16th May 2021, 14:44 | #41 | Link |
I hope I didnīt talk you into too much work Really appreciate this addition, thanx !!
My amateur suspection is, that the ...GAN folders should be somehow reduceable in size (since some other similar implementations come in smaller packages), but my skills are far from doing that |
16th May 2021, 15:11 | #42 | Link |
Yeah, my guess too is that one probably can delete some of the large cuda files inside VapourSynth64\Lib\site-packages\torch\lib since probably not all are needed, but haven't tested and probably won't spend time on it.
If someone has the time and motivation to test which dlls are really needed let me know. Cu Selur |
12th June 2021, 08:42 | #43 | Link |
Just wondering: Can the .params&.json files from https://github.com/WolframRhodium/Super-Resolution-Zoo
be used in VSGAN somehow? Cu Selur |
29th July 2021, 20:57 | #44 | Link |
I have installed VSGAN yesterday on windows, and the installation seems to have gone smoothly, but when I try the example script from the documentation, I receive this error:
raise EnvironmentError(f"VSGAN: Either NVIDIA CUDA or the device ({device}) isn't available.") OSError: VSGAN: Either NVIDIA CUDA or the device (cuda) isn't available. Last edited by Zarxrax; 29th July 2021 at 22:03. |
30th July 2021, 20:05 | #46 | Link |
You can check cuda support with gpuz.
19th August 2021, 15:10 | #49 | Link |
Can't do 1080p to 2160p with my Geforce GTX 1070ti (8GB VRAM) even when using a the 2x_PSNR model, when using one of the models with a 4x resize factor my guess it that you at least need a 30xx card with 12GB or more VRAM.
19th August 2021, 15:40 | #50 | Link | |
When using decent size margins, you don't see any seams or artifacts (but they are "microscopically" detected with amplified differences) |
4th October 2021, 19:01 | #52 | Link |
Hmm, wrote a small script that splits an image into tileCount*tileCount tiles and applies vsgan on each of them.
import vapoursynth as vs from vapoursynth import core from vsgan import VSGAN import torch # clip: the video source # model: path to the model to callable # tileCount number of times source will be splitt horizontally and vertically def tileVSGAN(clip, tileCount = 8, model = None) -> vs.VideoNode: if not isinstance(clip, vs.VideoNode): raise vs.Error('tileVSGAN: clip must be an instance of vs.VideoNode') if clip.format.id != vs.RGB24: raise vs.Error('tileVSGAN: clip must be RGB24') if model == None: raise vs.Error('tileVSGAN: model needs to be specified') if tileCount%2 != 0: raise vs.Error('tileVSGAN: tileCount needs to dividiable by 2.') if clip.width%(tileCount*2) != 0: raise vs.Error('tileVSGAN: clip.width must be dividable by 2*tileCount without rest') if clip.width%(tileCount*2) != 0: raise vs.Error('tileVSGAN: clip.height must be dividable by 2*tileCount without rest') tileWidth = clip.width/tileCount tileHeight = clip.height/tileCount tiles = [[None for x in range(tileCount)] for y in range(tileCount)] for index1 in range (tileCount): # vertical for index2 in range (tileCount): # horizontal tile = core.std.CropRel(clip=clip, left=tileWidth*index2, right = tileWidth*(tileCount-index2-1), top=tileHeight*index1, bottom=tileHeight*(tileCount-index1-1)) #tiles[index1][index2] = core.text.Text(clip=tile,text=str(index1)+'/'+str(index2),scale=1) # apply VSGAN on each tile for index1 in range (tileCount): # vertical for index2 in range (tileCount): # horizontal vsgan = VSGAN("cuda") vsgan.load_model(model) tiles[index1][index2] = vsgan.run(clip=tiles[index1][index2]) del vsgan # delete vsgan object torch.cuda.empty_cache() # trigger pytorch to free gpu memory cache horizontal = [None for x in range(tileCount)] for index in range (tileCount): horizontal[index] = core.std.StackHorizontal(tiles[index]) clip = core.std.StackVertical(horizontal) return clip Problem is that is doesn't seem to work, even with tileCount 64 on 4k content all my 8GB VRAM is full. :/ Cu Selur |
5th October 2021, 02:02 | #53 | Link |
unfortunately I do not have VSGAN to test it, but what about this, trying to process one clip at a time, put it more into functions so things get garbage collected:
def clipVSGAN(clip, model): vsgan = VSGAN("cuda") vsgan.load_model(model) new_clip = vsgan.run(clip=clip) del vsgan # delete vsgan object torch.cuda.empty_cache() # trigger pytorch to free gpu memory cache return new_clip def tileVSGAN(clip, tileCount = 8, model = None) -> vs.VideoNode: if not isinstance(clip, vs.VideoNode): raise vs.Error('tileVSGAN: clip must be an instance of vs.VideoNode') if clip.format.id != vs.RGB24: raise vs.Error('tileVSGAN: clip must be RGB24') if model == None: raise vs.Error('tileVSGAN: model needs to be specified') if tileCount%2 != 0: raise vs.Error('tileVSGAN: tileCount needs to dividiable by 2.') if clip.width%(tileCount*2) != 0: raise vs.Error('tileVSGAN: clip.width must be dividable by 2*tileCount without rest') if clip.width%(tileCount*2) != 0: raise vs.Error('tileVSGAN: clip.height must be dividable by 2*tileCount without rest') def fetch_new_tile(clip, tileWidth, tileHeight, tileCount): for index1 in range (tileCount): # vertical for index2 in range (tileCount): # horizontal tile = core.std.CropRel(clip = clip, left = tileWidth*index2, right = tileWidth*(tileCount-index2-1), top = tileHeight*index1, bottom = tileHeight*(tileCount-index1-1) ) yield clipVSGAN(tile, model) del tile tileWidth = clip.width/tileCount tileHeight = clip.height/tileCount tiles = [[None for x in range(tileCount)] for y in range(tileCount)] new_tile_generator = fetch_new_tile(clip, tileWidth, tileHeight, tileCount) for index1 in range (tileCount): for index2 in range (tileCount): tiles[index1][index2] = next(new_tile_generator) horizontal = [None for x in range(tileCount)] for index in range (tileCount): horizontal[index] = core.std.StackHorizontal(tiles[index]) clip = core.std.StackVertical(horizontal) return clip Last edited by _Al_; 5th October 2021 at 03:59. |
5th October 2021, 14:31 | #54 | Link |
There are several tiling scripts with variable input size and padding/margins out there
eg https://github.com/Oriode/ESRGAN-Til...ter/upscale.py They just need to be "massaged" into vapoursynth form . Several of HolyWu's scripts have tiling/padding too. HolyWu could probably add it easily |
5th October 2021, 18:00 | #55 | Link |
@_Al_: doesn't seem to behave differntly
RuntimeError: CUDA out of memory. Tried to allocate 2.00 MiB (GPU 0; 8.00 GiB total capacity; 6.75 GiB already allocated; 0 bytes free; 6.90 GiB reserved in total by PyTorch) Cu Selur |
5th October 2021, 21:34 | #56 | Link |
https://github.com/rlaphoenix/VSGAN/...an/__init__.py
PRAGMA had implemented that already, his parameter chunk in run() Code:
def run(self, clip: vs.VideoNode, chunk: bool = False) -> vs.VideoNode: Code:
def chunk(self, clip: vs.VideoNode) -> Iterable[vs.VideoNode]: """ Split clip down the center into two clips (a left and right clip) Then split those 2 clips in the center into two clips (a top and bottom clip). Resulting in a total of 4 clips (aka chunk). """ return itertools.chain.from_iterable([ self.split(x, axis=1) for x in self.split(clip, axis=0) ]) then he is reassembling clips doing this: Code:
# if chunked, rejoin the chunked clips otherwise return the result clip = core.std.StackHorizontal([ core.std.StackVertical([results[0], results[1]]), core.std.StackVertical([results[2], results[3]]) ]) if chunk else results[0] but there is a concern, because that poissondeathray link workflow uses margins, which they are cut off before assembling tiles, probably if not done, borders could be visible with some artifacts Last edited by _Al_; 5th October 2021 at 21:44. |
6th October 2021, 21:35 | #58 | Link | |
I could probably work on adding some black padding fairly easily to each one, and then crop if that works well enough. I see selur made an issue post asking for it, so if I ever work on it I will push updates there. https://github.com/rlaphoenix/VSGAN/issues/9 |
6th October 2021, 21:43 | #59 | Link |
I updated the Installation docs page to add some small information about how to use python/pip on a portable installation. Some users here struggled with that.
I also created a new troubleshooting page with some solutions or advice to problems posted in pages 2 and 3. |
esrgan, gan, upscale, vapoursynth |
