie Size Disc Size Bitrate Bitrate Main Audio Track ----- ------ ------- -------------- -------------- ------- ------- ------------------ 00004.MPLS AVC 1:38:23 0 8,446,599,229 0.00 0.00 DD AC3 5.1 640Kbps This full BD9 backup was created with BD-RBV03705, the audio is perfectly in sync from your latest find/fix. I have checked a few others, but BDInfo reports identical movie lengths with the original and the backup. |
20th February 2011, 17:56 | #11316 | Link | |
Aging Video Hobbyist
Are you running Vista or W7--I wonder if it might have something to do with Security Properties. I notice for example if I dl it separately and place HCenc_025.exe into BD's dir and compare these Security Props, they appear different. Dunno nuthin' 'bout these myself, just a puzzlement... Last edited by laserfan; 20th February 2011 at 18:11. |
20th February 2011, 18:13 | #11317 | Link |
Just a thought, but a potential problem, maybe minor, but using a previous BD-RB backup as the source to make another backup could bring about audio distortion problems, since the original audio has been amplified by BD-RB ( Amplify(1.2)). One additional amplification may not create a problem, but any additional ones could!
20th February 2011, 18:37 | #11318 | Link | |
If it's the difference in length that is your concern - my guess would be that on the original the timing in the MPLS didn't include the silent "intro" screen. It is possible for an MPLS to reference start and stop points other than the beginning of the video. Last edited by jdobbs; 20th February 2011 at 18:41. |
20th February 2011, 18:49 | #11320 | Link |
@jdobbs
Regarding my post #11305 ("Buried"): I performed a new conversion from the original Blu-ray disc, this time using "Automatic" setting and BD/DVD9 (rather than BD/DVD5).These settings yielded an excellent 7.6Gb full disc copy, as opposed to the pathetic, blocky 1.34Gb originally created with CRF... |
