Old 12th April 2015, 14:19   #101  |  Link
Reel.Deel
Originally Posted by kotuwa View Post
What is the difference between putting two functions in two lines vs in one line with a period/dot (.)
Performance-wise differences,
And differences in Qulaity and Lossyness...
There should be no difference. It's just 2 different ways of achieving the same thing.
Reel.Deel is offline   Reply With Quote
Old 12th April 2015, 16:26   #102  |  Link
creaothceann
The first version is the short form of
last = Crop(last, 0, 10, 0, -10)
last = Spline64Resize(last, 1280, 720)
...and the second version is the short form of
last = Spline64Resize(Crop(last, 0, 10, 0, -10), 1280, 720)
The difference is that in the second version, the implied (hidden) variable "last" is not modified between the lines. Consider this example:
Version
PointResize(Width * 2, Height * 2)
PointResize(Width / 2, Height / 2)
Result_1 = last
Version
PointResize(Width * 2, Height * 2).PointResize(Width / 2, Height / 2)
Result_2 = last
Clip "Result_1" will have the same content as the result of "Version", but clip "Result_2" will be half the size of "Version" because "Width" and "Height" refer to clip "last" when not prefixed with a clip variable name.
Expanded to its full form the example looks like this:
a = Version
b = PointResize(a, a.Width * 2, a.Height * 2)
c = PointResize(b, b.Width / 2, b.Height / 2)
Result_1 = c
d = Version
e = PointResize(PointResize(d, d.Width * 2, d.Height * 2), d.Width / 2, d.Height / 2)
Result_2 = e
Btw. an easy way to add a blur effect would be this:
BilinearResize(int(Width * 0.75), int(Height * 0.75)).BilinearResize(Width, Height)
creaothceann is offline   Reply With Quote
Old 16th October 2017, 21:30   #103  |  Link
ale_x
Hi.
I used this function recently
ExtractU().dither_resize16()
But I got an error "there is no function named ExtractU"
by the way, I'm using Avynth + .
Thanx =)
ale_x is offline   Reply With Quote
Old 16th October 2017, 21:52   #104  |  Link
Groucho2004
Groucho2004's Avatar
You're probably using an older version of AVS+ that does not have that function. Update to the latest version (r2508).
Groucho's Avisynth Stuff
Old 17th October 2017, 10:40   #105  |  Link
ale_x
Thank u very much =).
Old 17th October 2017, 15:13   #106  |  Link
real.finder
I think last posts should move to https://forum.doom9.org/showthread.php?t=174120
My Avisynth Stuff
Old 26th December 2017, 06:25   #107  |  Link
ilko
Q : is there a way to enumerate variables in avs ?
I'm trying to do something similar to the following batch script :
set /a count=1
set var=video%count%
echo the resulting var is "video1"
set /a count+=1
echo we add 1 to the initial count so it's now 2
echo then we set the var gain
echo the var is now "video2"
pause
AviSynth+ Fansub Edition
ilko is offline   Reply With Quote
Old 26th December 2017, 09:39   #108  |  Link
StainlessS
StainlessS's Avatar
RT_Stats:- https://forum.doom9.org/showthread.p...light=RT_Stats
RT_VarExist(string)
 Given the name (string) of the variable that you want to test for existence, returns true if exists, else false.
 Eg, #a=32
    RT_Debug(string(RT_VarExist("a")))  # would output 'false' to debugview unless '#a=32' uncommented. {Defined(a) would fail with error}.
    return colorbars()
Could also simulate (for Globals) with Try/Catch in script (within a function, and return as result).
EDIT:
Function VarType(String GlobalName) {
    Try {
	g = Eval(GlobalName) # Fail here if not exist
        res=    g.IsBool   ? 1
            \ : g.IsInt    ? 2
            \ : g.IsFloat  ? 3
            \ : g.IsString ? 4
            \ : g.IsClip   ? 5
            \ : 0
    } Catch (msg) {
        res = 0 # Not Exist
    return res
Function VarTypeName(Int TypIx) {Assert(0 <= Typix <= 5,"VarTypeName: Bad Typix") Return Select(TypIx,"NOT_EXIST","Bool","Int","Float","String","Clip")}
Global G_i = 666   # Comment Me Out
Type = VarType("G_i")
TypeName=VarTypeName(Type)
MessageClip("Global G_i Type = "+String(Type) + " : TypeName='"+TypeName+"'")
EDITED:
EDIT: RT_VarExist just returns result of an Avisynth function, would do equivalent of VarExist on local of that name, and if failed then on Global of that name.
We cant test locals in script within a separate function, you would need to inline script try/catch in-situ if required for local.
EDIT: Something like
    Try {Dummy=Eval(LocalName) LocalExist=True} Catch(msg) {LocalExist=False} # Dummy, avoid assign anything to Last
I sometimes post sober.
Old 18th April 2018, 08:04   #109  |  Link
ShogunGino
Was looking through the guides and the wiki and seemed to find that the Force Film, IVTC, and Deinterlacing tutorial link seems to be dead. Does anyone have a zip file of it? It looks like its the main tutorial that I need for my current situation.
ShogunGino is offline   Reply With Quote
Old 29th August 2018, 18:34   #110  |  Link
Seedmanc
Do we have a definitive guide for MVTools options that does a better job at explaining what the more obscure settings do than the official page? I'm particularly interested in what typical situations the options like divide, trymany, temporal, rfilter and so on should be used.
You'd think after all this time somebody would have done a proper analysis and comparison the way they're done for videocodecs. For example, by taking a source video, halving its framerate then upsampling it back and comparing with the original using tools like MSU VQM or other stuff with metrics like PSNR. This is the way I'm trying to do it, but there's only so much you can derive from metrics you don't know comparing options you don't understand.
For example I was surprised to find out that a combination of block size 32 and truemotion=true gives results a lot worse than most other combinations of sizes and values. Another counter-intuitive discovery was that the search method 3 (which is claimed to be similar to x264's ESA) is actually faster and not better than 5 (UMH).
What options should be tweaked first when dealing with 2K video with lots of flickering? I'm under the impression that most of Avisynth's filters were written in the DVD era and might have SD resolution dependency hardcoded in one way or another somewhere.
Seedmanc is offline   Reply With Quote
Old 28th April 2019, 06:30   #111  |  Link
imsrk48
I want to learn about this plugin more better
http://www.infognition.com/super_resolution_avisynth/
imsrk48 is offline   Reply With Quote
Old 29th April 2019, 07:49   #112  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
According to the comparison screenshots they posted on their websites, it looks like a decent upscaling kernel vs PointResize.
I think that you can achieve something like this by using a decent upscaling kernel yourself, especially in combination with NNEDI and 16bit precision to get better results.
Start with something like:
nnedi3_rpow2(cshift="Spline64Resize", rfactor=2, fwidth=1920, fheight=1080, nsize=4, nns=4, qual=1, etype=0, pscrn=2, threads=0, csresize=true, mpeg2=true, threads_rs=0, logicalCores_rs=true, MaxPhysCore_rs=true, SetAffinity_rs=false, opt=3)
for 8bit.
If you want more precision, you can use:
nnedi3_resize16(target_width=1920, target_height=1080, mixed=true, thr=1.0, elast=1.5, nns=4, qual=2, etype=0, pscrn=4, threads=0, tv_range=true, kernel_d="Spline", kernel_u="Spline", taps=6, f_d=1.0, f_u=2.0, sharp=0, lsb_in=true, lsb=true)
It will use more taps for Spline so it will be very sharp, but it will also try to preserve edges and avoid ringing and aliasing thanks to the trained neural netowk; it's also gonna work with 16bit precision and since it works in 16bit stacked, it's compatible with the normal Avisynth 2.6.1 from 2016.
Cheers,
Frank.
Broadcast Encoder
LinkedIn
Old 16th May 2019, 07:28   #113  |  Link
imsrk48
for 8bit.
Cheers,
Frank.
Thanks a Lot
Old 25th May 2019, 12:14   #114  |  Link
imsrk48
Please suggest me script for add .png logo on a video.
avisynth, faq
