Old 11th April 2020, 02:30   #2581  |  Link
kedautinh12
Originally Posted by l33tmeatwad View Post
FFMS2 2.23.1 (w/ FFmpeg 4.2.2)
Static Libs Build (x86 & x64) | Sources
use normally with this ver
Old 11th April 2020, 11:34   #2582  |  Link
gpower2
gMKVExtractGUI author
gpower2's Avatar
Originally Posted by kedautinh12 View Post
same error with StvG ver
video test: https://drive.google.com/file/d/1Gze...ew?usp=sharing
log:
I just provided a build with the latest versions of all dependencies at the time. I haven't tampered with the code in the slightest.
I guess it's a regression bug or something.
However, for .ts files, I recommend using LSMASH source filter, since it seems to be frame accurate instead of FFMS2, at least in my experience.
gpower2 is offline   Reply With Quote
Old 9th May 2020, 09:05   #2583  |  Link
Nik92
I have a captured video in HuffYUV and when I open it using FFmpegSource2 in Avisynth+ some frames are dropped which leads to audio to be out of sync.
No such issue when using AVISource, 319405 frames total, 25 fps:
But with FFmpegSource2 319008 frames total, 397 frames are dropped, 24.969 fps:
Also no dropped frames if I open with FFmpegSource2 the same video but encoded in FFV1.
Is it just me or FFmpegSource2 is not working correctly with HuffYUV?
Nik92 is offline   Reply With Quote
Old 9th May 2020, 10:53   #2584  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Originally Posted by Nik92 View Post
Huffyuv in avi should always work perfectly. Which ffms2 version did you try?
Does the captured file by any chance contain exactly 397 dropped frames?
Old 9th May 2020, 13:43   #2585  |  Link
zorr
My experience with ffmpegsource and dropped frames in Huffyuv clips is that they are skipped (tests done with Vapoursynth's core.ffms2.Source).
VirtualDub however shows them as duplicate frames so what I did was preprocess the video with VirtualDub so that the dropped frames are included as duplicates. It would be nice if there was a more elegant way.
zorr is offline   Reply With Quote
Old 9th May 2020, 23:05   #2586  |  Link
Nik92
I tried with 2.23.1 and the one provided by gpower2 a few posts earlier.
I'm not sure how to get the amount of dropped frames but when capturing I think I remember there was this number (or very close) of inserted frames reported by VirtualDub.
Could you please share what preprocessing was done with VirtualDub?
Old 10th May 2020, 20:44   #2587  |  Link
zorr
Load the video into VirtualDub and set the compression to Huffyuv. Select the "Fast recompress" option at the Video menu. Then save as AVI.
The resulting file no longer has dropped frames (at least VirtualDub cannot find them anymore) and they are replaced as duplicate frames.
Old 10th May 2020, 21:28   #2588  |  Link
videoh
Useful n00b
AVI/VFW is so 90s.
Old 22nd May 2020, 17:35   #2589  |  Link
stranno
I have been using FFMS2 + ProRes for years and everything works fine. But now I have switched to h264/h265 and FFMS2 struggles with the audio. Seeking, using any player (MPC-HC), and trimming, using NVEncc, takes A LOT of time.
Using FFVideoSource alone I have no problems at all, it seeks perfectly fine and it has a top-notch performance. Extracing the audio track and loading it using FFAudioSource also works. But loading the audio track from the MKV makes the decoder to struggle like hell.
I'm using the latest StvG build (from this page of the thread) but I also have tried more builds. Same problems.
Video seems to be fine, its MKV + h264 + AAC LC ADTS.
Any idea?
stranno is offline   Reply With Quote
Old 22nd May 2020, 19:12   #2590  |  Link
Myrsloik
Myrsloik's Avatar
Any idea?
The audio support is bad. If you can tolerate slightly worse performance give bestaudiosource a try. Otherwise keep demuxing...
Old 22nd May 2020, 19:35   #2591  |  Link
stranno
Thank you Myrsloik. It does the job perfectly fine and performance hit is tolerable. Is there room for performance improvements? Are you still working on it? Would indexing allow better performance?
Old 22nd May 2020, 20:47   #2592  |  Link
Myrsloik
Myrsloik's Avatar
1. Nope, the performance basically is what it is. Don't expect it to change at all.
2. Yes.
3. The whole idea is to not index and simply sacrifice a bit of cpu time for linear decoding. If you start indexing you end up with FFMS2.
Old 22nd May 2020, 21:47   #2593  |  Link
stranno
2. Yes.
Again, many thanks. I will stick with bestaudiosource.
Old 24th May 2020, 19:41   #2594  |  Link
wonkey_monkey
Formerly davidh*****
wonkey_monkey's Avatar
As I'm having problems getting DGDecNV to work on my new computer, I'm trying ffmpegsource on a 30Gb blu-ray rip (demuxed .264 file). It works, but it takes forever to open each time (15 minutes or so. It's not re-indexing as far as I can tell; I created the .ffindex file on the command line and its modified date hasn't changed).
Is this just how slow it is with such large files?
Old 24th May 2020, 19:59   #2595  |  Link
stax76
stax76's Avatar
Normally with MKV both ffms2 and l-smash are super fast indexing, staxrip uses LWLibavVideoSource for raw files by default, probably better.
Old 24th May 2020, 20:16   #2596  |  Link
videoh
Useful n00b
Sounds like something is sideways. Shouldn't be like that. Happy to help with DGDecNV if you want to open a new thread or visit my forum. Laptops can be problematic. But MX150 looks like a fine GPU. Let's see if we can sort things out for you.
Old 24th May 2020, 21:52   #2597  |  Link
wonkey_monkey
Thanks - already done, as I guess you know, unless you are somehow GPU-psychic.
As for ffmpegsource, I just tried with a 780Mb .m2ts file. It indexed in 30 seconds or so, and subsequent opens were instant. I'll now try with a 39Gb .m2ts...
Old 24th May 2020, 22:06   #2598  |  Link
videoh
Useful n00b
All seeing, all knowing.
Old 24th May 2020, 23:35   #2599  |  Link
wonkey_monkey
The 39Gb M2TS file took 17 minutes to index the first time, then opened instantly the next time.
I went back to the 30Gb .264 file, renamed the existing index file (created on the command line: 609,535 bytes), and opened the script in VirtualDub. It took nearly 30 minutes, created an index file which is 632,958 bytes, but still didn't open instantly the next time (I let it got for 10 minutes before giving up).
I've now remuxed the .264 into a .ts, and it's working as expected, so I guess it was just something about that .264 file.
Old 25th May 2020, 00:23   #2600  |  Link
videoh
Useful n00b
Sounds very doubtful, especially if it opened fine the first time. Sounds like an index management issue for elementary stream files.
