28th August 2018, 18:16 | #16021 | Link | |
E5 2697 v2 @ 3.0GHz on P9X79 Deluxe 24GB Xeon E5-2680 v2 @ 3.1GHz 16GB Sony Vaio VPC-F13Z1E/B |
28th August 2018, 23:19 | #16023 | Link | |
29th August 2018, 11:12 | #16024 | Link | |
31st August 2018, 17:04 | #16027 | Link | |
I did notice that if I turned off distributed encoding and then back on I will get the error "cannot find F:\Blue". I looked through all the settings and cannot find any such command. I don't know why this is coming up. So I created a file called Blue on my F drive and tried the process again. It opened the file up for each movie waiting to be encoded. Was very odd. Last edited by gabbett1; 31st August 2018 at 17:23. |
4th September 2018, 14:05 | #16029 | Link | |
https://forum.doom9.org/showpost.php...&postcount=951 I'll be testing it shortly. |
4th September 2018, 21:21 | #16030 | Link | |
ByteShare
Z:\>"C:\RipBot\EncodingClient.exe" "Z:\Temp\RipBot264temp\job113\job113_EncodingClient.meta" Z:\>"C:\RipBot\tools\mkvtoolnix\mkvmerge.exe" -o "Z:\MergeAudio&Video\A\Pokémon Movie 12 - Arceus And The Jewel Of Life [BluRay] (LightEssence).mkv" --compression 0:none --title "Pokémon Movie 12 - Arceus And The Jewel Of Life [BluRay] (LightEssence)" --default-duration 0:24000/1001fps "Z:\Temp\RipBot264temp\video.265" mkvmerge v23.0.0 ('The Bride Said No') 32-bit 'Z:\Temp\RipBot264temp\video.265': Using the demultiplexer for the format 'HEVC/h.265'. 'Z:\Temp\RipBot264temp\video.265' track 0: Using the output module for the format 'HEVC/h.265 (unframed)'. The file 'Z:\MergeAudio&Video\A\PokÎmon Movie 12 - Arceus And The Jewel Of Life [BluRay] (LightEssence).mkv' has been opened for writing. 'Z:\Temp\RipBot264temp\video.265' track 0: Extracted the aspect ratio information from the HEVC video data and set the display dimensions to 1920/1080. The cue entries (the index) are being written... Multiplexing took 25 seconds. ------------------------- Elapsed Time: 05h:29m:33s |
5th September 2018, 11:34 | #16031 | Link |
I have an issue when i shut down my computer and Ripbot is running (just idle, minimized in tray). I get an Error Message saying "Connot focus a disabled or invisible Window" and my computer does not shut off. I have to close RipBot by hand and then i can turn off my computer. Any Idea?
6th September 2018, 10:42 | #16036 | Link |
Problem solved. Expect auto-update soon. (tomorrow)
7th September 2018, 02:49 | #16038 | Link |
So, I was using Ripbot (very latest build) yesterday, with approx 20 or so job's in the queue, and it was ticking along quite nicely.
But just now (the next day), I opened Ripbot, and it displayed an error I had never seen before, something like "List index is out of bounds", and there were no job's in the queue, so I re started Ripbot, with the Temp Folder open, and before my very eyes, ALL the job folder's just disappeared, and I've got nothin' !!!! Now I have to do it all again Any clues ?? PS:- I just wanted to add, that the ONLY thing I did differently was that I had Ripbot turn itself off, yesterday. Maybe there's a little glitch with that function as noted by Privateer5000. Last edited by burt123; 7th September 2018 at 03:02. |
7th September 2018, 21:48 | #16039 | Link |
ByteShare
Is there any info I can send that would help explain why sometimes an encode server never starts?
It is listed as idle in the Encoding Client and shows starting in the job chunk list. I haven't seen a reason for it yet |
8th September 2018, 01:58 | #16040 | Link | |
I have had this problem on nearly every job I've done, since the very latest build....it is so annoying that you go away from the pc, expecting it to just carry on, and you return, only to notice it hasn't done anything for, some times hours, just because one chunk / server has either failed to start, or "freeze's" just at the end, like 99.8%. It used to happen randomly on earlier builds, but was never diagnosed to discover what was really causing it, so no fix was made. If there was some way Atak could come up with a process that "scan's" all the servers / chunks every so often, can detect if one or more has stalled, or failed to start, and refresh's them and they start the next available server. I had a couple of instance's yesterday (after losing the whole queue), that a server would fail to start, so you'd try and stop it, but that didn't work, you could press the Stop button all day, it would not respond, so the only way was to force Ripbot to close, and a few times even a reboot was required to reset everything. And another thing, ABORT is a bit hit & miss, sometimes it will, but for me, most times it won't. Use to work every time, when it was a part of the "chunk's" DE screen. I was really hoping that the last "BIG" auto update with Avisynth & ffmpeg updates may have fixed the problem, but it actually seems worse Are you using Numa Nodes ??? So, Atak, please don't take this the wrong way, we are trying to explain what some major problems are, and we're more than happy to help, where possible. Trying to help make Ripbot better, and better |
