30th May 2009, 22:17 | #1001 | Link | ||
HDConvertToX author
BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
31st May 2009, 05:11 | #1003 | Link | |
Unfortunately, that's not the only problems I experience using HDC. Very few times have I gotten a usable encode. Most of the encodes I've done have choppy/eratic frames when panning, and jagged edges on moving objects. It could be that I just don't know the right settings to use. I never try to do any cropping or resizing, and just want a simple encode to x264. I also just copy the audio. Maybe it would work better if I converted the audio to another format? Being used to AutoMKV, Nothing needs changing, I have it set for Constant Quality to the MKV container. I'm at a loss to explain my inability to use HDC successfully, I haven't seen any other posts about these issues.. Encoding my DVD collection to MKV for my WDTV is the only reason I'm trying to use it.. Rick |
31st May 2009, 06:52 | #1004 | Link |
HDConvertToX author
@rickhtoo
automkv has an automatic deinterlace routines. HDC as a good deinterlace detection BUT isn't automatic. if you think that your movie is interlaced : in "De-interlace" list select Interlaced , if your movie is to ivtc (is 29.97 fps) just select Film NTSC BHH
31st May 2009, 09:20 | #1005 | Link |
Greetings,
have another dummy question. Does any1 uses Sharktooth profiles in HDC ? Yes, I admit I am too lazy to write down each profile setting manually. I have changed buzz x264 Infinite Time preset a little bit not to take "infinite time" and the quality is nice but I want to compare it with Shark ones and implemet in HDC (because its neat gui). Thanx. |
31st May 2009, 13:09 | #1006 | Link | |
And perhaps a cosmetic issue only for 2-pass mode: The bitrate which is passed on to the x264 cmdline (queue.bat) is lower than what is displayed as text below the the video quality slider (.....; Bitrate= ...) |
31st May 2009, 13:19 | #1007 | Link |
It seems I catch another bug.
1) I set temp to e:/temp, 2) then open dvd, analize, 3) press "preview" - all is OK, 4) then set encoding parameters, add queue(without pressing "generate encode"), 5) Press "preview" again and get error in player "Color matrix could not open specified d2v project file! e:\temp preview.avs line 75" dump preview preview.avs from step 3 Code:
#HDConvertToX Avisynth Script # #Input File = E:\Video\Films\karnoch\VTS_01_1.VOB #Original Resolution = 352x288 #Aspect Ratio = 1.3334 #Frame rate =25.000 #Number of Frames = 108652 #Lenght (hours:minutes:seconds) = 1:12:27 #Display Aspect Ratio = 1.5001 #Aspect Error = 2.2778 # #Resized resolution = 352 / 240 #Crop Left = 0 #Crop Top = 16 #Crop Right = 0 #Crop Bottom = 16 # LoadPlugin("D:\tools\HDC\filters\AddGrain.dll") ... LoadPlugin("D:\tools\HDC\filters\yadifmod.dll") Import("D:\tools\HDC\filters\BlindDeHalo3_mt2.avsi") Import("D:\tools\HDC\filters\Deblock_QED_MT2.avsi") Import("D:\tools\HDC\filters\GradFun2DBmod.v1.3.avsi") Import("D:\tools\HDC\filters\Lem.avsi") Import("D:\tools\HDC\filters\LSFmod.v1.7.avsi") Import("D:\tools\HDC\filters\MCTemporalDenoise.v1.2.02.avsi") Import("D:\tools\HDC\filters\QMLF_3_motions.avsi") Import("D:\tools\HDC\filters\QMLF_5_motions.avsi") Import("D:\tools\HDC\filters\QMLF_7_motions.avsi") Import("D:\tools\HDC\filters\QMLF_9_motions.avsi") Import("D:\tools\HDC\filters\seesaw.avsi") Import("D:\tools\HDC\filters\spresso.avsi") Import("D:\tools\HDC\filters\Srestore.avsi") directshowsource("E:\Video\Films\karnoch\VTS_01_1.VOB") last = isRGB(last) ? ConvertToYV12(last) : last last = isYUY2(last) ? ConvertToYV12(last) : last GaussResize(352,240,0,16,-0,-16,p=75) ColorMatrix(mode="Rec.709->Rec.601") FFT3DFilter(sigma=2.5, sharpen=0.3) Code:
#HDConvertToX Avisynth Script # #Input File = e:\video\films\karnoch\vts_01_1.vob #Original Resolution = 352x288 #Aspect Ratio = 1.3334 #Frame rate =25.000 #Number of Frames = 108652 #Lenght (hours:minutes:seconds) = 1:12:27 #Display Aspect Ratio = 1.5001 #Aspect Error = 2.2778 # #Resized resolution = 352 / 240 #Crop Left = 0 #Crop Top = 16 #Crop Right = 0 #Crop Bottom = 16 # LoadPlugin("D:\tools\HDC\filters\AddGrain.dll") ... LoadPlugin("D:\tools\HDC\filters\yadifmod.dll") Import("D:\tools\HDC\filters\BlindDeHalo3_mt2.avsi") Import("D:\tools\HDC\filters\Deblock_QED_MT2.avsi") Import("D:\tools\HDC\filters\GradFun2DBmod.v1.3.avsi") Import("D:\tools\HDC\filters\Lem.avsi") Import("D:\tools\HDC\filters\LSFmod.v1.7.avsi") Import("D:\tools\HDC\filters\MCTemporalDenoise.v1.2.02.avsi") Import("D:\tools\HDC\filters\QMLF_3_motions.avsi") Import("D:\tools\HDC\filters\QMLF_5_motions.avsi") Import("D:\tools\HDC\filters\QMLF_7_motions.avsi") Import("D:\tools\HDC\filters\QMLF_9_motions.avsi") Import("D:\tools\HDC\filters\seesaw.avsi") Import("D:\tools\HDC\filters\spresso.avsi") Import("D:\tools\HDC\filters\Srestore.avsi") directshowsource("e:\video\films\karnoch\vts_01_1.vob") last = isRGB(last) ? ConvertToYV12(last) : last last = isYUY2(last) ? ConvertToYV12(last) : last GaussResize(352,240,0,16,-0,-16,p=75) ColorMatrix(d2v="D:\tools\HDC\movie.d2v") FFT3DFilter(sigma=2.5, sharpen=0.3) Code:
HDConvertToX v.1.7.323.2869 report Input File: e:\video\films\karnoch\vts_01_1.vob ( E:\Video\Films\karnoch\VTS_01_1.VOB ) Codec Video: mpeg Width / Heigh : 352 / 288 Framerate / Framecount: 25.000 / 108652 Duration(hh:mm:ss): 1:12:27 Aspect Ratio: 1.3334 Resized resolution: 352 / 240 Crop Values : 0:16:0:16 Activate: Crop Obey to AR Start Video Configuration -> Encoding Settings: X264 in MP4 Encoding Preset: 7 Final Size: 700 Priority: idle Denoise Level: None Set Manual Bitrate: 889 Video Handling: Use Best Decoder -> End Video Configuration Start Audio Configuration -> Audio Codec: Nero AAC Audio Audio Bitrate/Quality: 0.2 Audio Channels: 2 MP3 Mode: vbr Normalize: On Audio handling: Use Eac3to as demuxer -> End Audio Configuration Full Audio List-> (*** mean selected) NONE *** 2: ac3, 2.0 channels, 128kbps, 48khz -> End Full Audio List Full Subtitle List-> (*** mean selected) NONE -> End Full Subtitle List Mux Subtitle in MP4/MKV file: On Start Advanced AviSynth -> Basic Filter: FFT3DFilter(sigma=2.5, sharpen=0.3) ColorMatrix: On -> End Advanced AviSynth Start Queue -> "D:\tools\HDC\applications\dgindex.exe" -FO=0 -OM=0 -YR=2 -AIF=[e:\video\films\karnoch\vts_01_1.vob] -OF=[E:\temp\movie] -exit -minimize "D:\tools\HDC\applications\eac3to.exe" "e:\video\films\karnoch\vts_01_1.vob" 2: stdout.wav -normalize -down2 | "D:\tools\HDC\applications\neroaacenc.exe" -if - -q 0.2 -ignorelength -of "E:\temp\hdencodertox-pid2.mp4" "D:\tools\HDC\applications\x264.exe" --pass 1 --bitrate 889 --threads auto --thread-input --no-psnr --progress --keyint 250 --bframes 4 --mixed-refs --trellis 0 --ref 1 --deblock -1,-1 --subme 2 --direct auto --vbv-bufsize 14000 --vbv-maxrate 25000 --me dia --no-ssim --weightb --b-adapt 2 --no-chroma-me --aud --aq-strength 1 --psy-rd 1.0:0.3 --sar 1:1 --output "E:\temp\hdconverttox_vts_01_1.h264" "E:\temp\hdconverttox_vts_01_1.avs" "D:\tools\HDC\applications\x264.exe" --pass 2 --bitrate 889 --threads auto --thread-input --no-psnr --progress --keyint 250 --bframes 4 --mixed-refs --trellis 0 --ref 4 --deblock -1,-1 --subme 9 --direct auto --vbv-bufsize 14000 --vbv-maxrate 25000 --me umh --no-ssim --weightb --b-adapt 2 --no-chroma-me --8x8dct --aud --aq-strength 1 --psy-rd 1.0:0.3 --sar 1:1 --output "E:\temp\hdconverttox_vts_01_1.h264" "E:\temp\hdconverttox_vts_01_1.avs" "D:\tools\HDC\applications\mp4box.exe" -add "E:\temp\hdconverttox_vts_01_1.h264" -fps 25.000 -add "E:\temp\hdencodertox-pid2.mp4" "E:\karnoch.MP4" shutdown -s -t 2 -f -> End Queue AviSynth Script -> Working with files: E:\temp\hdconverttox_vts_01_1.avs try { mpeg2source("E:\temp\movie.d2v") LanczosResize(352,240,0,16,-0,-16) ColorMatrix(d2v="E:\temp\movie.d2v") FFT3DFilter(sigma=2.5, sharpen=0.3) } catch (err) { last=BlankClip() converttoyv12() subtitle(err) trim(0,1500) } -> End AviSynth Script Last edited by alter4; 31st May 2009 at 13:23. |
31st May 2009, 16:50 | #1008 | Link | |
Just ran into another issue trying to convert a 2 DVD set of Blue Planet. The frame rate shows 25 fps and I tried Adub's suggestion of selecting force DSS2. I then set it to Insane quality. After 2 plus hours the conversion finally finished. Almost... The progress showed 100.0 % with 0 time left. However the frames showed 65470/65477. The conversion stopped there and never finished.... I am in the process of doing it over but I created new ifo's with ifoedit. Will see what happens and post the progress. Thanks for your help Buzz. btw, here is the make report from the failed conversion. Code:
HDConvertToX v.1.7.326.2893 report Input File: k:\blue planet pt 1\video_ts\vts_01_1.vob ( K:\Blue Planet Pt 1\VIDEO_TS\VTS_01_0.IFO ) PGC : PGC 1. Length: 0:48:33:12 / chained=1 Codec Video: mpeg Width / Heigh : 720 / 576 Framerate / Framecount: 25.000 / 72825 Duration(hh:mm:ss): 0:48:34 Aspect Ratio: 1.7778 Resized resolution: 720 / 576 Crop Values : 0:8:0:8 No Resize & Crop: On Start Video Configuration -> Encoding Settings: X264 in MKV Encoding Preset: 8 Final Size: 20 Priority: idle Denoise Level: Super Light Video Handling: Force DirectShowSource2 (Haali) -> End Video Configuration Start Audio Configuration -> Audio Codec: Copy Audio Audio Bitrate/Quality: 128 Audio Channels: 2 MP3 Mode: abr Normalize: On Audio handling: Use Eac3to as demuxer Keep only core: On -> End Audio Configuration Full Audio List-> (*** mean selected) NONE *** 80: English (AC3 2ch, 0xBD 0x80) [0] -> End Full Audio List Full Subtitle List-> (*** mean selected) *** NONE English 0 (0xBD 0x20) [0] wide -> End Full Subtitle List Mux Subtitle in MP4/MKV file: On Start Advanced AviSynth -> ColorMatrix: On -> End Advanced AviSynth Start Queue -> "E:\HDConverToX\applications\eac3to.exe" "K:\Blue Planet Pt 1\VIDEO_TS\VTS_01_1.vob"+"K:\Blue Planet Pt 1\VIDEO_TS\VTS_01_2.vob"+"K:\Blue Planet Pt 1\VIDEO_TS\VTS_01_3.vob"+"K:\Blue Planet Pt 1\VIDEO_TS\VTS_01_4.vob"+"K:\Blue Planet Pt 1\VIDEO_TS\VTS_01_5.vob" 3: "E:\HDConverToX\temp\hdencodertox-pid3.ac3" "E:\HDConverToX\applications\x264.exe" --crf 20 --threads auto --thread-input --no-psnr --progress --keyint 250 --bframes 6 --mixed-refs --trellis 2 --ref 6 --deblock -1,-1 --subme 7 --direct auto --vbv-bufsize 14000 --vbv-maxrate 25000 --me umh --no-ssim --merange 20 --weightb --b-adapt 2 --b-pyramid --partitions p8x8,b8x8,i4x4,i8x8 --8x8dct --aud --aq-strength 1.0 --psy-rd 1.0:0.3 --sar 1:1 --output "E:\HDConverToX\temp\hdconverttox_vts_01_1.h264" "E:\HDConverToX\temp\hdconverttox_vts_01_1.avs" "E:\HDConverToX\applications\Chapter\ChapterXtractor.exe" "K:\Blue Planet Pt 1\VIDEO_TS\VTS_01_0.IFO" "E:\HDConverToX\temp\chapters.txt" -p5 "E:\HDConverToX\applications\mkvmerge.exe" -o "K:\convert\Blue Planet Pt 1.MKV" --default-duration 0:25.000fps --aspect-ratio -1:1.7778 "E:\HDConverToX\temp\hdconverttox_vts_01_1.h264" --language -1:eng "E:\HDConverToX\temp\hdencodertox-pid3.ac3" --chapters "E:\HDConverToX\temp\chapters.txt" --title "Done with HDConvertToX v.1.7.316.2823" -> End Queue AviSynth Script -> Working with files: E:\HDConverToX\temp\hdconverttox_vts_01_1.avs try { DSS2("k:\blue planet pt 1\video_ts\vts_01_1.vob",fps=25.000) last = isRGB(last) ? ConvertToYV12(last) : last last = isYUY2(last) ? ConvertToYV12(last) : last ColorMatrix(mode="Rec.709->Rec.601") hqdn3d(1) return last } catch (err) { last=BlankClip() converttoyv12() subtitle(err) trim(0,1500) } -> End AviSynth Script |
31st May 2009, 23:02 | #1009 | Link |
After a lot of experimentation I find that Film NTSC will not work.. Tried several rips, and it refuses to encode the video if I choose that mode. However Interlaced does work and solves the problem with jagged edges. This was using a rip that showed 29.97 fps. I guess I will just keep it on Interlaced and see how it goes.
Rick |
1st June 2009, 07:30 | #1010 | Link | |||||
HDConvertToX author
you must omit the --pass 2, bitrate and --threads auto --thread-input --no-psnr --progress Quote:
for bitrate: yes, only visual gitch Quote:
i suggest to use the Preview with different deinterlacers, and find what is more suited for input Quote:
make sure you had enough space on disk.. i strongly doubt is a problem of ifo BHH
1st June 2009, 07:55 | #1011 | Link |
My monitor is 1280x1024 (max). Maybe that's the problem with 1920x1080 sources.
If we would reduce the Visual Crop size by 2 if it it doesn't fit the display - and perhaps admit the cropping in steps of 2 pixels only? (I think DGIndex tools do something similar for the same reason) Last edited by Sharc; 1st June 2009 at 07:57. |
1st June 2009, 08:11 | #1012 | Link |
HDConvertToX author
if apply a reduceby2 (or what ever resizing) the crop values will be referred to a resized image, and so wrong
i will study a better approach... BHH
1st June 2009, 11:38 | #1014 | Link |
HDConvertToX author
please edit the file name... no support for this kind of files...
BHH
1st June 2009, 14:16 | #1017 | Link |
HDConvertToX author
@Spida
... you must donwload the update HDC... BHH
1st June 2009, 14:42 | #1019 | Link |
HDConvertToX author
@HiDef
again NO SUPPORT FOR DOWNLOADED MOVIE. please remove your "make report" BHH
1st June 2009, 15:35 | #1020 | Link |
Small tweak of queue.bat
would it be possible to improve queue.bat little bit? I would add the following two lines at the beginning and end of queue.bat: Code:
prompt $d $t $_$P$G "C:\DVD\HDC\applications\dgindex.exe" -FO=0 -OM=0 -YR=2 -AIF=[c:\dvd\title.mkv] -OF=[C:\DVD\HDC\temp\movie] -exit -minimize "C:\DVD\HDC\applications\eac3to.exe" "c:\dvd\title.mkv" 2: "C:\DVD\HDC\temp\hdencodertox-pid2.ac3" "C:\DVD\HDC\applications\x264.exe" --bitrate 467 --threads auto --thread-input --no-psnr --progress --keyint 250 --bframes 1 --trellis 0 --ref 1 --deblock 0,0 --subme 2 --direct spatial --vbv-bufsize 14000 --vbv-maxrate 25000 --me hex --no-ssim --merange 8 --b-adapt 0 --no-chroma-me --aud --sar 1:1 --output "C:\DVD\HDC\temp\hdconverttox_title.h264" "C:\DVD\HDC\temp\hdconverttox_title.avs" "C:\DVD\HDC\applications\mkvmerge.exe" -o "C:\DVD\title2.mkv" --default-duration 0:25.000fps "C:\DVD\HDC\temp\hdconverttox_title.h264" --language -1:cze "C:\DVD\HDC\temp\hdencodertox-pid2.ac3" --title "Done with HDConvertToX v.1.7.323.2869" pause The last line should cause that CMD window will not close and user can check what really happen. |
bluray, hdc, hdconverttox, m2ts, network media tank, playstation, x264 gui |
