31st March 2010, 16:58 | #241 | Link |
BluRip author
maybe an old haali version. The old one has some problems with vc-1 in mkv.
I'm working on advanced options for audio and video streams so you can enter fps etc manually.
BluRip : 1-Click BluRay/m2ts to h264 mkv converter http://code.google.com/p/blurip/ |
31st March 2010, 16:59 | #242 | Link |
BluRip author
I hope next month will need some infos on mkv overhead for different stream types...
1st April 2010, 00:47 | #244 | Link |
To Developer: Error Log (Software said to submit)
[3/31/2010 4:51:09 PM] Getting playlist info...
[3/31/2010 4:51:09 PM] [3/31/2010 4:51:09 PM] Command: G:\blu-ray_rip_utilities\eac3to\eac3to.exe "O:\" [3/31/2010 4:51:10 PM] 1) 00000.mpls, 00000.m2ts, 2:23:16 [3/31/2010 4:51:10 PM] [3/31/2010 4:51:10 PM] - Chapters, 16 chapters [3/31/2010 4:51:10 PM] - h264/AVC, 1080p24 /1.001 (16:9) [3/31/2010 4:51:10 PM] - RAW/PCM, English, multi-channel, 48khz [3/31/2010 4:51:10 PM] - AC3, English, multi-channel, 48khz [3/31/2010 4:51:10 PM] [3/31/2010 4:51:10 PM] Return code: 0 [3/31/2010 4:51:10 PM] Done. [3/31/2010 4:51:10 PM] Getting title info... [3/31/2010 4:51:10 PM] [3/31/2010 4:51:10 PM] Command: G:\blu-ray_rip_utilities\eac3to\eac3to.exe "O:\" 1) [3/31/2010 4:52:17 PM] ------------------------------------------------------------------------------- M2TS, 1 video track, 2 audio tracks, 2 subtitle tracks, 2:23:16, 24p /1.001 [3/31/2010 4:52:17 PM] [3/31/2010 4:52:17 PM] 1: Chapters, 16 chapters [3/31/2010 4:52:17 PM] 2: h264/AVC, 1080p24 /1.001 (16:9) [3/31/2010 4:52:17 PM] 3: RAW/PCM, English, 5.1 channels, 24 bits, 48khz [3/31/2010 4:52:17 PM] 4: AC3 EX, English, 5.1 channels, 640kbps, 48khz, 24ms [3/31/2010 4:52:17 PM] 5: Subtitle (PGS), English [3/31/2010 4:52:17 PM] 6: Subtitle (PGS), English [3/31/2010 4:52:17 PM] [3/31/2010 4:52:17 PM] Return code: 0 [3/31/2010 4:52:17 PM] Done. [3/31/2010 5:04:09 PM] Unknown tracks selected - please report log to developer basically trying to convert a mounted blu-ray iso (already decrypted and all that good stuff). Recieve the above error. Have already transcoded about 10 titles, so i understand the process. PM if you need further info. Also note that the linear pcm track is the one creating the issue. Maybe mkv doesn't support this? When i omit that track it works. |
1st April 2010, 23:12 | #245 | Link |
so I ran some more tests. tried three different source files and on each on got the frame rate error. However it seems specifically related to the autocrop feature. if i run the same process except i check "untouched video no encode" everything runs fine. Also I took a look at the chapter log and it shows an error:
M2TS, 1 video track, 3 audio tracks, 7 subtitle tracks, 2:45:29, 24p /1.001 1: Chapters, 26 chapters 2: h264/AVC, 1080p24 /1.001 (16:9) 3: DTS Master Audio, English, 5.1 channels, 24 bits, 48khz (core: DTS, 5.1 channels, 24 bits, 1509kbps, 48khz) 4: AC3, French, 5.1 channels, 448kbps, 48khz, dialnorm: -27dB 5: AC3, Spanish, 5.1 channels, 448kbps, 48khz, dialnorm: -27dB 6: Subtitle (PGS), English 7: Subtitle (PGS), Spanish 8: Subtitle (PGS), Korean 9: Subtitle (PGS), Chinese 10: Subtitle (PGS), Chinese 11: Subtitle (PGS), Portuguese 12: Subtitle (PGS), French Creating file "C:\Documents and Settings\Coldhammer\Desktop\data\bluRip\0000australia_001_chapter.txt"... [v02] Extracting video track number 2... [a03] Extracting audio track number 3... [s06] Extracting subtitle track number 6... [v02] Muxing video to Matroska... [a03] Creating file "C:\Documents and Settings\Coldhammer\Desktop\data\bluRip\0000australia_003_audio_dtsHD_English.dtshd"... [s06] Creating file "C:\Documents and Settings\Coldhammer\Desktop\data\bluRip\0000australia_006_subtitle_English.sup"... [a03] Writing the destination file failed. <ERROR> Aborted at file position 24906825728. <ERROR> Last edited by coldhammer; 1st April 2010 at 23:19. |
2nd April 2010, 18:35 | #246 | Link | |
BluRip author
The error in log is an eac3to error. Maybe the source file is corrupt or theres not enough space?
2nd April 2010, 20:26 | #247 | Link |
Hey Hawk,
Care to respond to my log about 3 posts above? (I figure you may have assumed it was the same issue as the post 1 above) I'm basically trying to convert a mounted blu-ray iso (already decrypted and all that good stuff) to mkv. I receive the above error. Have already transcoded about 10 titles, i understand the process, so thats not the issue. PM if you need further info. Also note that the raw/pcm track is the one creating the issue. Maybe mkv doesn't support this? When i omit that track it works. |
2nd April 2010, 21:11 | #248 | Link | |
BluRip author
4th April 2010, 20:55 | #250 | Link |
BluRip author
Current svn:
- switched to .NET 2.0 - added advanced options for audio and video tracks - added support for PCM audio tracks Please test & report
6th April 2010, 17:38 | #251 | Link | |
Banned
Are these updates under the v47 download link on your site page? I couldn't find the v49 or v50 program download, only changelogs. |
6th April 2010, 18:08 | #252 | Link |
@_hawk_
You'll miss a lot not using .NET 3.5, it's included with Win 7 and on Vista it takes only a minute or two to install since Vista has 3.0 included and the web installer for the client profile has only to grab very few files since 3.0 and 3.5 is build on top of 2.0. The client profile is a trimmed down version sufficient for this type of application. http://www.microsoft.com/downloads/d...d-8ceba808b28b
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 6th April 2010 at 18:10. |
8th April 2010, 08:16 | #253 | Link | |
BluRip author
8th April 2010, 08:17 | #254 | Link |
BluRip author
It's only in the svn repository. I'll upload a test version the next days
8th April 2010, 16:19 | #255 | Link | |
12th April 2010, 08:58 | #258 | Link |
BluRip author
New testversion:
http://blurip.googlecode.com/files/blurip048_test.zip - advanced options for audio & video streams disable autocrop/set fps & resolution manually set custom output format for audio tracks options to include additionally ac3 tracks - only requires .net 2.0 - updated MediaInfo.dll Pls test & report
12th April 2010, 15:11 | #259 | Link |
@_hawk_
nice additions updated first post with some screenies
StaxRip at Doom9's | StaxRip at Sourceforge [RSS] | StaxRip Donations | TheMTiNFo |
19th April 2010, 14:28 | #260 | Link |
BluRip author
New testversion:
http://blurip.googlecode.com/files/blurip_test.zip - 64-bit support (using avs2yuv) - bitrate calculator for 2-pass profiles Please test & report
blu-ray, blurip, eac3to, ffms2, mkv, mkvtoolnix, x264 |
