View Poll Results: What version do you prefer? | |||
[+] v0.1 | 1 | 4.17% | |
[+] v0.9 | 0 | 0% | |
[+] v1.0 | 3 | 12.50% | |
[+] v1.9 | 1 | 4.17% | |
[+] v2b1 | 2 | 8.33% | |
[+] v2.0 | 8 | 33.33% | |
[+] v2.1 | 0 | 0% | |
[+] v2.2 | 8 | 33.33% | |
[+] v3.0 | 1 | 4.17% | |
Voters: 24. You may not vote on this poll |
24th February 2012, 16:28 | #21 | Link | |
26th February 2012, 21:36 | #24 | Link |
great skin, using latest dark 2.0, but my playlist does not look like yours, originally the logo did not switch either so i had to force it but i see no option for playlist?
Uploaded with ImageShack.us |
5th March 2012, 14:32 | #26 | Link | |
And for the + tab instead of *new album, it's due to french localization choice, not to the skin. I hope I answer your issue. Last edited by fred_gaou; 5th March 2012 at 14:48. |
5th March 2012, 14:42 | #27 | Link |
thank you, I'll check it this evening
It's great - I changed only few things: - the Close button on the playlist closes the player instead of the playlist - on right click on stop button - rewind - on right click on audio track select - subtitle track select Last edited by pdanpdan; 6th March 2012 at 20:40. |
23rd March 2012, 08:28 | #28 | Link |
Thank you very much for this great skin! I've just discovered it and didn't know a skin could be so powerful/customizable, things like transparency, control via playlist, the different modes etc is all so nice to use. You must have put in a lot of work on this, it should be the default skin.
23rd March 2012, 08:39 | #29 | Link | |
27th March 2012, 22:15 | #32 | Link |
Skin update 2012.03.27
Please download v2.2 again (if you download it before this post), I made some changes:
Skin update 2012.03.27: minor changes ------------------------------------------------------------------------------------------ v2.2 (2012/03/27) ------------------------------------------------------------------------------------------ + buttons are more integrated with skin background (see screenshots below) + change: subtitle button + change: button animation on click improvement + fix: hover on playlist button could be frozen in some cases |
11th May 2012, 00:18 | #33 | Link |
skin update v2.2.1 is available
Skin update 2012.05.11: minor changes ------------------------------------------------------------------------------------------ v2.2.1 (2012/05/11) only for those who experimented problem in audio skin ------------------------------------------------------------------------------------------ + fix: time display in audio skin was limited to 59 min, now limit is 9:59:59 (useful for podcasts) + add tooltip for file infos in skin audio (bit rate, codec, etc). kbps text has been removed because it took too much space and broke display in some cases (aac with variable bit rate) + visual audio synchronization is available in control box to Sub./Synch./right click |
10th October 2012, 05:06 | #37 | Link |
The zip you provide seems to have duplicated files and 7Z hangs trying to unzip. I was able to select individual files so I got it to work. Great SKINS!!
My only question is can you provide details on where to save the skins - ie can I put them in their en folder under skins? And where do I put the fonts for them to work? Thanks again!
BSW |
english, french, potplayer, skin |
