4th July 2010, 18:09 | #8701 | Link | |
@Kakashi Sensei;
I'm not sure if this is your problem, but fixing this will not hurt! EDIT: Looks like you corrected it now! Last edited by Capsbackup; 4th July 2010 at 18:11. |
4th July 2010, 19:29 | #8702 | Link |
Thanks Caps yeah i noticed it. I'm going to see if it happens in High Speed encode, if I get the same resault as i did in Default 2 Pass i'm going to re-install windows.
Thanks EDIT: Reinstall of the recommended FFDShow worked. Must have have been currupted or gone bad or something. Yeah! no more problems and no out of sync with the finished BD-25 Last edited by Kakashi Sensei; 5th July 2010 at 00:00. |
5th July 2010, 08:31 | #8704 | Link |
x264 only working with 1 core
I have a quad core desktop running XP. I have noticed that when running BD_rebuilder, x264.exe runs only on CPU 0 unless I manually go into task manager and set the affinity to all 4 CPU.
I did some research and found similar issues in programs that are launced by explorer if explorer only has affinity set to CPU 0. I checked the affinity for BD_Rebuilder and it was also set to CPU 0 only. When I set the affinity for BD_rebuilder to all 4 CPU and launched a job I noticed that x264.exe was running on all 4 CPU. For now, my work around is to set the affinity every time I launch BD_Rebuilder. Any thought on how to change this behavior? Thanks! PD |
6th July 2010, 04:14 | #8705 | Link | |
Be sure you are encoding to an NTFS partition and NOT a FAT32. RCF |
6th July 2010, 11:39 | #8706 | Link |
Like to say thanks for another GREAT program from jdobbs and another donation on its way soon
My bug report (only one in many BD's re-encoded) is Monsters vs. Aliens, Region B, Full disc, keep all English audio, keep HD audio, keep all subs, BD25, auto settings, on Windows7 64bit, all software installed from first post... The PIP audio track is way out of sync from start to end, everything else seems great. i noticed this has been reported back on page 386 by Moviewatcher666 (took me days to read the whole thread) and know the rules, i'm not pussing the matter just a heads up incase its slipped and been missed. Anyways thanks for the great app and everyone keep up the great work |
6th July 2010, 15:18 | #8707 | Link |
Deinterlacing Question..
1080i video plays very smoothly im guessing because its 60 fields per second or because of the deinterlacer, I understand that when reencoding to 1080p you only have 30 frames per second to work with so some of the fluidity is lost but is there not a way of preserving this when encoding 1080i to 720p since its 60fps. When watching my 720p encodes (from 1080i source) they look like 30fps and not 60.
Anyway around this? Does the decomb option help with this... i know I could just try its just my PC take a hell of a long time to do encodes so if anyone has any experience I would be grateful Thanks |
7th July 2010, 09:49 | #8708 | Link | |
Programmer
I will have to try the set affinity tomorrow. |
7th July 2010, 13:21 | #8709 | Link |
Has anyone else experienced this, I checked to resize to 720p from a 1080i source, I also turned on "decomb" as well... the resulting file was stretched out to be twice as long as it should have been (slow motion) and had no sound. Does BD rebuilder always use decomb when resizing interlaced material to 720p? Have I screwed it up by selecting both options...
7th July 2010, 14:35 | #8710 | Link |
I'm having a dickens of a time with one disc I'm trying to rebuild. It's Disc 2 of "Monty Python: Almost the Truth". Disc 1 went well and I had no problems. Now, with disc 2, I'm having wavi.exe crash on me. Sometimes it completes, sometimes it get's to about 48-53% and errors out.
Most of the audio on it is LPCM stereo, with only the main two streams having both LPCM and multi-channel AC3. Not sure if that really means anything, but I thought I'd add it in. I'm trying to make a DB-9 backup as I don't have any Blu-Ray discs, and it's an episodic type disc, so movie only is a moot point to me. Not sure what is needed, so I'm adding a few of the logs that I have, if you need more information, please ask and I'll get you what I can. This is from the actual Windows crash log. Problem signature: Problem Event Name: APPCRASH Application Name: wavi.exe Application Version: 0.0.0.0 Application Timestamp: 46c49fdf Fault Module Name: StackHash_c3ce Fault Module Version: 6.1.7600.16559 Fault Module Timestamp: 4ba9b29c Exception Code: c0000374 Exception Offset: 000cdc9b OS Version: 6.1.7600.2.0.0.256.1 Locale ID: 1033 Additional Information 1: c3ce Additional Information 2: c3cea82f1c070d133e9b374c05e90329 Additional Information 3: 6551 Additional Information 4: 655199149e619f35f4b6169c45d6451d From Inspect.exe - Windows Version: 6.1 [7600] - AVISYNTH Version: 2.5.8.0, Ok - HAALI Splitter: Ok - FFDSHOW: 3326, Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libmpeg2": Ok - FFDSHOW AVC set to "libavcodec": Ok - BD Rebuilder v0.34.0.2, Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok The BD-REBUILDER.LOG ----------------------- [08:20:03] BD Rebuilder v0.34.02 (beta) - Source: MONTY_PYTHON_D2 - Input BD size: 42.67 GB - Approximate total content: [04:05:22.274] - Target BD size: 7.72 GB - Windows Version: 6.1 [7600] - Auto Quality: High Quality (Default), Two Pass - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [08:20:05] PHASE ONE, Encoding - [08:20:05] Extracting A/V streams [VID_00075] - [08:20:05] Reencoding: VID_00075 (1 of 40) - [08:20:05] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29.970fps, 98 frames - Bitrate: 337 Kbs - [08:20:05] Reencoding: VID_00075, Pass 1 of 2 - [08:20:09] Reencoding: VID_00075, Pass 2 of 2 - [08:20:13] Video Encode complete - [08:20:13] Reencoding audio tracks (if req'd) - [08:20:57] Multiplexing M2TS - [08:20:57] Extracting A/V streams [VID_00076] - [08:20:58] Reencoding: VID_00076 (2 of 40) - [08:20:58] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29.970fps, 98 frames - Bitrate: 348 Kbs - [08:20:58] Reencoding: VID_00076, Pass 1 of 2 - [08:21:02] Reencoding: VID_00076, Pass 2 of 2 - [08:21:06] Video Encode complete - [08:21:06] Reencoding audio tracks (if req'd) [08:21:12]PHASE ONE aborted by user request From the MONTY_PYTHON_D2.INF [Status] LABEL=MONTY_PYTHON_D2 VERSION=v0.34.02 (beta) SOURCE_SIZE=45813369860 SOURCE_VIDEO_SIZE=45787686912 TARGET_SIZE=8294236160 REDUCTION=.180584645559656 RESIZE_1080=0 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=all BACKUP_MODE=0 MOVIEONLY_TYPE=0 QUICK=1 ENCODE_STEP=3 COMPLETED=1 REBUILD_COMPLETE=0 [00075] AUDIO=1 PGS=11111111 M2TS_TARGET=271830 RATE=337 NSIZE=325632 FLINK=0 MLINK=0 [00076] AUDIO=1 PGS=11111111 M2TS_TARGET=276267 RATE=348 System Specs CPU: Intel Core2Extreme @ 2.66GHz Board: MSI 975X Platinum Memory: 4 GB Kingston @ 800MHz Windows 7 Ultimate x64 Again, I rebuilt disc 1 with no problems, and I've done other discs as well (both movie only and BD-9) before and after trying this disc. So that's why I'm leaning towards something in the disc makeup. Any help IS appreciated. Again if you need to know anything else, please let me know. |
7th July 2010, 17:48 | #8712 | Link | |
8th July 2010, 15:48 | #8713 | Link | |
8th July 2010, 15:50 | #8714 | Link | |
THREADS=n n represents the number of threads to use in X264, default is "auto" |
8th July 2010, 15:55 | #8715 | Link | |
8th July 2010, 15:57 | #8716 | Link | |
8th July 2010, 17:19 | #8717 | Link |
BD Rebuilder v0.34.03 (beta)
I have updated the first post of this thread with a link to the most recent release of BD-RB (v0.34.03). Changes for this version:
- Increased the default output size for BD-5 and BD-9 encodes to use more of the available disc space. - Added an AVS filter editor to the SETUP dialog. This will allow you to add AVS filters to files. Note that bug reports WILL NOT BE ACCEPTED when filters are in use (as errors are almost always caused by the filter usage). You can add "E:", "F:", "I:", or "P:" as a prefix to a line added in the filter editor. The prefixes represent "Extras", "Feature", "Interlaced", and "Progressive" respectively. When specified, the prefix will limit that filter to usage only when the source to be encoded matches the prefix. For example, if specifying "E:filter1()" the filter "filter1()" would only be applied to segments that are determined to be extras. Setting "e:i:filter2()" limits use of "filter2()" to segments that are extras -- and are also interlaced. - Added an additional priority choice. You can now set to HIGH priority as well as NORMAL and IDLE. It is still recommended to use IDLE, however, as it will best share the app with others running, but will still max out processors on a machine when CPU is available. - Added open GOP encoding as the default. This option can be selected or deselected from the SETUP dialog. Open GOPs can noticably improve picture quality for blu-ray due to GOP size restrictions. - Removed COLOR_BOOST from the SETUP dialog. This option is rarely used or needed. It still exists as a hidden option (see HIDDENOPTS.TXT). - Updated the included version of X264.EXE to the latest release (r1666). - Other minor corrections and cosmetic fixes. |
8th July 2010, 19:21 | #8718 | Link |
@jdobbs
Hi, I installed this latest version, but when you run the INSPECT, gives me the following report - Windows Version: 6.0 [6001] - AVISYNTH Version: 2.5.7.0, Ok - HAALI Splitter: Ok - FFDSHOW: 3326, Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libmpeg2": Ok - FFDSHOW AVC set to "libavcodec": Ok - BD-RB v0.34.0.3, not current What's wrong with my computer? Thanks. |
8th July 2010, 19:28 | #8719 | Link | |
8th July 2010, 19:29 | #8720 | Link |
@jdobbs
Something has gone wrong with the new version. I've just replaced .02 and when I tried a disk which was still on my HDD from a previous encode, it immediately gives ' - Error in attempt to extract audio/subs' Just tried another disc I encoded this morning with .02 and it also does the same. |
