Old 18th April 2010, 04:36   #21  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
Originally Posted by MyCometG3 View Post
Humm.
To make single pass + smaller gop size works better, limiting qpmin seems to be one choice, I guess.
Currently QuickTime's default Key frame interval (used as keyint) is 24, it is too smaller value compared to rc_lookahead's default value.
If default keyint is larger value like 120 or so, rc_lookahead perfectly controls each frame's qp. But it is not for now.
Under this restriction (as common QuickTime Component), limiting QP-min value seems to be one of resonable solution.
Well-known user always changes, but novice user may not change. It is easy to overshoot on this case.
rc-lookahead doesn't even affect frame QP except in the case of VBV mode... and an rc-lookahead of 24 is quite fine enough for that.
Old 18th April 2010, 04:36   #22  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
@Adub:
Yes, it absolutely is. It works almost everywhere that any other QuickTime component would. Strangely it crashes AJA VTRXchange (A simple capturing app for AJA's Kona cards).
@MyCometG3
I think you're a bit misguided in trying to mimic QuickTime. Why optimize around the corner case of short GOPs? I would bet the vast majority of people use the default max keyint of 250, as it's a well chosen number and x264 is highly adaptive in frametype decision.
I would VERY MUCH prefer if the defaults precisely mirrored x264cli, and the slider adjusted the --preset. This would make things a lot more familiar to us daily x264 users, as it's much closer to how other x264 GUIs have done things. Also, adjusting the --preset is basically the only adjustment most folks make (in addition to bitrate) between encode.
Having the slider adjust --qp-min doesn't make sense at all, because this value should almost NEVER be adjusted. Unless you think you're smarter than x264
~MiSfit
These are all my personal statements, not those of my employer :)
Old 18th April 2010, 04:52   #23  |  Link
MyCometG3
Mapping preset as q-slider seems to be good idea.
But q-slider is analog, and no way to feedback what preset is specified. Also it seems to require re-design dialog, because under crf mode preset is specified in complex dialog.
If user doesnot see common compression dialog, it is easy though.
To achive all of request, user can not use common movie export component... Behaving as quicktime component seems to be not smart.
EDIT - I guess just ignoring slider is simple but best solution for ABR. Planed to implement on next update.
MyCometG3 is offline   Reply With Quote
Old 21st April 2010, 22:50   #24  |  Link
Adub
Fighting spam with a fish
Adub's Avatar
@Blue_MiSfit
Thanks for the info! Looking forward to getting my Macbook Pro and testing this out.
FAQs:Bond's AVC/H.264 FAQ
Site:Adubvideo
Adub is offline   Reply With Quote
Old 27th April 2010, 00:30   #25  |  Link
MyCometG3
Update: 1.2.6 - r1564
x264Encoder Version 1.2.6 is now available at:
- http://www003.upp.so-net.ne.jp/mycometg3/
Based on libx264.a r1564.
When abr, q-slider is ignored by default now.
Old 27th April 2010, 01:02   #26  |  Link
Blue_MiSfit
Excellent!
I've always been confused as to how CRF mode worked in your QuickTime component.
If I set CRF mode in the config page, where do I enter the CRF number I want to use? Based on a previous post of yours, I see that the quality slider adjusts the CRF number - at least it did at one point. Is this still the case? If so, I assume moving the slider to the right will lower the CRF value, correct?
~MiSfit
Old 27th April 2010, 03:22   #27  |  Link
MyCometG3
Yes.
Datarate:automatic runs as crf.
Datarate:any value runs as abr.
exeption: if you checked lossless, datarate/slider are ignored.
Old 27th April 2010, 20:35   #28  |  Link
porfitron
DivX Team
Very cool, MyCometG3.
Just tried it out with iMovie on Snow Leopard. Generally, I use auto-leveling, but do you think it would be possible to let users set to level 4.0 (you skipped up to 4.1).
I ask because our DivX Plus HD profile is 4.0: http://developer.divx.com/docs/divx_...ion_with_x264/
Also, is there a way to get it to export in a container other than MOV? It's very simple to mux to MKV with MKVtoolnix or MP4 with Subler, but if it is possible directly from iMovie/Quicktime I would like to know how.
Again, very nice work! Thanks!
I lurk @ DivX Labs: labs.divx.com | DivX Developer info: developer.divx.com | Our Free H.264 Decoder: DivX Plus
Follow @DivXLabs on Twitter for Software Updates, Betas, and More
porfitron is offline   Reply With Quote
Old 28th April 2010, 14:54   #29  |  Link
MyCometG3
Currently, it is limited to a few levels. I am not sure, but 4.0 seems to have little difference from 4.1. (VCL value only?)
Anyway, I can mod my code to add support 4.0 in addition to 4.1.
I do not know any export component for mkv.
MPEG Streamclip works with mp4, but no support for mkv.
No plan to mkv exporter in next DivX for Mac?
Old 5th May 2010, 07:46   #30  |  Link
MyCometG3
Update: 1.2.7 - r1570
x264Encoder Version 1.2.7 is now available at:
Based on libx264.a r1570.
Support many levels now.
Old 5th May 2010, 09:07   #31  |  Link
smok3
brontosaurusrex
smok3's Avatar
i still need a short guide for dummies:
a. what do i clicky to get crf23 going &
b. what to clicky to get crf21 going (with default profile)?
(readme/docs stuff are totaly useless btw)
thanks for your work!
smok3 is offline   Reply With Quote
Old 5th May 2010, 11:32   #32  |  Link
MyCometG3
CRF value takes analog values. Try log info checkbox.
Console log shows what crf value is specified when slider is changed.
Old 5th May 2010, 15:10   #33  |  Link
Gser
Oh I sooo would have needed this a year and a half ago. Thank Apothis that I will never need to use a Mac again.
Gser is offline   Reply With Quote
Old 5th May 2010, 18:49   #34  |  Link
creamyhorror
No instant indicator for CRF value?
Keep up the good work!
creamyhorror is offline   Reply With Quote
Old 6th May 2010, 12:33   #35  |  Link
Mug Funky
interlace this!
Mug Funky's Avatar
hey, mycometg3! love your work - x264encoder has been a bit of a workhorse at my last workplace for about a year - much better for delivering proofs to clients than apple's crap colour-tainted stupid slow bad quality encoder.
perhaps a little textbox in the settings dialog that maps to the quality slider would help relieve the confusion. and if it's possible, the ability to set a crf in the textbox and have it change the position on the slider?
interesting about streamclip having mp4 output... i had been making movs and using applescript and some bash with mp4box to handle the mp4 creation after encoding.
sucking the life out of your videos since 2004
Mug Funky is offline   Reply With Quote
Old 12th May 2010, 00:24   #36  |  Link
MyCometG3
Update: 1.2.8 - r1583
x264Encoder Version 1.2.8 is now available at:
Based on libx264.a r1583.
Fix crash issue. Numeric field for crf is now available.
Old 12th May 2010, 20:29   #37  |  Link
porfitron
DivX Team
You totally fixed the crash issue
Encoding some stuff now... I'll let you know what happens.
Old 12th May 2010, 20:37   #38  |  Link
Blue_MiSfit
Awesome! This keeps getting better and better!!
Old 13th May 2010, 04:17   #39  |  Link
creamyhorror
MyCometG3, you're a real example to us. Thanks for implementing suggestions, and so quickly.
(Now someone needs to write a blurb about doing CRF encoding for all the QT users out there, so they know there's an alternative to 2-pass...)
Old 22nd May 2010, 23:21   #40  |  Link
MyCometG3
Update: 1.2.9 - r1602
x264Encoder Version 1.2.9 is now available at:
Based on libx264.a r1602.
Support fake-interlaced.
mac os x, quicktime, x264encoder
