7th March 2010, 23:14 | #7162 | Link | |
7th March 2010, 23:17 | #7163 | Link | |
You may want to open up the audio decoder configuration under FFDSHOW and make sure you have something selected for AC3, True HD, DTS, and LPCM. Last edited by jdobbs; 7th March 2010 at 23:32. |
8th March 2010, 01:01 | #7164 | Link | |
In the interim, I have two quick Qs for you. 1. I put your program in, and I run it from, a different directory from the normal C:\Program Files (I put it under my name in the My Documents folder). Could this be affecting my results? Furthermore, when I remove your program to replace it with new versions you release, I just use the "Delete" command, as "Remove Program" does not appear to be an option. Is this okay.. or should I do something else? 2. I want to preserve the highest fidelity sound possible on the copy. If I am recording to BR25s, which options do I chose under Audio Encoding? Thanks, Richard |
8th March 2010, 01:56 | #7165 | Link | |
2. Just select "Keep HD Audio for BD25 encoding" in the SETUP dialog. For BD-25 it has the highest priority and will override the other settings. |
8th March 2010, 02:38 | #7166 | Link |
Made well but i think i have a problem with codecs: i have installed eac3to decodec pack, surcode and sonic cineplayer decoder. I´ve installed so arcsoft media theatre, quick media player with itunes. I´ve the correct versions avisynth, ffdshow and haali.
My S.O. is windows 7 ultimate and procesor intel quad core. With Vista and the same codecs work perfectly. Thanks!! |
8th March 2010, 03:36 | #7167 | Link |
I've seen this reported before, and the only way around it is to encode the entire disc, but I'm perplexed as to why this error occurs. Log below:
[20:11:34] BD Rebuilder v0.32.07 (beta) - Source: SIN_CITY_D1 - Input BD size: 26.87 GB - Approximate total content: [02:04:03.685] - Target BD size: 22.66 GB - Windows Version: 6.0 [6002] - MOVIE-ONLY mode enabled - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [20:11:36] PHASE ONE, Encoding - [20:11:36] Extracting A/V streams [VID_00614] - Extracting A/V to M2TS [VID_00614] - [20:30:55] ExtractAudioSubs() 00053 1605 - Error in attempt to extract audio/subs. - Muxing time: 19 min 43 sec [20:30:58] - Failed to retrieve audio, aborted I've tried every permutation of audio tracks, just one english, all english, all audio...all with the same results: "error in attempt to extract audio/subs". Jdobbs, any thoughts here? Could this be corrected by changing settings (other than recoding the entire disc)? Or is this a bug? |
8th March 2010, 06:10 | #7168 | Link | |
8th March 2010, 06:22 | #7169 | Link | |
8th March 2010, 06:38 | #7170 | Link |
Having problems with Fast And The Furious and Tokyo Drift:
----------------------- [18:55:15] BD Rebuilder v0.31.07 (beta) - Source: TFATF - Input BD size: 38.43 GB - Approximate total content: [03:42:29.878] - Target BD size: 22.66 GB - Windows Version: 6.1 [7600] - SHUTDOWN at completion enabled - Audio Settings: AC3=1 DTS=0 HD=1 Kbs=640 [18:55:15] PHASE ONE, Encoding - [18:55:15] Extracting A/V streams [VID_00103] - [18:55:16] Reencoding: VID_00103 (1 of 35) - [18:55:19] Extracting A/V streams [VID_00097] - [18:55:20] Reencoding: VID_00097 (2 of 35) - [18:55:24] Extracting A/V streams [VID_00095] - [18:55:25] Reencoding: VID_00095 (3 of 35) - [18:55:29] Extracting A/V streams [VID_00092] - [18:55:30] Reencoding: VID_00092 (4 of 35) - [18:55:34] Extracting A/V streams [VID_00099] - [18:55:35] Reencoding: VID_00099 (5 of 35) - [18:55:40] Extracting A/V streams [VID_00093] - [18:55:40] Reencoding: VID_00093 (6 of 35) - [18:55:46] Extracting A/V streams [VID_00100] - [18:55:47] Reencoding: VID_00100 (7 of 35) - [18:55:52] Extracting A/V streams [VID_00098] - [18:55:53] Reencoding: VID_00098 (8 of 35) - [18:56:00] Extracting A/V streams [VID_00118] - [18:56:02] Reencoding: VID_00118 (9 of 35) - [18:56:10] Extracting A/V streams [VID_00079] - [18:56:11] Reencoding: VID_00079 (10 of 35) - [18:56:19] Extracting A/V streams [VID_00101] - [18:56:21] Reencoding: VID_00101 (11 of 35) - [18:56:32] Extracting A/V streams [VID_00094] - [18:56:34] Reencoding: VID_00094 (12 of 35) - [18:56:48] Extracting A/V streams [VID_00078] - [18:56:50] Reencoding: VID_00078 (13 of 35) - [18:57:15] Extracting A/V streams [VID_00061] - [18:57:18] Reencoding: VID_00061 (14 of 35) - [18:57:47] Extracting A/V streams [VID_00130] - [18:57:50] Reencoding: VID_00130 (15 of 35) - [18:58:12] Extracting A/V streams [VID_00050] - [18:58:15] Reencoding: VID_00050 (16 of 35) - [18:58:48] Extracting A/V streams [VID_00129] - [18:58:51] Reencoding: VID_00129 (17 of 35) - [18:59:11] Extracting A/V streams [VID_00096] - [18:59:14] Reencoding: VID_00096 (18 of 35) - [18:59:34] Extracting A/V streams [VID_00062] - [18:59:38] Reencoding: VID_00062 (19 of 35) - [19:00:14] Extracting A/V streams [VID_00084] - [19:00:19] Reencoding: VID_00084 (20 of 35) - [19:00:42] Extracting A/V streams [VID_00102] - [19:00:46] Reencoding: VID_00102 (21 of 35) - [19:01:10] Extracting A/V streams [VID_00089] - [19:01:14] Reencoding: VID_00089 (22 of 35) - [19:01:50] Extracting A/V streams [VID_00090] - [19:01:56] Reencoding: VID_00090 (23 of 35) - [19:02:46] Extracting A/V streams [VID_00088] - [19:02:52] Reencoding: VID_00088 (24 of 35) - [19:03:26] Extracting A/V streams [VID_00056] - [19:03:32] Reencoding: VID_00056 (25 of 35) - [19:05:32] Extracting A/V streams [VID_00117] - [19:05:38] Reencoding: VID_00117 (26 of 35) - [19:06:19] Extracting A/V streams [VID_00086] - [19:06:27] Reencoding: VID_00086 (27 of 35) - [19:07:24] Extracting A/V streams [VID_00115] - [19:07:30] Reencoding: VID_00115 (28 of 35) - [19:08:08] Extracting A/V streams [VID_00116] - [19:08:14] Reencoding: VID_00116 (29 of 35) - [19:08:58] Extracting A/V streams [VID_00087] - [19:09:06] Reencoding: VID_00087 (30 of 35) - [19:09:54] Extracting A/V streams [VID_00080] - [19:10:29] Reencoding: VID_00080 (31 of 35) - [19:17:52] Extracting A/V streams [VID_00083] - [19:18:27] Reencoding: VID_00083 (32 of 35) - [19:21:21] Extracting A/V streams [VID_00085] - [19:21:57] Reencoding: VID_00085 (33 of 35) - [19:24:59] Extracting A/V streams [VID_00081] - [19:26:15] Reencoding: VID_00081 (34 of 35) - [19:42:24] Extracting A/V streams [VID_00010] - [19:58:40] Reencoding: VID_00010 (35 of 35) - [19:58:40] Reencoding secondary video [TRK_02] - [20:20:37] Reencoding secondary video [TRK_03] - Error in attempt to multiplex: MUX_00010.meta - Can't open file: C:\A BLU RAY ENCODES\WORKFILES\00010.track_6656.DTS [07:50:44] - Failed to build structure, aborted ----------------------- [01:43:34] BD Rebuilder v0.31.07 (beta) - Source: TFATF_TD - Input BD size: 40.81 GB - Approximate total content: [04:28:46.109] - Target BD size: 22.66 GB - Windows Version: 6.1 [7600] - SHUTDOWN at completion enabled - Audio Settings: AC3=1 DTS=0 HD=1 Kbs=640 [01:43:34] PHASE ONE, Encoding - [01:43:34] Extracting A/V streams [VID_00307] - [01:43:35] Reencoding: VID_00307 (1 of 30) - [01:43:39] Extracting A/V streams [VID_00298] - [01:43:40] Reencoding: VID_00298 (2 of 30) - [01:43:48] Extracting A/V streams [VID_00294] - [01:43:49] Reencoding: VID_00294 (3 of 30) - [01:43:58] Extracting A/V streams [VID_00302] - [01:44:01] Reencoding: VID_00302 (4 of 30) - [01:44:12] Extracting A/V streams [VID_00299] - [01:44:14] Reencoding: VID_00299 (5 of 30) - [01:44:25] Extracting A/V streams [VID_00078] - [01:44:27] Reencoding: VID_00078 (6 of 30) - [01:44:52] Extracting A/V streams [VID_00061] - [01:44:55] Reencoding: VID_00061 (7 of 30) - [01:45:24] Extracting A/V streams [VID_00297] - [01:45:26] Reencoding: VID_00297 (8 of 30) - [01:45:44] Extracting A/V streams [VID_00301] - [01:45:47] Reencoding: VID_00301 (9 of 30) - [01:46:04] Extracting A/V streams [VID_00295] - [01:46:07] Reencoding: VID_00295 (10 of 30) - [01:46:25] Extracting A/V streams [VID_00050] - [01:46:28] Reencoding: VID_00050 (11 of 30) - [01:47:01] Extracting A/V streams [VID_00296] - [01:47:04] Reencoding: VID_00296 (12 of 30) - [01:47:22] Extracting A/V streams [VID_00303] - [01:47:25] Reencoding: VID_00303 (13 of 30) - [01:47:44] Extracting A/V streams [VID_00300] - [01:47:47] Reencoding: VID_00300 (14 of 30) - [01:48:07] Extracting A/V streams [VID_00304] - [01:48:10] Reencoding: VID_00304 (15 of 30) - [01:48:30] Extracting A/V streams [VID_00062] - [01:48:34] Reencoding: VID_00062 (16 of 30) - [01:49:11] Extracting A/V streams [VID_00064] - [01:49:15] Reencoding: VID_00064 (17 of 30) - [01:49:59] Extracting A/V streams [VID_00305] - [01:50:04] Reencoding: VID_00305 (18 of 30) - [01:50:38] Extracting A/V streams [VID_00292] - [01:50:43] Reencoding: VID_00292 (19 of 30) - [01:51:17] Extracting A/V streams [VID_00056] - [01:51:22] Reencoding: VID_00056 (20 of 30) - [01:53:21] Extracting A/V streams [VID_00306] - [01:53:27] Reencoding: VID_00306 (21 of 30) - [01:54:09] Extracting A/V streams [VID_00288] - [01:54:15] Reencoding: VID_00288 (22 of 30) - [01:54:59] Extracting A/V streams [VID_00291] - [01:55:08] Reencoding: VID_00291 (23 of 30) - [01:56:05] Extracting A/V streams [VID_00287] - [01:56:16] Reencoding: VID_00287 (24 of 30) - [01:57:28] Extracting A/V streams [VID_00289] - [01:57:40] Reencoding: VID_00289 (25 of 30) - [01:58:57] Extracting A/V streams [VID_00293] - [01:59:12] Reencoding: VID_00293 (26 of 30) - [02:00:44] Extracting A/V streams [VID_00290] - [02:01:01] Reencoding: VID_00290 (27 of 30) - [02:02:40] Extracting A/V streams [VID_00011] - [02:03:37] Reencoding: VID_00011 (28 of 30) - [02:20:03] Extracting A/V streams [VID_00308] - [02:24:07] Reencoding: VID_00308 (29 of 30) - [09:35:24] Extracting A/V streams [VID_00010] - [09:49:29] Reencoding: VID_00010 (30 of 30) - [09:49:29] Reencoding secondary video [TRK_02] - [09:59:35] Reencoding secondary video [TRK_03] - [10:06:08] Reencoding secondary video [TRK_04] - [10:12:42] Reencoding secondary video [TRK_05] - Error in attempt to multiplex: MUX_00010.meta - Can't open file: C:\A BLU RAY ENCODES\WORKFILES\00010.track_6656.DTS [20:04:16] - Failed to build structure, aborted ----------------------- My computer specs: Windows Vista 64bit BD Rebuilder v0.31.07 FFDSHOW rev 2661 Last edited by jdobbs; 8th March 2010 at 15:32. |
8th March 2010, 09:18 | #7172 | Link |
Hi, maybe that a moron question, but, when BD-Rebuilder does the demux process, does it use a built-in demuxer or does it use tsMuxeR?
I ask this because I’ve read many post that state that tsMuxeR has problems demuxing seamless branching movies (overlaps and gaps in the file produced by tsMuxeR on it's own tend to cause out of sync audio), and in the tools folder of BD-Rebuilder I do not see eac3to, which doesn’t have this problems while demuxing. I don’t have any seamless branching movie right now, but maybe someday I’ll get one, and I’d like to know if a full backup could end with these audio out of sync problems, being safer creating a movie only with eac3to and then compress it with BD-Rebuilder. Greetings PS. Thanks jdobbs for this great software that till know, in my first 6 backups, as worked perfectly with 0 errors |
8th March 2010, 13:46 | #7174 | Link |
Thanks jdobbs Fast And The Furious (OK) Bd-25 with settings, full backup, no quicker encode for extras, cfr, ahaha and .iso, and play full perfect in sony . Thanks...BD Rebuilder v0.32.07
8th March 2010, 14:47 | #7175 | Link |
First run with 0.32.07, tried to do a movie-only backup of REC2 (Spanish import):
[15:34:11] BD Rebuilder v0.32.07 (beta) - Source: (BD28)_REC2 - Input BD size: 18,95 GB - Approximate total content: [01:24:14.125] - Target BD size: 23,54 GB - Windows Version: 6.1 [7600] - MOVIE-ONLY mode enabled - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [15:34:12] PHASE ONE, Encoding - [15:34:12] Extracting A/V streams [VID_00000] Code:
03.08.10 [15:40:29] ExtractAudioSubs() 00075 1605 Last edited by colinhunt; 8th March 2010 at 15:05. |
8th March 2010, 15:36 | #7176 | Link | |
8th March 2010, 15:39 | #7177 | Link | |
By the way, the required FFDSHOW version is 3133, and it can be downloaded from the first post of this thread. But I don't think that is related to your problem in any way. Last edited by jdobbs; 8th March 2010 at 15:53. |
8th March 2010, 15:57 | #7178 | Link | |
8th March 2010, 17:21 | #7179 | Link | |
00614.m2ts 00614.track_4113.264 Aud_00614.meta The exact text of the popup error is: BD Rebuilder experienced an error 1605 [10:14:07] ExtractAudioSubs() 00053 1605 None of those file names appear to be extremely lengthy, so I'm still scratching my head over this one. Any other insight here is very welcome. |
8th March 2010, 17:37 | #7180 | Link | |
