Old 5th February 2011, 00:09   #10961  |  Link
jj666
Given both tracks are lossless, can you hear a difference?
The way I'd do it would be to demux both tracks with EAC3TO, demux to .WAVs and waveform compare in Audition to verify either an initial +/- delay and/or cuts necessary to sync.
Cheers,
-jj-
jj666 is offline
Old 5th February 2011, 01:21   #10962  |  Link
rapscallion
NY Frame of Mind
rapscallion's Avatar
Thanks, good suggestion jj.
Difference? I'm not sure, maybe it's just psycological but one track is ~1576 kps, 16 bit, while the other is ~ 3700 kbps, 24 bit. Hard to believe that the first one is truly lossless, but I guess when I demux to wavs I'll see.
I've been playing around with the track sync in VLC and +900 ms puts it just about spot on, even when I slow down playback. But if I can get it exact in Audition, I'll give it a shot.
Edit : pm sent
"Talk to me Goose"
rapscallion is offline
Old 7th February 2011, 12:50   #10963  |  Link
kypec
User of free A/V tools
kypec's Avatar
I usually open both video sources via Avisynth -> StackHorizontal(a,b) and time/scene shifts can be immediately seen. I then cut/append blank frames as necessary while leaving audio track untouched.
kypec is offline
Old 7th February 2011, 23:24   #10964  |  Link
rapscallion
NY Frame of Mind
Thanks, but that's something I don't know how to do.
"Talk to me Goose"
Old 8th February 2011, 07:47   #10965  |  Link
kypec
kypec's Avatar
Well, then it's about time to start learning
  1. Install Avisynth
  2. Download some universal source filter, I'd suggest FFMpegSource
  3. Download AvsPMod or VirtualDub
  4. Open AVS script
    LoadPlugin("path\to\plugins\ffms2.dll")
    a=FFVideoSource("first video.mkv")
    b=FFVideoSource("second video.mkv")
kypec is offline
Old 9th February 2011, 23:07   #10966  |  Link
rapscallion
NY Frame of Mind
I apologize again for the OT of this subject.
Thanks for the info kypec.
Already use #'s 1 & 2.
I've heard of VirtualDub but never used it because it doesn't support *.m2ts video sources, which is the subject of my op.
"Talk to me Goose"
Old 10th February 2011, 01:51   #10967  |  Link
Midzuki
Unavailable
Midzuki's Avatar
I am sure phaeron won't mind if you write a .(M2)TS source plugin
Watches pelcome
Midzuki is offline
Old 10th February 2011, 06:52   #10968  |  Link
kypec
kypec's Avatar
Well, VirtualDub supports AVS scripts, right?
AVS supports FFMS2 plugin, right?
Finally, FFMS2 supports M2TS & TS streams (maybe not frame-accurate when seeking though), or you can try DGDecNV if you have compatible nVidia GPU which is frame-accurate with all supported file formats.
kypec is offline
Old 10th February 2011, 16:27   #10969  |  Link
Weirdo
Eac3to reports: "Haali Matroska Muxer (2010-11-07) is installed, There's a new version (2010-11-21) available". However, I have installed the latest 21/11/2010 version from http://haali.su/mkv/.
Weirdo is offline
Old 12th February 2011, 14:51   #10970  |  Link
jeremy33
Madshi,
Can you add my little GUI eac3to ”GUI to your first post please ?
jeremy33 is offline
Old 14th February 2011, 01:11   #10971  |  Link
afonic
DVD-Guides.com Author
afonic's Avatar
sorry to "hack" this thread, but it is kind of eac3to related.
It reports I have ArcSoft:
[a03] Extracting audio track number 3...
[a03] Decoding with ArcSoft DTS Decoder...
[a03] Encoding AC3 <448kbps> with libAften...
[a03] Creating file "D:\Movies\xxxx\1_3_audio.ac3"...
[a03] The original audio track has a constant bit depth of 24 bits.
Video track 2 contains 141706 frames.
eac3to processing took 11 minutes, 7 seconds.
Done.
And it appears I have. However I didn't install anything from them. Any idea what could have installed it? I have Nero, AnyDVD and DVD Fab from commercial applications.
afonic is offline
Old 16th February 2011, 16:28   #10972  |  Link
Delta2
I don't know if this is a bug of eac3to or not, my current version is 3.17
In some sources I get this error log message :
eac3to v3.17
command line: "C:\eac3to\eac3to.exe" C:\SAMPLE~2\CTU-X2~1.MKV 1:"C:\AAA_TE~1\dolby_ac3_1.ac3" -448 -down6
MKV, 1 video track, 1 audio track, 0:01:05, 24p /1.001
1: h264/AVC, English, 720p24 /1.001
2: AC3, 5.1 channels, 448kbps, 48khz, dialnorm: -27dB, 2ms
This video conversion is not supported. <ERROR>
That's correct because I'm trying to reencode stream nș 1 that eac3to identifies as VIDEO H264, of course that is not supported
The problem is that Mediainfo and MKVToolnix identifies the streams as 1 = audio and 2 = video, i.e., the streams order are different
Here is the log of mkvinfo of that sample movie :
+ EBML head
|+ Doc type: matroska
|+ Doc type version: 1
|+ Doc type read version: 1
+ Segment, size 28039868
|+ Seek head (subentries will be
|+ EbmlVoid (size: 4027)
|+ Segment information
| + Timecode scale: 1000000
| + Muxing application: libebml
| + Writing application: mkvmerg
7 09:35:09
| + Duration: 64.610s (00:01:04.
| + Date: Fri Feb 22 04:21:20 20
| + Segment UID: 0x66 0x07 0x99
7 0xfe 0xd0 0xd0
|+ Segment tracks
| + A track
| + Track number: 1
| + Track UID: 376306038
| + Track type: audio
| + Enabled: 1
| + Default flag: 1
| + Forced flag: 0
| + Lacing flag: 1
| + MinCache: 0
| + Timecode scale: 1
| + Max BlockAddition ID: 0
| + Codec ID: A_AC3
| + Codec decode all: 1
| + Default duration: 32.000ms
| + Language: und
| + Audio track
| + Sampling frequency: 48000
| + Channels: 6
| + A track
| + Track number: 2
| + Track UID: 1
| + Track type: video
| + Enabled: 1
| + Default flag: 1
| + Forced flag: 0
| + Lacing flag: 0
| + MinCache: 1
| + Timecode scale: 1
| + Codec ID: V_MPEG4/ISO/AVC
| + CodecPrivate, length 39 (h.
| + Default duration: 41.708ms
| + Language: eng
| + Video track
| + Pixel width: 1280
| + Pixel height: 720
| + Interlaced: 0
| + Display width: 16
| + Display height: 9
|+ EbmlVoid (size: 1024)
|+ Cluster
Delta2 is offline
Old 16th February 2011, 16:51   #10973  |  Link
nurbs
I guess eac3to always uses the same order (chapter,video,audio,subtitles) regardless of what the track order in the container is. If eac3to lists the audio as track 2 then that's what you'll have to use in your command line.
nurbs is offline
Old 16th February 2011, 16:59   #10974  |  Link
Delta2
but if you make a gui that uses eac3to how do you know the track order, i.e., if there is more than 1 audio type ?
Delta2 is offline
Old 16th February 2011, 17:19   #10975  |  Link
tebasuna51
tebasuna51's Avatar
First run:
eac3to v3.17
and analize the log.
tebasuna51 is offline
Old 18th February 2011, 20:09   #10976  |  Link
sl1pkn07
Pajas Mentales...
same here
[AUR] Vapoursynth Stuff
[AUR] Avisynth Stuff
sl1pkn07 is offline
Old 18th February 2011, 21:14   #10977  |  Link
GRKNGLR
I have same problem too.
GRKNGLR is offline
Old 18th February 2011, 21:57   #10978  |  Link
Midzuki
Unavailable
Midzuki's Avatar
@ madshi (feature request) :
why not make eac3to look for mkvtoolnix in the folders covered by the "PATH" envinronment-variable? In the same way it looks for neroaacenc.exe. I am sure I'm not the only one who uses mmg.exe without the help from an "installer".
Midzuki is offline
Old 19th February 2011, 06:56   #10979  |  Link
ketchup318
extraction problem?
Hi
I'm trying to extract DTS-HD audio from a m2ts file so that I can mux it with my compressed video stream (MKV).
Using MediaInfo, the original m2ts file displays this for audio
Audio #1
Menu ID                          : 1 (0x1)
Format                           : DTS
Format/Info                      : Digital Theater Systems
Format profile                   : MA / Core
Muxing mode                      : Stream extension
Codec ID                         : 134
Duration                         : 50mn 23s
Bit rate mode                    : Variable
Bit rate                         : 3 688 Kbps / 1 510 Kbps
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Side: L R, LFE
Sampling rate                    : 48.0 KHz
Bit depth                        : 24 bits
Compression mode                 : Lossless / Lossy
Language                         : English
But using eac3to, I only get this in my converted file
Audio
Format                           : DTS
Duration                         : 1h 47mn
Bit rate                         : 1 747 Kbps / 1 510 Kbps
Bit depth                        : 24 bits
This is what I input for eac3to. The funny thing is that it doesn't seem to be using the Arcsoft Decoder that I bought with TMT.
eac3to.exe C:\makin.m2ts 2: C:\test.dts
M2TS, 1 video track, 4 audio tracks, 6 subtitle tracks, 0:50:23, 24p /1.001
1: VC-1, 1080p24 /1.001 (16:9)
2: DTS Master Audio, English, 5.1 channels, 24 bits, 48kHz
   (core: DTS, 5.1 channels, 24 bits, 1509kbps, 48kHz)
3: AC3, French, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB
4: AC3, Spanish, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB
5: AC3, Portuguese, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB
6: Subtitle (PGS), English
7: Subtitle (PGS), French
8: Subtitle (PGS), Spanish
a02 Extracting audio track number 2...
a02 Creating file "C:\test.dts"
When I convert it to flac, it says this. It seems like now it's using the decoder.
a02 Decoding with ArcSoft DTS Decoder...
a02 Encoding FLAC with libFlac...
a02 Creating file "test.flac"...
Is it not possible to extract the full DTS-HD track in it's pure form? Is flac the only way to get the lossless track out or is reduced DTS track all I can get? Thanks in advance
ketchup318 is offline
Old 19th February 2011, 11:10   #10980  |  Link
TinTime
If you're demuxing then the decoder won't be used.
As for the bitrate discrepancy, perhaps Mediainfo isn't reporting it correctly. As you know the length and size of your demuxed file you can work out the actual bitrate and check against what Mediainfo says. 1747Kbps sounds very low for a 6 channel, 24 bit lossless track.
EDIT: nurbs beat me to it!
TinTime is offline
eac3to
