6th May 2008, 22:55 | #4661 | Link |
I have spiderman2 bluray with truehd converted to lpcm. It cannot be done without scenarist as of yet. After scenarist builds the file. You can demux the file into elementry streams and rebuild it and the audio is perfect with lpcm no 20% freezeup . However if you choose to demux and remux you need to use the append button as the audio gets split into two wav files.
Also when you import a wav file from eac3to into tsmuxer. Ts muxer says it s applying default channel information while the wav from scenarist doesnt do this so I am guessing that scenarist must add something different to the header. here is the first few lines of the scenarist file opened using XVI32 ( all you have to do is copy the garbled mess below into notepad then save it as a file then open it with xvi32 I think this may have relevant info ) RIFFüñÿWAVEfmt ( þÿ €» / ? € ª 8›qdataÀñÿ Last edited by wildchild22; 6th May 2008 at 23:44. |
6th May 2008, 23:44 | #4662 | Link |
I just demuxed a studio created lpcm track from Underworld. Here is what eac3to said about it:
C:\DVDRips\HD>eac3to.exe Ripped\output.wav The format of the source file could not be detected. This means it's not a WAV. But, TsMuxer recognizes the file as LPCM, and I can remux it back with the video, and it still plays fine on the Popcorn Hour. Can eac3to be made to create the decompressed audio into this format? It could be a new output option like -popcorn? |
7th May 2008, 00:01 | #4664 | Link | |
7th May 2008, 03:08 | #4666 | Link | |
@wildchild22, here you have two links about wav header: http://ccrma.stanford.edu/CCRMA/Cour...ts/WaveFormat/ http://www.lightlink.com/tjweber/StripWav/Canon.html The RIFF ChunkSize must be FileLength - 8 and the Data SubChunkSize can be FileLength - 44, both fields have 4 bytes. How can you hexedit 4 bytes to put a number greater than 2^32 (4 GB)? |
7th May 2008, 03:43 | #4667 | Link |
Here is the first 20mb:
http://hd-r-us.kicks-ass.net/public/output.wav.001 I checked, and this chunk is recognized by TsMuxer. Also, the solution may not involve the WAV container, because it obviously doesn't support file size > 4gb. Last edited by jchappo; 7th May 2008 at 03:53. |
7th May 2008, 03:58 | #4668 | Link |
I am trying to convert - using eac3to - BR Pirates of the Carribean - Deadman's Chest and the resultant mkv video height is about 30% shorter than the source m2ts file. I then demuxed using eac3to and the resultant h264 file matches the source. I then used mkvmerge to convert the h264 file and the resultant mkv video is again about 30% shorter than the source h264 video. Is there an option that I need to use or is this a bug in the mkv code?
zap |
7th May 2008, 05:38 | #4669 | Link | |
Anyway, not sure why it did not affect other mkv videos.
zap |
7th May 2008, 10:13 | #4670 | Link | ||
1: WAV supports >4GB files and eac3to handles them fine. It's just tsremux that doesn't support them! Post a request THERE! 2: eac3to is just fine and no special switches (like -popcorn) are needed! 3: The link to your sample does not work! |
7th May 2008, 13:49 | #4671 | Link |
All I did was slit the file into a 100 meg slice then opened the 100 meg slice with the hex editor and posted the bytes before they were all zero till later on. There is a difference in the first 2 lines so maybe eac3to needs to write the differences into the header.
7th May 2008, 13:50 | #4672 | Link | |
A working link to the lpcm sample please. |
7th May 2008, 13:54 | #4673 | Link |
Hi.
Thanks for a wonderful tool. I have used this tool to rip my BD and HDDVDs. Two days ago, I tried to rip Chris Botti Live with friends, but for some reason, I can't seem to play this after the conversion. I have tried this on 2.44 and 2.45 version. Both of them produces the gap information. I re-ran the same command to produce the new mkv and flac file, however, after I remux them with mkvmergeGui, it doesn't play. I have tried both with and without gap and the results are same. The symtom I have is, the mkvtoolnix remux them fine, but when I tried to play in any player (zoomplayer, mpc, kmp, media portal, and etc), none of them works. They just hangs in the beginning, and nothing happens. I don't see any errors from the eac3to or mkxtoolnix. Oh, here is the command I used. C:\Users\Public\Videos\Recent>eac3to 00000.m2ts 1: v.mkv 3: a.flac M2TS, 1 video track, 3 audio tracks, 1:29:02 1: h264/AVC, 1080i60 /1.001 (16:9) 2: AC3, 2.0 channels, 640kbit/s, 48khz 3: RAW/PCM, 5.1 channels, 24 bits, 96khz 4: AC3, 5.1 channels, 640kbit/s, 48khz [v01] Extracting video track number 1... [a03] Extracting audio track number 3... [a03] Reading RAW/PCM... [a03] Swapping endian... [a03] Remapping channels... [a03] Encoding FLAC... [v01] Muxing video to Matroska... Last edited by tosehee; 7th May 2008 at 13:57. |
7th May 2008, 13:57 | #4674 | Link |
Looks like my own hosting solution didn't work out, try this:
http://www.mediafire.com/?yjjvm0l1zfl Why is everyone hung up on WAV now? I was only using WAV because I thought that was the only way to make it work. What I want is to create the exact format of this studio LPCM, which is recognized by TsMuxer AND plays perfectly on my A/V receiver. >4gb WAV files are recognized by TsMuxer BUT do not play perfectly on my A/V receiver. |
7th May 2008, 14:00 | #4675 | Link |
The only thing that I haven't tried is demux the video as .h264. If I do that, what frame rates do I need to assign when remuxing with mkvmerge?
Is it 30 or is it 60? It's 1080i material.. So, it it 30 then? or is 60 still? |
7th May 2008, 14:07 | #4678 | Link | |
I believe it's a player/decoder issue. Change the video decoder (ffdshow/coreavc/mpc internal decoder) and report back. Try also the .mkv file that eac3to makes (without audio).
From 1st post: Quote:
7th May 2008, 14:11 | #4679 | Link |
Ok here is yet more info,
Looks like if I change the extension to RAW, then eac3to has something to say about it: C:\DVDRips\HD>eac3to.exe Ripped\output.raw This might be a RAW/PCM file. Trying to figure out the details. This will probably take a while. Please be patient... The RAW/PCM file seems to be big endian. The RAW/PCM file seems to have a bitdepth of 16 bits. The RAW/PCM file seems to have 6 channels. RAW/PCM, 5.1 channels, 2:13:48, 16 bits, 48khz I will try converting a DTS-HD track to RAW, and then test is TsMuxer will accept that. |
7th May 2008, 14:15 | #4680 | Link | |
Mind you that I have ripped about 30+ movies so far without this type of issue now. |
eac3to |
