13th November 2013, 19:34 | #18281 | Link | |
I just checked the bitrate of the menu video with DGIndexNV: it indicates a Bitrate(max) of 30.873Mbps, and an average of 18.144 Mbps. This looks indeed too high for BD5/9. Means probably that the menu video has to be compressed. Actually the freezing in my case depends from where during the menu playback I switch to the movie. Wouldn't this be an indication of a bitrate or buffer problem? Last edited by Sharc; 13th November 2013 at 19:45. |
13th November 2013, 19:41 | #18282 | Link |
Tested BD-RB Version 0.45.03 with several DVDs. Actually any video- and audio-stream of the tested DVDs has been in sync but one. The only difference I could figure out is, that the one not working has primary and secondary subtitles and a primary subtitle is activated at start.
13th November 2013, 20:49 | #18283 | Link |
All of my tests, so far, have shown the Quick-Play menu on my LG BD590 fine. I've not done enough to possibly get more than 1 page, but that's coming.
13th November 2013, 21:03 | #18284 | Link | |
Why v0.44.16 rather than a current version? |
13th November 2013, 21:05 | #18285 | Link | |
At some point in the future I plan to add multi-page capability along with the use of selectable graphic button images rather than text. Last edited by jdobbs; 13th November 2013 at 21:08. |
13th November 2013, 21:17 | #18286 | Link |
@ JDobbs
Thank you for that info. I won't have BD-RB import enough to cause that then. Also, nice to know about future plans. Merely curious, I know you're really focused on the Quick-Play displaying/functioning well.. So I don't expect any real focus, these days, on my MOV Import posts. Just want to know if you saw them..? Thank you.
13th November 2013, 21:22 | #18287 | Link | |
13th November 2013, 21:46 | #18288 | Link | |
As for the Quicktime player -- ugghh, I couldn't imagine a poorer performing player for the PC. I don't think I've ever used it without stutter or problems of some type. Maybe you could forward a short example that has issues? Last edited by jdobbs; 13th November 2013 at 21:56. |
13th November 2013, 22:23 | #18289 | Link |
More testing done. Thinking there might be some incompatibilities between PowerDVD 12 and Windows 8.1, I downloaded the trial version of PowerDVD 13. The Bourne blu ray movie works in this player as it should, with the first play being the menu. All the titles seem to work, as well as the chapters.
I made a second test movie, this time making a 50gb blu ray and using the movies Blade Runner and Moon as input. The originals are blu ray source. This second movie plays in both Arcsoft TMT 5 and PowerDVD 13, but the menu doesn't show up. It simply starts with the first title in both those players. It is possible to select the other title from within TMT 5, and it is possible to access the menu in PowerDVD 13 once it starts playing the first title. So playback in the major software players is a bit hit or miss. |
13th November 2013, 23:12 | #18290 | Link | |
13th November 2013, 23:16 | #18291 | Link | |
Video: MPEG4 Video (H264) 1280x720 29.97fps 10418kbps [Video] Audio: AAC 44100Hz mono 63kbps [Audio] For one of the files. The video and audio play well with my LG Player when burned to a BD-RE DL as a data disk or USB flash drive. AFTER each file file has been converted to MKV from MOV with BD-RB's Alternate Output with AC-3. When Importing the MKV's the audio plays as should with my LG player. When Imported (before converting to MKV) from MOV and burned, there's an interesting audio "stutter" effect. I'll get some video ready for you and email... I don't use QuickTime as a Player or editor (not even close to my preferred choice). All QuickTime extensions are assigned to Media Player Classic: Home Cinema (64-bit). Or I use VLC. I have QuickTime installed for use with iTunes an M4V - MP4 files for use with iDevices, you get the idea.
14th November 2013, 00:42 | #18292 | Link |
@Sharc
Thanks for your response, however, (Perhaps I wasn't as clear as I could have been) although I too had no problem making a movie only BD9 of "The Man of Steel", the problem arose when trying to make a FULL DISC copy. Any thoughts and/or suggestions will be greatly appreciated ;>} |
14th November 2013, 00:45 | #18293 | Link | ||
@jdobbs
14th November 2013, 00:59 | #18294 | Link | |
14th November 2013, 15:45 | #18296 | Link |
@ jdobbs
found a bug by creating 3d (mkv). if automatically crop black borders is enabled, enconding wont start and process stops. if automatically crop black borders is disabled, encoding process works fine. would be nice if you can fix this in upcoming bd rebuilder version. many thx and kind regards from germany andref4 |
14th November 2013, 17:05 | #18297 | Link | |
14th November 2013, 17:49 | #18298 | Link | |
You may be able to do the crop manually with a filter. But it gets complicated keeping the aspect ratio right, since ALTERNATE output is set to a fixed height & width based on the ALTERNATE.TXT settings. It's not impossible, but you'd need to create a custom output format (actually you'd have to do that even if AutoCrop worked). Last edited by jdobbs; 14th November 2013 at 17:56. |
14th November 2013, 19:58 | #18299 | Link | |
14th November 2013, 20:02 | #18300 | Link | |
@Sharc
