12th February 2018, 14:53 | #5043 | Link |
Did it, default settings. Same problem.
It's strange because with windows media player classic I have same problem. No problem with vlc. Note that if I open the singles vob file I can jump to any point of video so no problem.
Intel i5-4590 - MSI R9 270X 2GB - 8GB RAM Last edited by steakhutzeee; 12th February 2018 at 14:55. |
12th February 2018, 17:13 | #5044 | Link |
not "windows media player classic" -> Windows Media Player
VLC has its own codecs built in which work or not, you cannot do anything if it doesn't work. 1.) Now MPC-BE is reset to default, take a look at external filters, are the filters now also in the list? 2.) Rightclick on videoframe when you play the DVD -> Filter -> Screenshot needed 3.) Be sure that all internal Filters in MPC-BE are enabled/checked. 4.) What OS are you using? -> like Windows 7 , 8.1, 10 5.) What MPC-BE version are you using? 6.) What LAV Filters version are you using? I need all six points, otherwise I can not help you. |
12th February 2018, 18:12 | #5045 | Link | |
1. MPC BE reset to default, No external filter is listed. 2. [SPOILER] [/SPOILER] 3. All internal filters enabled/checked. 4. Windows 7 x64. 5. MPC BE 1.5.1 build 2985, not updated if there's new one because I have internet problems at home these days. 6. Lav 0.70.2, but they are disabled now because I reset MPC BE.
Intel i5-4590 - MSI R9 270X 2GB - 8GB RAM Last edited by steakhutzeee; 12th February 2018 at 18:16. |
12th February 2018, 18:31 | #5046 | Link |
If there is a problem, first update to latest build and check if it is already fixed in the new version.
Nightlies -> https://yadi.sk/d/hlf1lfC8mKU58 You can also download the installer/zip folder on your mobile phone and copy the installer/zip folder onto your computer, because you mentioned internet problems. |
12th February 2018, 19:34 | #5047 | Link |
I have some questions regarding it:
1. Is it possible to load separate audio and video streams via remote control (web interface)? 2. Can the remote control (web interface) be polled for status fast enough to make player sync possible with decent results? |
12th February 2018, 19:40 | #5048 | Link | |
Why this not updated to the last (it is?) 3391? EDIT: I think i was connected to the repo on sourceforge where last version is the one i downloaded. Unistalled completely mpc be and downloaded last 1.5.2.3991 from your link. Nothing. Problem persists.
Intel i5-4590 - MSI R9 270X 2GB - 8GB RAM Last edited by steakhutzeee; 12th February 2018 at 19:48. |
13th February 2018, 01:06 | #5050 | Link | |
With single vobs I can jump in the file without problems.
Intel i5-4590 - MSI R9 270X 2GB - 8GB RAM |
13th February 2018, 05:52 | #5051 | Link |
@steakhutzeee
Please repeat briefly: 1. What DVD is the problem? 2. What is the problem? 3. If you can reproduce the problem in MPC-HC and Windows Media Player?
13th February 2018, 15:34 | #5052 | Link | |
2. Can't use the seekbar to jump at a point of the movie, back and forth. 3. Yes, only vlc runs without problems.
14th February 2018, 17:52 | #5053 | Link |
So for some DVDs you can seek like you want? I remember that there are methods of DVD authoring which blocks the seek command. The creator of the dvd(s) does not want you to do this.
There is nothing you can do except ripping the disc and play that. |
15th February 2018, 10:31 | #5054 | Link |
Hi there,
I was just informed that MPC-HC's development has ended, and I should try MPC-BE. So here I am, and I'm just writing down some stuff that I miss from MPC-HC (maybe they are in the settings and I'm the one who can't find it ): 1. Auto subtitle downloading: In MPC-HC it has a system, and I love it. Basically you can set it to auto-download the correct subtitle in the preferred language right when you open the video file. You have to do nothing in order to have a subtitle. Looks like in MPC-BE you have to hit D and manually select it. Here comes the second problem: MPC-BE only uses Opensubtitles, which is not so great for TV shows. MPC-HC also has Podnapisi and SubDB. It always (well, 99.99% of the time) finds the correct subtitle. MPC-BE with only Opensubtitles does not. Third problem: I can't select the preferred language in subtitle downloading window. Looks like the english (or preferred?) one gets to the top, but the rest is still unnecessary. So what's missing is: a) auto-download b) more database source c) language filter 2. How can I turn on the full OSD? What I mean is, when I jump backward/forward with the left/right arrow, I don't see the time mark in the top left corner. 3. How can I set it to exit after a video was finished playing? Can't find this option. If I'm finished with a video, I don't want to stare at a black screen/window. Last edited by tonyrulez; 15th February 2018 at 10:32. Reason: bb code change |
16th February 2018, 04:33 | #5055 | Link |
tonyrulez
1. I do not remember that this ever worked well in MPC-HC. Every time when I tried to just get a list of subtitles, I was getting nonsense. Not planned. 2. See options "Show OSD", "Show seek time" in "Player" setting page. 3.See option "Exit fullscreen at the end of playback" in "Fullscreen" setting page. See "Play->After playback->Exit" in menu.
16th February 2018, 08:19 | #5056 | Link |
Thank you! I totally skipped these settings.
As for the subtitles in MPC-HC, it works for me and worked for the last year. List also shows the subtitles all right, see attached sample: https://p1.picsto.re/w9OT1.png. An auto-download would be great nonetheless, based on the release group. |
