Old 2nd October 2021, 09:41   #21  |  Link
romangal
So, what about VsLGhost? I try it with avisynth 2.6 and it doesnt work unfortunately. As i understand the vapoursynth version requires avisynth+ version only?
romangal is offline   Reply With Quote
Old 2nd October 2021, 09:43   #22  |  Link
Reel.Deel
Yes, VsLGhost uses arrays and requires AviSynth 3.6 or greater to use. You can use the original version if for some reason you do not want to use AVS+, which really there should not be
Reel.Deel is offline   Reply With Quote
Old 3rd October 2021, 03:03   #23  |  Link
romangal
Thanks. Already using version 3.7 . So i need exactly vslghost because of color halos around edges which vslghost can reduce a little. Authentic lghost has luma effect only. But i still cant understand how disable this annoying color widening edges in red blue and green. Fixchromableedingmod, chromashift(sp) doesnt help - the first reduce saturation, the second just shifting resulting huge color edges still exist. Thanks!
Old 3rd October 2021, 06:52   #24  |  Link
Katie Boundary
Katie Boundary's Avatar
If the source was originally some constant frame rate other than 60 hz, you could try Srestore()
I ask unusual questions but always give proper thanks to those who give correct and useful answers.
Katie Boundary is offline   Reply With Quote
ghosting
