3rd February 2020, 01:28 | #58481 | Link |
Guess I should just turn off my OLED and wait for some future technology to come out so I can watch movies and TV again. LMAO As I've said before, once your future tech is ready to be purchased and bugs worked out (i.e. NOT first gen tech), I'll be ready to replace my OLED. Those of us coming from plasma already know the "rules" so it's not exactly difficult.
3rd February 2020, 06:52 | #58482 | Link | |
Spotting an OLED apart from any other screen is typically child's play and the reason being that just look that much better than most other screens available. I never once regretted any of my plasmas (owned about four of five models over the years) and I'm very much enjoying the crazy clarity of my OLED. |
3rd February 2020, 08:59 | #58483 | Link | |
but where found display's actual peak brightness ? I specify 100nits for my non-hdr screen (samsung ue50h6400). it's correct ? |
3rd February 2020, 11:41 | #58485 | Link |
I use Kodi Dsplayer with MadVR and I am very happy with it!
There is just one thing that bugs me and that is that I can't get MadVR to use "NV, HDR, 10bit" - it always uses "NV, HDR, 8bit" (the TV switches to HDR10 though according to the onscreen overlay on my Samsung QE65Q9FNATXZG). HDR pass-through is enabled inside MadVR and the native color depth of the TV is set to "10bit or higher" in MadVR. https://i.imgur.com/iUzP966.jpg If I enabled HDR inside windows 10 then mad VR uses "OS HDR 12 bit" GPU is an RTX 2060, Windows 10 64bit pro. What am I doing wrong? Last edited by solidservo; 3rd February 2020 at 12:56. |
3rd February 2020, 12:25 | #58486 | Link |
"What am I doing wrong?"
Well not using search , but the gist is its fine at 8 bit due to madVRs dithering. There are a million threads on this thread about it.
Windows 10-1909 | i5-3570k | GTX 1070 Windforce OC Rev2 8GB : 430.64 | Pioneer VSX-534 | Philips 65PUS6703 - 65" |
3rd February 2020, 12:26 | #58487 | Link |
Hi, yeah KODI Ds is fantastic isnt it.
The answer for this is probably better coming from an NVIDIA user, there are some issues with driver versions and the ability to select bit rates and create custom resolutions. However, many people on here would just say dont bother mate leave it, 8bit dithered is indisinguishable from 10bit, you're not missing anything really, just enjoy your movie and forget about it
3rd February 2020, 12:32 | #58488 | Link | ||||
Is it without flaws? No, unfortunately (but which one was in the history of displays?): - mainly the uniformity issues are the problem (possible tinting, near black jail bars), if you are unlucky - but ABL is and (I think) will be there on every set in the future as well - burn-in is definitely not an issue if you use it as a TV (tv shows, movies) As @SamuriHL said, new technologies also will need time to get mature, and only that time we will see whether they're good enough compared to Oleds! One thing is for sure: this is the best display tech so far for TV usage. And who knows, maybe it will always be? The sharpness, hence the resulting contrast, that individual pixels can achieve is unbeatable. That's the best thing for me, not the perfect black.
3rd February 2020, 12:53 | #58489 | Link | |
In the threads I found madshi talked about MadVR using a "hidden nvidia API" to switch the output from 8bit to 10bit when HDR content is played. To me that sounded like in my case it should be possible to get "NV, HDR, 10bit" when I play 23/24Hz content. I can select 10bit inside the nvcpl for 4k@23/24/30hz, but as soon as MadVR starts the playback it seems to do a resolution/color depth switch and then it uses 8bit. |
3rd February 2020, 18:46 | #58491 | Link | |
3rd February 2020, 22:03 | #58492 | Link | |
It won't work, it won't do it: for RGB, for YCbCr yes it is possible using Nvapi. This is how I did for my Kodi fork: https://github.com/fandangos/Kodi-HD...8d71c44349R491 But that's not what I came here to ask. Today I own a 1080Ti, does the 2080Ti offers any improvements on what can be used with Madvr? I only have problems if everything is set to very high, even luma quadrupling. So I just wanted to check if anyone with a 2080Ti could tell if there's any change. And of course I won't buy a 2080Ti just for Madvr, gaming in 4k would be the reason to. |
4th February 2020, 00:57 | #58493 | Link |
someone will have one but they may not have come from a 1080, the usual rule of thumb is to look at the gaming performance of the card, the percentage gap should give you a rough idea how much more you'll get from it in MADVR, hopefully someone will be able to give you a better answer.
Hope you're feeling better by the way
4th February 2020, 14:35 | #58495 | Link |
New Monitor
Hello Doom9 Forum
I need your help. Can you clever people anwser this question: I want to buy a new monitor. In the near future i want to start photography and start searching. Monitors like the Eizo CS2420 ColorEdge got great Picture Quality but is it fast enough for madvr? Any other displays you can recommend? Thank you all. @madvr: I really love Madvr. Fantastic job. |
4th February 2020, 16:08 | #58496 | Link |
what do you mean by fast enough?, response times are irrelevant for MADVR and MADVR refresh rate matches, sure this monitor will both 23,976 and 60hz.
4th February 2020, 16:57 | #58497 | Link |
professional devices can be to slow for proper motion displaying.
the device in his question has at least 15 ms gtg response times on paper can nearly for sure not do 23p naively so yes i would avoid this one for madVR. |
4th February 2020, 18:05 | #58500 | Link |
Soul Seeker
I'm experiencing delayed frames with image doubling NGU Sharp High on 1.78:1 tv shows and movies. Monitor resolution is 3440x1440p card is gtx 1050 ti. Is it possible that NGU Sharp High is pushing my card to the limit? Rendering times are ~26-28 ms.
