Old 3rd August 2020, 13:41   #1001  |  Link
outgoing
SetStream AAAASSSS,0
Audio:
8001 - 801F - Will change audio stream to 1-31
0000 - will not change current audio
Subtitles:
C001 - C007 - Will force/show subtitle stream 1 to 7
8001 - 8007 - Will hide subtitle stream 1 to 7
0000 - will not change subtitle stream
So for Subtitle 2 with audio 3 to show:
SetStream 8003C002,0
For Audio change only: 80010000
Fos Subtitles change only: 0000C001
To force audio track 1 and hide subtitles: 80018001 - if you previously enabled subtitle track 1
When entering these values make sure you're using IMMEDIATE values format for SetStream (program code 51C00001).
etc...
This is correct for hdmv menus but how to proceed for J-BD, as these commands are not valid.
outgoing is offline   Reply With Quote
Old 6th August 2020, 21:55   #1002  |  Link
Ghitulescu
Ghitulescu's Avatar
You can mix java with HDMV but it's not recommended.
You have to use the corresponding java commands instead of the HDMV ones.
Born in the USB (not USA)
Old 7th August 2020, 23:22   #1003  |  Link
outgoing
yes, could you indicate what those commands are so that i can identify them and study whether they are generic to BD-J.
Old 24th August 2020, 01:32   #1004  |  Link
outgoing
Is it possible to create more than one command to associate an audio with a forced subtitle and that through the context menu (not via menu buttons) of the player they can be exchanged between them? I'm talking about the complete structure of a bluray with menu.
For example, if I have a movie with 3 languages:
1-France
2-English
3-Germany
And 5 subtitles (3 full and 2 forced):
1-English (full)
2-Germany (full)
3-France (full)
4-English (forced)
5-Germany (forced)
The parameters of the command to be entered through BDEdit would be:
1st position: 8002C004
2nd position: 8003C005
On the Top Menu through the play button of the player, it starts the movie with the german audio by default and with the forced subtitle nº5 activated. So far it is perfect, but when i switch to the english language via the context menu, it is not associated with the forced subtitle nº4 but still has the forced german subtitle. Someone knows how to set this, i have tried many commands and none have been satisfactory.
Old 25th August 2020, 17:51   #1005  |  Link
pel9
pel9's Avatar
Operand2 of the SetStream sets the IG number and the angle number so you don't put anything there. Also check your audio and PG stream numbers in the PlayList section.
pel9 is offline   Reply With Quote
Old 25th August 2020, 20:51   #1006  |  Link
Ghitulescu
Ghitulescu's Avatar
Forced subtitles are controlled by the player's settings.
Old 25th August 2020, 23:36   #1007  |  Link
outgoing
I thought that these hexadecimal values were equivalent to the positioning of each stream starting with number one. In the playlist the first audio is identified with the value 4352 (0x1100), the second with 4353 (0x1101). The first subtitle its indicator is 4608 (0x1200), the 2nd--> 4609 (0x1201) and so on.
If i understand you correctly, what you are saying is that simply by having the subtitle X forced (with the forced flag) is already activated automatically in the player when from the contextual button the audio X is selected, the player should automatically change to the subtitle of the same language with the forced flag. If this is the case, it does not work in this case with PowerDVD.
Old 31st August 2020, 20:01   #1008  |  Link
outgoing
I see that some blu-ray if you add the typical setstream parameter works as it should but going deeper, in which i have investigated, it turns out that by forcing the x stream when you press the menu play, then as a consequence the top menu buttons associated with the predefined audios do not work as they should. This parameter cannot be implemented from bdedit if the correct functioning of the top menu has not been checked.
Old 5th September 2020, 15:28   #1009  |  Link
LowDead
Elit Amans
anyone else getting:
Not Found
The requested URL was not found on this server.
When trying to download the latest registred version?
//LD
Old 11th September 2020, 11:13   #1010  |  Link
AVX
any update from pel?
AVX is offline   Reply With Quote
Old 11th September 2020, 22:19   #1011  |  Link
LowDead
Elit Amans
yes, got new updated link from pel that worked. So all good now
//LD
Old 12th September 2020, 13:11   #1012  |  Link
AVX
//LD
I sent him a message via email but no answer. Any way of contacting him?
Old 12th September 2020, 16:57   #1013  |  Link
LowDead
Elit Amans
check your inbox
//LD
Old 15th September 2020, 13:36   #1014  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
LowDead, which version is it now ? 0.50?
Old 16th September 2020, 00:17   #1015  |  Link
LowDead
Elit Amans
The one I got linked was 0.50b.
//LD
Old 17th September 2020, 12:22   #1016  |  Link
AVX
Have anyone found a new way to force/disable audios/subtitles by default? The old method does not work for me.
Old 17th September 2020, 19:49   #1017  |  Link
outgoing
Related to a complete bluray structure or just only movie?
Old 17th September 2020, 21:08   #1018  |  Link
AVX
if u are answering to me , i mean for the bluray structure. The setstream method is not working for me idk why.
Old 19th September 2020, 06:29   #1019  |  Link
outgoing
In the hdmv blurays not always that commands works (code), according to the structure that contains and mainly although it works you shold check well your main menu, audio buttons, since they will not work correctly if you have forced an audio/subtitle so that it starts with the play. All this is much more complex than inserting a command with bdedit if you want everything to work properly.
Old 20th September 2020, 13:57   #1020  |  Link
AVX
Thanks for the answer, maybe one day someone will make a guide.
bd menu, bdedit, blu-ray
