8th June 2021, 00:14 | #24462 | Link |
Should this vulnerability be fixed in LAV Filters? Maybe in a nightly update?
https://nvd.nist.gov/vuln/detail/CVE-2021-33815 https://github.com/FFmpeg/FFmpeg/com...acfb4b1139a777 |
12th June 2021, 06:06 | #24464 | Link | |
CUVID still works best for our DVB broadcasts, but I understand it is deprecated by Nvidia. My question to Nev is do you plan to replace Cuvid with NVDec or similar, or will it just be removed? |
13th June 2021, 00:53 | #24467 | Link | |
Claims CUVID is now deprecated and replaced with NVDec, but I don’t really care what’s it’s called. I’d just like to have an equivalent deinterlacing solution to CUVID (as dxva2 is NOT the same as CUVID when using Lav filters now) |
13th June 2021, 02:46 | #24468 | Link |
they are the same there is absolutely zero chance they have coded 2 hardware decoder it's just buggy with DXVA2 you could try mpcVR with d3d11 VP support it may work better.
as said before nev had an idea where nvdec would work like d3d11 native and with deint support. it's done when it's done if he even works on it all. |
13th June 2021, 03:19 | #24469 | Link |
Relax Huhn,
I’m not making any demands, just would like to know what Nev might be planning for deinterlacing support (if anything). Whether it’s due to buggy dxva2 or not, lav with CUVID does not deinterlace the same as lav with dxva2. I’ve tried everything and they both deinterlace, usually very similarly, but definitely NOT the same. CUVID always does better on the fringe cases. I wish dvb would just switch to progressive so I never have to worry about interlacing again. I have posted these before, but here are two clips (and screenshots) that show what happens with DXVA2 deinterlacing. Neither issue happens with CUVID. I know one is an interlaced overlay and the other may have its own issues but CUVID deals with all the interlaced content I encounter while DXVA2 only deals with some. MadVR or EVR renderer - makes no difference. https://1drv.ms/u/s!AuEm8LURKbbGaa4F...W50Oc?e=gRDMWT Last edited by Calvi; 13th June 2021 at 06:22. |
13th June 2021, 17:18 | #24470 | Link | |||
It's a pity even modern 4K channels despite of progressive sometimes are 25p instead of 50p even on Euro2020(4x~92 MB, 4х29 seconds) https://transfiles.ru/pu0jw - to watch HLG with right colors on SDR monitor read my thread https://forum.doom9.org/showthread.php?t=176909 Quote:
I see the problem as on your screenshots only when I disable deinterlacing in LAV Video Decoder: PS. If I've got some free time I'm going to install Win10x64 21H1 to try D3D11 on my old computer with Athlon II x3 460 CPU. Last edited by VictorLS; 13th June 2021 at 21:13. |
13th June 2021, 19:15 | #24471 | Link | |
The problem with the powerball clip and DXVA is that when you disable that option, it deinterlaces the overlay with the balls correctly but does not do pulldown anymore, so progressive material broadcast in interlaced is lower quality. If you enable the option, it then does pulldown for progressive but if there is interlaced overlay like here it decides the image is till progressive and does not deinterlace.
13th June 2021, 21:24 | #24472 | Link | |
Btw I'm going to experiment with Ryzen 3 3200g with Vega graphics deinterlacing of H265 SD and HD quasi-interlaced channels soon so can anyone show how to disable Inverse Telecine in Adrenalin's Control Panel (and btw in modern Intel's Control Panel)? I don't care about it (I don't watch movies and so on from interlaced channels - I'd say I don't watch movies almost at all) but will appreciate examples how namely looks that lower quality. Last edited by VictorLS; 13th June 2021 at 22:05. |
14th June 2021, 06:20 | #24473 | Link | |
You are right, I did have IVTC switched on. DXVA is much closer to Cuvid with it switched off. But still not the same, Cuvid is OK with IVTC on while DXVA is not. I also tried the Cheese Slices from here (with both IVTC on and off): https://www.avsforum.com/threads/hd-...icker.1157287/ and the results are different for DXVA2 vs Cuvid with these as well (whether IVTC is on or off). DXVA2 Copy Back vs Native seem identical, but Cuvid gives an entirely different result (Seems slightly worse actually, but definitely different). I will say that with IVTC off and DXVA2 the Australian Broadcasts seem ok so I can probably live with this setup. Would still like to know what causes the difference though as it would seem having IVTC and deinterlacing working correctly would cover the most formats out there? Last edited by Calvi; 14th June 2021 at 07:18. |
14th June 2021, 08:46 | #24474 | Link | |
Seems that's why nevcairiel didn't want to do CUVID DXVA deinterlacing switchable for "broken streams" for a long time but I don't see difference. Btw I used Cheese Slices since 2009 for tests - i.e. at the end of 2009 I choose Samsung 40B652 PVA TVset (despite one broken dark subpixel) instead of identical LG IPS namely due to much more quality of deinterlacing Last edited by VictorLS; 14th June 2021 at 10:05. |
14th June 2021, 20:18 | #24477 | Link | |
With 30i it will completely mess up the 3:2 cadence and you'll see moiré and aliasing.
14th June 2021, 21:09 | #24478 | Link | |
el Filou
Thanks - will try to find described you artifacts in a future on movies on interlaced channels trying switch on/off "Use inverse telecine" in nVIDIA Control Panel Quote:
from 20210614-205013_TRT 4K.mkv (28 MB) https://transfiles.ru/cum1l It's a pity I didn't record from live translation of that match to see was interlace artifacts or not (I'm sure there wasn't artifacts). Last edited by VictorLS; 14th June 2021 at 21:14. |
14th June 2021, 21:18 | #24479 | Link |
Life's clearer in 4K UHD
Studio content has too many overlays, so it doesn't provide an accurate example. The actual game play would be better... But it looks progressive to me!
16th June 2021, 21:36 | #24480 | Link |
I use Kodi DSPlayer as my main player... today I've finally managed to get a RTX3070, preparing for when my new 4K TV will be here.
As such I have tried playing back some 4K HDR files (tonemapped through madVR). Initially I got all strange colors, blocks, general crap... At first I did not understand, then I realized that I had tried, years ago, to decode through the Lentoid HEVC decoder, as an experiment. I removed that from my system aaaand... there is pretty much no way I can get LAV Video to be used to decode HEVC. I have unregistered Lentoid, I have selected LAV Video, nothing... video starts but there is sound and no video. I tried with both MPC-HC and MPC-HC BE and even though I deselect the internal filters and place LAV Video as preferred, they both fall back to the internal filter (MPC-HC stating "Lav Video (internal low merit)"). It's as if LAV is not usable for HEVC (HEVC is selected in configuration). I have upgraded to 75, downgraded to 74.1, reupgraded to 75, nothing changed. I restarted the machine too (Windows 10 x64). |
