20th October 2011, 21:17 | #10283 | Link |
I hate stupid C++. In Delphi accessing a two dimensional array can be done by writing "arr[0, 0]" or "arr[0][0]". In C++ the compiler also allows both, but I only get correct results when using "arr[0][0]". When using "arr[0,0]" in C++ I get very weird results. What a stupid compiler. This was causing the crash.
20th October 2011, 21:21 | #10284 | Link |
madVR v0.76 released
http://madshi.net/madVR.zip Code:
* fixed: crash on MPC-HC exit / close file * fixed: OSD didn't show properly or didn't show at all * fixed: subtitles showed with a black background * fixed: trade quality -> use 10bit chroma option was used for luma sometimes * unfortunately subtitles are not running through 3dlut, anymore |
20th October 2011, 21:25 | #10285 | Link | |
20th October 2011, 21:26 | #10286 | Link | ||
Forget about my old .3dlut stuff, just use mpv if you want accurate color management |
20th October 2011, 21:26 | #10287 | Link | |
20th October 2011, 21:31 | #10288 | Link |
General support for HLSL (or assembly) pixel shaders would be much nicer imo, then we can add our own deband and deinterlacing filters without needing madshi to do so, and if they're good enough he can just seamlessly integrate them.
20th October 2011, 21:41 | #10289 | Link | ||||
Can't. I don't even draw the subtitles myself. I just tell MPC-HC to draw them. I have to let MPC-HC draw them directly onto the video image, that's the only way it works with the ISR. Quote:
Yeah, support for external pixel shaders is on my to do list. Like so many other things. |
20th October 2011, 21:46 | #10291 | Link | ||||
Have you considered just writing a wrapper to X back-end library written in Y language of choice, using C++? Quote:
Write one according to your requirements. All you need is access to the current and previous frames. I don't think MPC-HC lets you have the previous frame but madVR certainly could if designed that way.
Forget about my old .3dlut stuff, just use mpv if you want accurate color management Last edited by nand chan; 20th October 2011 at 21:50. |
20th October 2011, 22:04 | #10292 | Link | ||||
Anyway, everybody has his own idea about which of the many things on my to do list should have which priority. In the end I will do things in the order that I consider best. Shader support is not at the very top of my priority list, but it's not too far down, either. |
20th October 2011, 22:11 | #10293 | Link | |||
I think a simpler solution may just be to have one of the MPC-HC devs go through the ISR code and make it fill the alpha channel (optionally, of course) as well. Have you considered forking VSFilter and rendering subtitles yourself (well, of course you've considered it, but how immediate/easy would it be?) Quote:
20th October 2011, 22:15 | #10294 | Link | |
20th October 2011, 22:16 | #10295 | Link | |
20th October 2011, 22:24 | #10296 | Link | |
As an optional setting in the tweaks section this could work for now, for those who want color accurate subtitles *and* have an older GPU.
20th October 2011, 22:26 | #10297 | Link |
If there is work going into a new subtitle filter, it should imho be designed in such a way that its not locked into one renderer (iow. defining a new/better interface to a sub rendering filter, and using that instead of hard-wiring it)
If one day the time comes, i would be available to also work on that, the existing subtitle solutions have really been annoying me lately.
20th October 2011, 22:26 | #10298 | Link | |
20th October 2011, 22:30 | #10299 | Link | |
Default: No color management on subs, same as now Optional 1: Color management for subs Optional 2: (Only available when previous selected) Dither to 10 bit before rendering subtitles
20th October 2011, 22:37 | #10300 | Link | |
