14th November 2018, 22:42 | #241 | Link |
You can remove DN to 5.1 eac3:
E-AC3, 5.1 channels, 0:00:34, 1536kbps, 48kHz, dialnorm: -27dB Code:
eac3to 51chan_dn.eac3 51chan.eac3 But to 7.1.eac3 only can renove the DN from the core: E-AC3, 7.1 channels, 0:01:23, 768kbps, 48kHz, dialnorm: -27dB (core: AC3, 5.1 channels, 0:01:23, 448kbps, 48kHz, dialnorm: -27dB) Code:
eac3to 71chan_dn.eac3 71chan.eac3 -> abort eac3to 71chan_dn.eac3 71chan.eac3 -core
19th November 2018, 22:14 | #242 | Link |
Life's clearer in 4K UHD
Hi tebasuna51,
Windows Defender has just reported the following: - Cheers
8th February 2019, 00:46 | #243 | Link |
Anime addict
Hi, I need save audio files on 32 bitdepth, I think that only ALAC audio encoder supported that bit depth (compression audio). How I could using ALAC with Useac3to? Thanks in advance, Teba.
EDIT: Maybe?--> stdout.wav | refalac - -o audio.m4a
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Radeon RX580 8GB DDR5 + ADATA SX8200 Pro 1 TB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite Last edited by Overdrive80; 8th February 2019 at 00:48. |
8th February 2019, 02:57 | #244 | Link |
If refalac.exe is in the eac3to/UsEac3to/defined path the sintax is correct.
But I don't know the source, and by default eac3to output stdout.wav in 24 bits int, you can try stdout.wav -down32 | refalac - -o audio.m4a To obtain a 32 bits int. From lossy decoders you can obtain until 64 bits float with the parameter -full, for instance: eac3to input.ac3 output64float.wav -full I don't know how obtain 32 bits float.
8th February 2019, 19:49 | #245 | Link |
Anime addict
The source is 32 bit float but, refalac convert directly to 24 bit integer. I think that ALAC does not support 32 bit depth. Any other lossless encoder with support for 32 bit? Thanks.
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Radeon RX580 8GB DDR5 + ADATA SX8200 Pro 1 TB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite Last edited by Overdrive80; 8th February 2019 at 19:56. |
9th February 2019, 11:02 | #246 | Link |
The float audio samples are only usefull to operate with them (mix, amplify, etc.), after that must be normalized and converted to int samples before to be played (to avoid overflow).
The precission of 32 float (24 bits of mantissa) is, more or less, the same than 24 int. A float format must be converted always to int (normalize first) to lossless encode. I never see a source of 32 bit float lossless, maybe is a decode of a lossy format.
9th February 2019, 14:29 | #247 | Link | |
Anime addict
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Radeon RX580 8GB DDR5 + ADATA SX8200 Pro 1 TB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite |
17th April 2019, 16:42 | #248 | Link |
hello , sorry my english...
Windows 10 Pro, user Paweł (Polish letters) UsEac3To choose the test and show me: "C:\Users\Paweü\Desktop\eac3to.exe" -test -progressnumbers -log="C:\Users\Paweü\Desktop\UsEac3to\UsEac3To.log" Processing Info... Please wait or Ctrl+C over CMD window. The problem is that instead of Paweł, I have Paweü Can you fix it somehow? so that the program would support Polish letters? Now, when I open UsEac3 it does not work, the program does nothing ... regards Eleonore |
17th April 2019, 21:50 | #249 | Link |
Sorry Eleonore I can't do anything about that.
The unique workaound is create folders to install and work UsEac3to without special letters. C:\Portable\eac3to\UsEac3to...
7th July 2019, 17:17 | #250 | Link |
My os drive is C:. When I demux to mkv (using Haali Media Splitter) and select output folder not on c drive (D:\... for ex) it creates a few mb mkv file and the process gets stuck.
If i choose C:\ it creates files in appdata\local\VirtualStore. If i choose C:\...\ it works correctly. I'm using eac3to 3.34 with UsEac3to GUI 1.2.9 Any thoughts? Last edited by orisvl; 7th July 2019 at 17:21. |
1st November 2019, 17:07 | #253 | Link |
E-AC3 really working? I'm trying to convert or decode a EAC3 file and this gives me error. does it decode with libav/ffmpeg (E-)AC3 or i need nero 7 installed?
Thanks. EDIT: seems that with windows xp i can't use the ffmpeg. And i want to use qaac. I will try belight/besweet Last edited by rocknard; 1st November 2019 at 17:51. |
1st November 2019, 18:50 | #255 | Link |
Fortunately some nice folks still provide current FFmpeg builds which work under WinXP. This one by Reino (CoRoNe) is my favorite:
http://rwijnsma.home.xs4all.nl/files...c-xpmod-sse.7z I know that it has no problems decoding and encoding eac3 audio. To use qaac under XP you need an older version of iTunes or QuickTime. Let me know if I should upload something for you. Cheers manolito |
2nd November 2019, 10:28 | #256 | Link | |
The libav dll in use with eac3to is very old and only work with eac3 5.1, with 7.1 crash.
For instance with: Quote:
To decode/recode the track 3 you can use the button 'A/V Recode', if you have the appropiate ffmpeg and qaac for you OS. belight/besweet never can decode eac3.
3rd November 2019, 21:26 | #257 | Link | |||
Thank you Quote:
Well, i will check how to use ffmpeg to reencode a .eac3 7.1/5.1 to 2.0 (+lfe or not) with normalization/drc. Stereo with 2 channels + subwoofer is equal to 2.1? do i need to put -downstereo or -downdpl (effect surround on stereo = dolby pro logic II or I?) on UsEac3To? P.S.: behappy works on winxp with one lLSMASH-Works-r784 (for win xp) for .eac3 files (libav or ffmpegsource). Last edited by rocknard; 3rd November 2019 at 21:33. |
4th November 2019, 12:15 | #258 | Link | |
Yes, but downmix to 2.1 is not recomended at all.
Downmix only to 2.0 Quote:
29th November 2019, 13:55 | #259 | Link |
Could you add more parameters to the parameters dropdown or make it editable, please. I miss "down6" for example.
List of commands: https://en.wikibooks.org/wiki/Eac3to...files_as_input |
29th November 2019, 22:26 | #260 | Link |
You can edit UsEac3to.au3 and compile or interpret with free tools https://www.autoitscript.com/site/autoit/downloads/
BTW down6 is already in 'Frequent parameters':
