20th July 2008, 09:47 | #321 | Link | |
Cheers! |
23rd July 2008, 08:35 | #323 | Link |
AVStoDVD Dev
Available AVStoDVD 2.1.0 Alpha 080722.
Change log (since last Alpha): - Added multiple file selection in 'Add' Common Dialog window - Added autoselect Audio and Subs files if they have same name as Video - Added 'HCenc Advanced Configuration' option (AQ, Lumgain, Matrix, Profile) in 'Title Edit'/'Video' - Added direct access to 'Settings'/'DVD Menu' from DVD Menu Editor (faster way to change settings) - Added 'Default Max Thumbs per Row' option in 'Settings'/'DVD Menu' - Added 'TV Overscan' and 'Center Axis' display in DVD Menu Editor - MediaInfo updated to 0.7.7.4 - BatchMux updated to 1.1 Bye Last edited by MrC; 23rd July 2008 at 10:07. Reason: Forgot BatchMux update |
23rd July 2008, 08:53 | #324 | Link | |
23rd July 2008, 09:22 | #325 | Link | |
AVStoDVD Dev
Bye |
24th July 2008, 19:32 | #328 | Link | |
AVStoDVD Dev
Yes, very next steps will be: a better Editor GUI, locking labels properties (change one -> change all), anchoring labels to thumbs, motion menu (only thumbs). Then: drag&drop, templates saving and text only menus. Bye |
25th July 2008, 21:10 | #330 | Link |
A few more small usability thoughts. Could you add that double clicking on a title opens the edit title options and could the average bitrate for all videos be shown in the status bar (so you can quickly see if you've added too much video data)? Also, can you change the encoding options for all titles at once?
28th July 2008, 14:57 | #331 | Link | |||
AVStoDVD Dev
Bye |
28th July 2008, 19:58 | #332 | Link |
I'm using the latest Noinstall beta, I changed the SubtitleCreator profile xml document in the Subtitlecreator data folder[Font-Tahoma to Verdana, size 18 to 16, bold to regular. I also slightly altered the subtitle position] Unfortunately nothing appears to have changed in the output dvd, the subtitle size seems the same. I have used this method to change the profiles when using FAVC & have had no issues. Do I need to do something else to change the profile when using AVStoDVD. On a more upbeat note thanks for so quickly incorporating the HCenc advanced options into AVStoDVD.
Thanks in advance. |
28th July 2008, 21:18 | #333 | Link | |
AVStoDVD Dev
The only reason that comes to my mind is that there are 8 profiles:
Ah, you did not setup hard-encoded sub, did you? Bye |
29th July 2008, 10:33 | #334 | Link | |
<?xml version="1.0" encoding="utf-16"?> <!--Profiles for SubtitleCreator v2.1.0 RC5 Note: This file exists in two locations: the program's data folder (for first-time users), and in the local Application folder (e.g. C:\Documents and Settings\John Doe\Application Data\SubtitleCreator\), which is used by default.--> <Profiles> <!-- SubtitleCreator profiles are created to easily switch between different movie screen sizes, and are used to store your defaults. You can add as many profiles as you like, but the first one will always be used as the default.--> <Profile Name="AVStoDVD PAL 4:3"> <Font Name="Verdana" Size="20" Style="Regular" Outline="5" /> <Window DistanceToLeftBorder="80" DistanceToTopBorder="450" Width="560" /> <Stretch Horizontal="100" Vertical="100" /> <LineHeight Value="100" /> <Formatting Lines="2" Wrap="True" VerticalAlignment="3" VerticalFont="False" /> </Profile> <Profile Name="AVStoDVD PAL 16:9"> <Font Name="Verdana" Size="16" Style="Regular" Outline="5" /> <Window DistanceToLeftBorder="80" DistanceToTopBorder="440" Width="560" /> <Stretch Horizontal="100" Vertical="100" /> <LineHeight Value="100" /> <Formatting Lines="2" Wrap="True" VerticalAlignment="3" VerticalFont="False" /> </Profile> <Profile Name="AVStoDVD NTSC 4:3"> <Font Name="Verdana" Size="20" Style="Regular" Outline="5" /> <Window DistanceToLeftBorder="80" DistanceToTopBorder="380" Width="560" /> <Stretch Horizontal="100" Vertical="100" /> <LineHeight Value="100" /> <Formatting Lines="2" Wrap="True" VerticalAlignment="3" VerticalFont="False" /> </Profile> <Profile Name="AVStoDVD NTSC 16:9"> <Font Name="Verdana" Size="16" Style="Regular" Outline="5" /> <Window DistanceToLeftBorder="80" DistanceToTopBorder="370" Width="560" /> <Stretch Horizontal="100" Vertical="100" /> <LineHeight Value="100" /> <Formatting Lines="2" Wrap="True" VerticalAlignment="3" VerticalFont="False" /> </Profile> </Profiles> I have just tried another encode & the subs are still the same, they have not changed to my selection(Pal 16:9). Also the subtitle settings I have deleted from the profile are still shown in Sub Creators profile list? On my first attempt I only edited the pal 16:9 full D1 entry, & obviously that didn't work either. Even if I change the 'Distance To Top Border' setting the subs do not move. The settings are the same as I have set in FAVC, but for some reason they appear higher up, more towards the centre of the screen when encoded using AVStoDVD. The subs are selectable not hard encoded. Thanks in advance. Last edited by wg; 29th July 2008 at 10:44. |
29th July 2008, 13:12 | #335 | Link |
AVStoDVD Dev
@wg
please do not alter so much the profiles.xml file that comes with AVStoDVD! You have removed 4 profiles. AVStoDVD needs to have all above 8 profiles when calling SubtitlesCreator. This is the original profiles.xml: Code:
<?xml version="1.0" encoding="utf-16"?> <!--Profiles for SubtitleCreator v2.1.0 RC5 Note: This file exists in two locations: the program's data folder (for first-time users), and in the local Application folder (e.g. C:\Documents and Settings\John Doe\Application Data\SubtitleCreator\), which is used by default.--> <Profiles> <!-- SubtitleCreator profiles are created to easily switch between different movie screen sizes, and are used to store your defaults. You can add as many profiles as you like, but the first one will always be used as the default.--> <Profile Name="AVStoDVD PAL 4:3 Full-D1"> <Font Name="Tahoma" Size="18" Style="Bold" Outline="5" /> <Window DistanceToLeftBorder="80" DistanceToTopBorder="450" Width="560" /> <Stretch Horizontal="100" Vertical="100" /> <LineHeight Value="100" /> <Formatting Lines="2" Wrap="True" VerticalAlignment="3" VerticalFont="False" /> </Profile> <Profile Name="AVStoDVD PAL 4:3 Half-D1"> <Font Name="Tahoma" Size="9" Style="Bold" Outline="5" /> <Window DistanceToLeftBorder="36" DistanceToTopBorder="450" Width="280" /> <Stretch Horizontal="100" Vertical="200" /> <LineHeight Value="100" /> <Formatting Lines="4" Wrap="True" VerticalAlignment="3" VerticalFont="False" /> </Profile> <Profile Name="AVStoDVD PAL 16:9 Full-D1"> <Font Name="Tahoma" Size="18" Style="Bold" Outline="5" /> <Window DistanceToLeftBorder="80" DistanceToTopBorder="430" Width="560" /> <Stretch Horizontal="100" Vertical="125" /> <LineHeight Value="100" /> <Formatting Lines="3" Wrap="True" VerticalAlignment="3" VerticalFont="False" /> </Profile> <Profile Name="AVStoDVD PAL 16:9 Half-D1"> <Font Name="Tahoma" Size="9" Style="Bold" Outline="5" /> <Window DistanceToLeftBorder="36" DistanceToTopBorder="430" Width="280" /> <Stretch Horizontal="100" Vertical="250" /> <LineHeight Value="100" /> <Formatting Lines="5" Wrap="True" VerticalAlignment="3" VerticalFont="False" /> </Profile> <Profile Name="AVStoDVD NTSC 4:3 Full-D1"> <Font Name="Tahoma" Size="18" Style="Bold" Outline="5" /> <Window DistanceToLeftBorder="80" DistanceToTopBorder="370" Width="560" /> <Stretch Horizontal="100" Vertical="100" /> <LineHeight Value="100" /> <Formatting Lines="2" Wrap="True" VerticalAlignment="3" VerticalFont="False" /> </Profile> <Profile Name="AVStoDVD NTSC 4:3 Half-D1"> <Font Name="Tahoma" Size="9" Style="Bold" Outline="5" /> <Window DistanceToLeftBorder="36" DistanceToTopBorder="370" Width="280" /> <Stretch Horizontal="100" Vertical="200" /> <LineHeight Value="100" /> <Formatting Lines="4" Wrap="True" VerticalAlignment="3" VerticalFont="False" /> </Profile> <Profile Name="AVStoDVD NTSC 16:9 Full-D1"> <Font Name="Tahoma" Size="18" Style="Bold" Outline="5" /> <Window DistanceToLeftBorder="80" DistanceToTopBorder="350" Width="560" /> <Stretch Horizontal="100" Vertical="125" /> <LineHeight Value="100" /> <Formatting Lines="3" Wrap="True" VerticalAlignment="3" VerticalFont="False" /> </Profile> <Profile Name="AVStoDVD NTSC 16:9 Half-D1"> <Font Name="Tahoma" Size="9" Style="Bold" Outline="5" /> <Window DistanceToLeftBorder="36" DistanceToTopBorder="350" Width="280" /> <Stretch Horizontal="100" Vertical="250" /> <LineHeight Value="100" /> <Formatting Lines="5" Wrap="True" VerticalAlignment="3" VerticalFont="False" /> </Profile> </Profiles> Code:
<?xml version="1.0" encoding="utf-16"?> <!--Profiles for SubtitleCreator v2.1.0 RC5 Note: This file exists in two locations: the program's data folder (for first-time users), and in the local Application folder (e.g. C:\Documents and Settings\John Doe\Application Data\SubtitleCreator\), which is used by default.--> <Profiles> <!-- SubtitleCreator profiles are created to easily switch between different movie screen sizes, and are used to store your defaults. You can add as many profiles as you like, but the first one will always be used as the default.--> <Profile Name="AVStoDVD PAL 4:3 Full-D1"> <Font Name="Tahoma" Size="18" Style="Bold" Outline="5" /> <Window DistanceToLeftBorder="80" DistanceToTopBorder="450" Width="560" /> <Stretch Horizontal="100" Vertical="100" /> <LineHeight Value="100" /> <Formatting Lines="2" Wrap="True" VerticalAlignment="3" VerticalFont="False" /> </Profile> <Profile Name="AVStoDVD PAL 4:3 Half-D1"> <Font Name="Tahoma" Size="9" Style="Bold" Outline="5" /> <Window DistanceToLeftBorder="36" DistanceToTopBorder="450" Width="280" /> <Stretch Horizontal="100" Vertical="200" /> <LineHeight Value="100" /> <Formatting Lines="4" Wrap="True" VerticalAlignment="3" VerticalFont="False" /> </Profile> <Profile Name="AVStoDVD PAL 16:9 Full-D1"> <Font Name="Times New Roman" Size="10" Style="Bold" Outline="5" /> <Window DistanceToLeftBorder="80" DistanceToTopBorder="430" Width="560" /> <Stretch Horizontal="100" Vertical="125" /> <LineHeight Value="100" /> <Formatting Lines="3" Wrap="True" VerticalAlignment="3" VerticalFont="False" /> </Profile> <Profile Name="AVStoDVD PAL 16:9 Half-D1"> <Font Name="Tahoma" Size="9" Style="Bold" Outline="5" /> <Window DistanceToLeftBorder="36" DistanceToTopBorder="430" Width="280" /> <Stretch Horizontal="100" Vertical="250" /> <LineHeight Value="100" /> <Formatting Lines="5" Wrap="True" VerticalAlignment="3" VerticalFont="False" /> </Profile> <Profile Name="AVStoDVD NTSC 4:3 Full-D1"> <Font Name="Tahoma" Size="18" Style="Bold" Outline="5" /> <Window DistanceToLeftBorder="80" DistanceToTopBorder="370" Width="560" /> <Stretch Horizontal="100" Vertical="100" /> <LineHeight Value="100" /> <Formatting Lines="2" Wrap="True" VerticalAlignment="3" VerticalFont="False" /> </Profile> <Profile Name="AVStoDVD NTSC 4:3 Half-D1"> <Font Name="Tahoma" Size="9" Style="Bold" Outline="5" /> <Window DistanceToLeftBorder="36" DistanceToTopBorder="370" Width="280" /> <Stretch Horizontal="100" Vertical="200" /> <LineHeight Value="100" /> <Formatting Lines="4" Wrap="True" VerticalAlignment="3" VerticalFont="False" /> </Profile> <Profile Name="AVStoDVD NTSC 16:9 Full-D1"> <Font Name="Tahoma" Size="18" Style="Bold" Outline="5" /> <Window DistanceToLeftBorder="80" DistanceToTopBorder="350" Width="560" /> <Stretch Horizontal="100" Vertical="125" /> <LineHeight Value="100" /> <Formatting Lines="3" Wrap="True" VerticalAlignment="3" VerticalFont="False" /> </Profile> <Profile Name="AVStoDVD NTSC 16:9 Half-D1"> <Font Name="Tahoma" Size="9" Style="Bold" Outline="5" /> <Window DistanceToLeftBorder="36" DistanceToTopBorder="350" Width="280" /> <Stretch Horizontal="100" Vertical="250" /> <LineHeight Value="100" /> <Formatting Lines="5" Wrap="True" VerticalAlignment="3" VerticalFont="False" /> </Profile> </Profiles> Let me know Bye |
29th July 2008, 16:54 | #336 | Link | |
<Profile Name="AVStoDVD PAL 16:9 Full-D1"> <Font Name="Verdana" Size="16" Style="Regular" Outline="5" /> <Window DistanceToLeftBorder="80" DistanceToTopBorder="450" Width="560" /> I left every thing else as it was, I edited nothing except that shown. This had no effect on the output it stayed the same, as did the version I last submitted, which also stayed the same. When I edit the xml profile it is having no effect on the output, it is staying the same as it was? Could it somehow be deferring to the default setting? Thanks in advance. |
29th July 2008, 20:08 | #337 | Link |
AVStoDVD Dev
@wg
Check if you have a profile.xml file in your "c:\documents and settings\youruser\Application Data\SubtitleCreator" folder. If you have, that one overrides the profile.xml file in "c:\program files\avstodvd\SubtitleCreator\data", so you have either to delete the first one or to edit it. Btw, to test if changing font settings has effect, use font and size "very" different from the default: Verdana 16pt is not much different from Tahoma 18pt... I have no profile.xml in AppData folder and I tried with Times New Roman 10pt and it works as now as when I implemented subs routine in AVStoDVD. Bye |
29th July 2008, 20:36 | #338 | Link | |
Thanks for the interest MrC |
30th July 2008, 08:16 | #339 | Link | |
AVStoDVD Dev
So please, after cleaning, be sure you do have only the *primary* profiles.xml in "c:\program files\avstodvd\SubtitleCreator\data" and no *secondary*profiles.xml "C:\Documents and Settings\youruser\Local Settings\Application Data\SubtitleCreator" (in previous message I posted the wrong path: there is also "\Local Settings\") Bye |
31st July 2008, 13:18 | #340 | Link | |
