Old 13th January 2011, 19:46   #10921  |  Link
Thanks. Hopefully I'll be able to figure it out from "Case 39".
Old 13th January 2011, 20:40   #10922  |  Link
omegaman7
omegaman7's Avatar
I just backed up "A-Team". I used the custom output size of 23500, and got 22.9Gb(24,607,336,840 bytes). Excellent! Now if it can just average this LOL!
Old 13th January 2011, 20:42   #10923  |  Link
Since that's also the default, why use "Custom"? Just select "BD-25".
Old 13th January 2011, 20:47   #10924  |  Link
omegaman7
omegaman7's Avatar
Default I was averaging 22.4 - 22.5, and noticing(visually) that a significant amount of the disk was not being used. I assumed the default was smaller than that. But if you say it is 23500(0.37.01), I'll just go with the default setting. I was probably getting undersizing for unknown reasons.
The first time I ran the custom setting, I set it for 23450, and had a marginal increase in output size. I guess it was coincidence
Old 13th January 2011, 22:15   #10925  |  Link
Dirk Diggler
I use 24600 (usually comes in at 99%) for all my movie only encodes and BD-25 for full backups which are usually Season Episode disc
Dirk Diggler is offline   Reply With Quote
Old 13th January 2011, 22:24   #10926  |  Link
That's been the default since v0.36.01. If you set it to a lower number and got an increase -- then it's likely you changed some other setting -- because the exact same code is executed regardless of the size. Usually any variation would be in audio selections, because they are a little more unpredictable in their muxing overhead (example: a 192Kbs AC3 can often take the same or more space than a 224Kbs one).
Old 13th January 2011, 22:34   #10927  |  Link
omegaman7
omegaman7's Avatar
When I tried the 23450, it was with a new encode(And was unaware of the default size). Had I left it at default for that disk, it likely would have been larger. I only do a Re-encode if there is something seriously wrong. Or if somebody asks me to test something. At an average job time being 7 - 9hrs, it's irritating to have to re-encode something. Not really complaining here. I understand the term beta. I love new toys, and playing with them
Old 13th January 2011, 23:13   #10928  |  Link
cnote
cnote
failed encode with the latest release
I can't seem to figure this one out. Things have been going extremely well. This is my first try with the latest release. I appreciate the help!
[21:21:52] BD Rebuilder v0.37.01 (beta)
- Source: 21
- Input BD size: 33.65 GB
- Approximate total content: [02:02:41.354]
- Target BD size: 7.84 GB
- Windows Version: 6.1 [7600]
- MOVIE-ONLY mode enabled
- Quality: High Quality (Default), Two Pass
[21:21:52] PHASE ONE, Encoding
- [21:21:52] Extracting A/V streams [VID_00011]
- [21:39:08] Reencoding: VID_00011 (1 of 1)
- [21:39:08] Collecting video information
- Rate/Length: 23.976fps, 176,496 frames
- Bitrate: 7,754 Kbs
- [21:39:08] Reencoding: VID_00011, Pass 1 of 2
- Encode failed. Retrying.
- Reached retry limit. Aborting.
- BD-Rebuilder v0.37.01 (beta)
- AVISYNTH Version: 2.5.7.0, Ok
- HAALI Splitter: Ok
- FFDSHOW: 3326, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
[21:39:13] - Failed video encode, aborted
cnote is offline   Reply With Quote
Old 14th January 2011, 00:36   #10929  |  Link
Capsbackup
Apparently something was changed for your decoding AVC video. Can you play the VID_00011.avs file BD-RB created in the Workfiles folder with MPC?
Usually a simple uninstall of Haali and ffdshow and then reinstall them will fix this.
Old 14th January 2011, 00:59   #10930  |  Link
Mr. Movies
I believe I’m encountering Cinavia protection problems as they are the same issues I find on known releases of Movies with Cinavia and I don’t seem to have problems with anything else. My system checks out OK and I don’t have any Codecs outside of the required ffdshows. I’ve even done a clean system reinstall thinking there may be some issues not apparent. So I’m curious if this is Cinavia or a possible issue in BD-RB but another reason I don’t think it is BD-RB is that I’ve used the not so good DVDFab8 and it produces the same problems, so the only other variable here is AnyDVDHD.
Problem:
If I rip the following titles and keep the HD Audio & DTS I have problems with the BD25’s losing audio and freezing in spots of the movies. It tends to be anywhere from 10minutes to 20minute intervals. I can fast forward a frame or two and it picks up again fine. Also the timer will stop and won’t always pick up again. If I play the BD25 rip with TMT3 it plays fine and TMT3 doesn’t have Cinavia protection scheme in it.
The problem is lessened when I choose to transcode and convert the DTS to AC3 and was even better when I unchecked the only use one language audio feature, which I didn’t like anyway as I wanted the directors commentary on track 4 instead of dup’n track 1 to track 4.
With Gladiator (2 disc) Sapphire Edition at 10:03 on the extended version and DTS intact it always drops out audio, glitches a bit, and then freezes until I fast forward a bit and then it is fine other than possibly the timer remaining froze. If I convert audio to AC3 then it glitches just slightly, hardly noticeable, and keeps playing until the next point of concern at 32:51 were it will probably freeze but most certainly the timer will freeze even if the audio/video doesn’t. When that happens if I fast forward it jumps back to the timer freeze point and continues on from there. Here are some of the points that the movie has problems in;
Gladiator Extended Version
10:03
32:51
54:10
1:10:18
1:21:39
I stopped here but the 10min marker is like clockwork but will play through when using AC3 where the later points are more apt to freeze at.
Here are the titles I’ve encounter this problem with using my Cinavia firmware LG BD370V player;
Resident Evil: Afterlife 2D
Iron Man 2 (2 disc)
Iron Man (2 disc)
Toy Story 3 (2 disc)
I have no problems though with other new titles like Case 39 & Inception and have ripped over 100 BD’s with only having the VC1 problems way back when.
My BD Rebuilder Setup
Mode:
Full Backup
"Quicker" Encode for Extras
Settings:
Encoder - x264 Encoder
Output Options - Target Size BD-25
Encoder Settings - Idle Priority (Default) - Automatic Quality Settings
Verbose Status Reporting
Setup:
Audio Languages to Keep (set to ALL) - Limit to one track for each language (last rip this was unchecked)
Subtitle Language to Keep (set to ALL) - Limit to one track for each language
Video Encoding Options - (none checked in this section)
Audio Encoding Options - (none checked in this section)
General Encoding Options -
Strict AVCHD for BD-5/9 Movie-Only
NOTE: For the Setup section when I have the two following features selected is when I have DTS intact and encounter more issues with freezing and audio.
Do not convert DTS to AC3 (Blu-Ray only)
Keep HD Audio for BD25 encoding
BD-RB System Inspect
- FFDSHOW: 3326, Ok
- BD Rebuilder v0.36.0.9, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
LG BD370V Player
Main Ver: BD.8.08.027.B
Servo Ver: H51203
IO Micom Ver: 09063000
INF File for Log
DTS Audio INF File
Mr. Movies is offline   Reply With Quote
Old 14th January 2011, 01:20   #10931  |  Link
It's gotta be either the media or the burner -- most likely the media. There's also a remote possibility it could be the muxing from TSMUXER -- but if it were there'd be a lot of other people getting it too, and that's not happening. Of course it looks like you're keeping all languages and that's unusual. I would think though that the fact that you run into issues with DVDFab also makes muxing issues unlikely.
Try keeping only the audio languages you speak/understand and let me know how if it acts differently.
Sorry but I won't look at those "wait forever" links you've posted. I hate those things.
Cinavia has nothing to do with it.
Still think it's most likely media.
Old 14th January 2011, 01:26   #10932  |  Link
Mr. Movies
I've used two burners, and different media and the problem is always exactly the same, at the same points. I bought a new burner thinking the same as you.
AC3 Log INF
[Status]
LABEL=GLADIATOR_D1
VERSION=v0.37.01 (beta)
SOURCE_SIZE=47781799466
SOURCE_VIDEO_SIZE=46886111232
TARGET_SIZE=24641536000
REDUCTION=.506458035056517
RESIZE_1080=0
AUDIO_TO_KEEP=all
SUBS_TO_KEEP=all
BACKUP_MODE=0
MOVIEONLY_TYPE=0
USE_LAVF=0
QUICK=1
ENCODE_STEP=0
COMPLETED=85
REBUILD_COMPLETE=1
[00197]
AUDIO=1
PGS=1111
M2TS_TARGET=40452
NSTART=27000000
NEND=27011520
NSIZE=36864
FLINK=0
MLINK=0
[00189]
AUDIO=11
PGS=1111
M2TS_TARGET=43563
NSTART=27000000
NEND=27011520
NSIZE=49152
FLINK=0
MLINK=0
[00187]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=7558266
NSTART=27000000
NEND=28624320
NSIZE=4294656
FLINK=0
MLINK=0
[00111]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=12972586
NSTART=27000000
NEND=28752480
NSIZE=13062144
FLINK=0
MLINK=0
[00138]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=14357283
NSTART=27000000
NEND=28860480
NSIZE=13762560
FLINK=0
MLINK=0
[00130]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=14761801
NSTART=27000000
NEND=28922400
NSIZE=17166336
FLINK=0
MLINK=0
[00143]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=16009584
NSTART=27000000
NEND=29092320
NSIZE=17055744
FLINK=0
MLINK=0
[00126]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=19718705
NSTART=27000000
NEND=29573280
NSIZE=22425600
FLINK=0
MLINK=0
[00115]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=21523478
NSTART=27000000
NEND=29799360
NSIZE=23900160
FLINK=0
MLINK=0
[00117]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=22276504
NSTART=27000000
NEND=29894400
NSIZE=25466880
FLINK=0
MLINK=0
[00109]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=24283536
NSTART=27000000
NEND=30143520
NSIZE=24219648
FLINK=0
MLINK=0
[00131]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=25329060
NSTART=27000000
NEND=30274560
NSIZE=28944384
FLINK=0
MLINK=0
[00128]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=25693127
NSTART=27000000
NEND=30296160
NSIZE=29939712
FLINK=0
MLINK=0
[00108]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=26651524
NSTART=27000000
NEND=30360960
NSIZE=31850496
FLINK=0
MLINK=0
[00149]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=28599434
NSTART=27000000
NEND=30676320
NSIZE=33140736
FLINK=0
MLINK=0
[00144]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=31017208
NSTART=27000000
NEND=30994560
NSIZE=32649216
FLINK=0
MLINK=0
[00133]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=31574198
NSTART=27000000
NEND=31121280
NSIZE=38768640
FLINK=0
MLINK=0
[00110]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=31580422
NSTART=27000000
NEND=31036320
NSIZE=38780928
FLINK=0
MLINK=0
[00129]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=31801351
NSTART=27000000
NEND=31093920
NSIZE=33202176
FLINK=0
MLINK=0
[00236]
AUDIO=111111
PGS=1011100
M2TS_TARGET=31966545
RATE=11617
NSTART=27000000
NEND=27734400
NSIZE=30621696
FLINK=-1
MLINK=0
[00139]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=33280367
NSTART=27000000
NEND=31278240
NSIZE=41355264
FLINK=0
MLINK=0
[00141]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=33336274
NSTART=27000000
NEND=31299840
NSIZE=35985408
FLINK=0
MLINK=0
[00106]
AUDIO=111111
PGS=1011100
M2TS_TARGET=33419053
RATE=11520
NSTART=27000000
NEND=27773280
NSIZE=32464896
FLINK=-1
MLINK=0
[00228]
AUDIO=111111
PGS=1011100
M2TS_TARGET=34264944
RATE=11728
NSTART=27000000
NEND=27784800
NSIZE=33454080
FLINK=-1
MLINK=0
[00137]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=34398452
NSTART=27000000
NEND=31436640
NSIZE=31635456
FLINK=0
MLINK=0
[00132]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=34445024
NSTART=27000000
NEND=31443840
NSIZE=39892992
FLINK=0
MLINK=0
[00127]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=35124983
NSTART=27000000
NEND=31527360
NSIZE=42092544
FLINK=0
MLINK=0
[00136]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=35345426
NSTART=27000000
NEND=31573440
NSIZE=43468800
FLINK=0
MLINK=0
[00226]
AUDIO=111111
PGS=1011100
M2TS_TARGET=38797310
RATE=11875
NSTART=27000000
NEND=27875520
NSIZE=37005312
FLINK=-1
MLINK=0
[00123]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=39448844
NSTART=27000000
NEND=32140800
NSIZE=39677952
FLINK=0
MLINK=0
[00145]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=40115891
NSTART=27000000
NEND=32169600
NSIZE=39118848
FLINK=0
MLINK=0
[00119]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=40934963
NSTART=27000000
NEND=32276160
NSIZE=47603712
FLINK=0
MLINK=0
[00104]
AUDIO=111111
PGS=1011100
M2TS_TARGET=43282001
RATE=11695
NSTART=27000000
NEND=27992160
NSIZE=41213952
FLINK=-1
MLINK=0
[00148]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=43595302
NSTART=27000000
NEND=32616000
NSIZE=42584064
FLINK=0
MLINK=0
[00146]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=43741095
NSTART=27000000
NEND=32630400
NSIZE=48955392
FLINK=0
MLINK=0
[00233]
AUDIO=111111
PGS=1011100
M2TS_TARGET=44893912
RATE=11834
NSTART=27000000
NEND=28016640
NSIZE=42964992
FLINK=-1
MLINK=0
[00112]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=45362267
NSTART=27000000
NEND=32819040
NSIZE=46854144
FLINK=0
MLINK=0
[00122]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=45371572
NSTART=27000000
NEND=32842080
NSIZE=49367040
FLINK=0
MLINK=0
[00113]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=46004318
NSTART=27000000
NEND=32922720
NSIZE=52303872
FLINK=0
MLINK=0
[00125]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=46950334
NSTART=27000000
NEND=33046560
NSIZE=42860544
FLINK=0
MLINK=0
[00116]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=48972638
NSTART=27000000
NEND=33291360
NSIZE=60905472
FLINK=0
MLINK=0
[00229]
AUDIO=111111
PGS=1011100
M2TS_TARGET=51794563
RATE=11558
NSTART=27000000
NEND=28193760
NSIZE=49975296
FLINK=-1
MLINK=0
[00120]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=51847250
NSTART=27000000
NEND=33698880
NSIZE=66920448
FLINK=0
MLINK=0
[00114]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=52265648
NSTART=27000000
NEND=33727680
NSIZE=62717952
FLINK=0
MLINK=0
[00135]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=52358625
NSTART=27000000
NEND=33734880
NSIZE=61556736
FLINK=0
MLINK=0
[00230]
AUDIO=111111
PGS=1011100
M2TS_TARGET=53193894
RATE=11555
NSTART=27000000
NEND=28226880
NSIZE=51406848
FLINK=-1
MLINK=0
[00118]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=53382667
NSTART=27000000
NEND=33883200
NSIZE=53366784
FLINK=0
MLINK=0
[00121]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=53815918
NSTART=27000000
NEND=33953760
NSIZE=64253952
FLINK=0
MLINK=0
[00227]
AUDIO=111111
PGS=1011100
M2TS_TARGET=54224776
RATE=11814
NSTART=27000000
NEND=28234080
NSIZE=52801536
FLINK=-1
MLINK=0
[00140]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=62252233
NSTART=27000000
NEND=35023680
NSIZE=68825088
FLINK=0
MLINK=0
[00147]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=62638912
NSTART=27000000
NEND=35117280
NSIZE=74397696
FLINK=0
MLINK=0
[00134]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=64296991
NSTART=27000000
NEND=35285760
NSIZE=63774720
FLINK=0
MLINK=0
[00142]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=72494587
NSTART=27000000
NEND=36336960
NSIZE=73949184
FLINK=0
MLINK=0
[00107]
AUDIO=111111
PGS=1011100
M2TS_TARGET=74239976
RATE=11414
NSTART=27000000
NEND=28735200
NSIZE=71774208
FLINK=-1
MLINK=0
[00220]
AUDIO=111111
PGS=1011100
M2TS_TARGET=81587061
RATE=11765
NSTART=27000000
NEND=28859040
NSIZE=78379008
FLINK=-1
MLINK=0
[00207]
AUDIO=111111
PGS=1011100
M2TS_TARGET=82248493
RATE=11668
NSTART=27000000
NEND=28879200
NSIZE=79626240
FLINK=-1
MLINK=0
[00204]
AUDIO=111111
PGS=1011100
M2TS_TARGET=91550258
RATE=11561
NSTART=27000000
NEND=29112480
NSIZE=88836096
FLINK=-1
MLINK=0
[00124]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=92833471
NSTART=27000000
NEND=38928960
NSIZE=103133184
FLINK=0
MLINK=0
[00231]
AUDIO=111111
PGS=1011100
M2TS_TARGET=106650966
RATE=11476
NSTART=27000000
NEND=29455200
NSIZE=102445056
FLINK=-1
MLINK=0
[00203]
AUDIO=111111
PGS=1011100
M2TS_TARGET=144575089
RATE=11443
NSTART=27000000
NEND=30346560
NSIZE=139825152
FLINK=-1
MLINK=0
[00216]
AUDIO=111111
PGS=1011100
M2TS_TARGET=156052381
RATE=11442
NSTART=27000000
NEND=30598560
NSIZE=149907456
FLINK=-1
MLINK=0
[00103]
AUDIO=111111
PGS=1011100
M2TS_TARGET=181032713
RATE=11897
NSTART=27000000
NEND=31095360
NSIZE=175484928
FLINK=-1
MLINK=0
[00205]
AUDIO=111111
PGS=1011100
M2TS_TARGET=198169675
RATE=11604
NSTART=27000000
NEND=31543200
NSIZE=191668224
FLINK=-1
MLINK=0
[00212]
AUDIO=111111
PGS=1011100
M2TS_TARGET=243070124
RATE=11494
NSTART=27000000
NEND=32650560
NSIZE=234190848
FLINK=-1
MLINK=0
[00234]
AUDIO=111111
PGS=1011100
M2TS_TARGET=281906275
RATE=11624
NSTART=27000000
NEND=33451200
NSIZE=271466496
FLINK=-1
MLINK=0
[00222]
AUDIO=111111
PGS=1011100
M2TS_TARGET=339506068
RATE=11595
NSTART=27000000
NEND=34790400
NSIZE=327118848
FLINK=-1
MLINK=0
[00232]
AUDIO=111111
PGS=1011100
M2TS_TARGET=381985079
RATE=11567
NSTART=27000000
NEND=35775360
NSIZE=368271360
FLINK=-1
MLINK=0
[00214]
AUDIO=111111
PGS=1011100
M2TS_TARGET=419396164
RATE=13032
NSTART=27000000
NEND=35781120
NSIZE=405282816
FLINK=-1
MLINK=0
[00217]
AUDIO=111111
PGS=1011100
M2TS_TARGET=475621872
RATE=11577
NSTART=27000000
NEND=37874880
NSIZE=458342400
FLINK=-1
MLINK=0
[00209]
AUDIO=111111
PGS=1011100
M2TS_TARGET=494035799
RATE=11566
NSTART=27000000
NEND=38312640
NSIZE=476921856
FLINK=-1
MLINK=0
[00213]
AUDIO=111111
PGS=1011100
M2TS_TARGET=547219231
RATE=11565
NSTART=27000000
NEND=39535200
NSIZE=528359424
FLINK=-1
MLINK=0
[00235]
AUDIO=111111
PGS=1011100
M2TS_TARGET=605072049
NSTART=27000000
NEND=46111680
NSIZE=460406784
FLINK=0
MLINK=0
[00218]
AUDIO=111111
PGS=1011100
M2TS_TARGET=633711787
RATE=11732
NSTART=27000000
NEND=41434560
NSIZE=610713600
FLINK=-1
MLINK=0
[00224]
AUDIO=111111
PGS=1011100
M2TS_TARGET=721781902
RATE=9384
NSTART=27000000
NEND=46683360
NSIZE=694321152
FLINK=0
MLINK=0
[00221]
AUDIO=111111
PGS=1011100
M2TS_TARGET=723757644
RATE=12252
NSTART=27000000
NEND=42932160
NSIZE=699113472
FLINK=-1
MLINK=0
[00198]
AUDIO=111111
PGS=1011100
M2TS_TARGET=880420825
RATE=12213
NSTART=27000000
NEND=46431360
NSIZE=849690624
FLINK=-1
MLINK=0
[00219]
AUDIO=111111
PGS=1011100
M2TS_TARGET=1108463947
RATE=11911
NSTART=27000000
NEND=51897600
NSIZE=1069916160
FLINK=-1
MLINK=0
[00223]
AUDIO=111111
PGS=1011100
M2TS_TARGET=1154935916
RATE=12050
NSTART=27000000
NEND=52833600
NSIZE=1113987072
FLINK=-1
MLINK=0
[00102]
AUDIO=111111
PGS=1011100
M2TS_TARGET=1244937137
RATE=12412
NSTART=27000000
NEND=54135360
NSIZE=1200979968
FLINK=-1
MLINK=0
[00206]
AUDIO=111111
PGS=1011100
M2TS_TARGET=1293950199
RATE=12069
NSTART=27000000
NEND=55762560
NSIZE=1248878592
FLINK=-1
MLINK=0
[00215]
AUDIO=111111
PGS=1011100
M2TS_TARGET=1579239998
RATE=12485
NSTART=27000000
NEND=61241760
NSIZE=1524910080
FLINK=-1
MLINK=0
[00208]
AUDIO=111111
PGS=1011100
M2TS_TARGET=1632315964
RATE=13286
NSTART=27000000
NEND=60570720
NSIZE=1576611840
FLINK=-1
MLINK=0
[00105]
AUDIO=111111
PGS=1011100
M2TS_TARGET=1742187679
RATE=12274
NSTART=27000000
NEND=65067840
NSIZE=1682294784
FLINK=-1
MLINK=0
[00210]
AUDIO=111111
PGS=1011100
M2TS_TARGET=2064521142
RATE=12825
NSTART=27000000
NEND=70768800
NSIZE=1993156608
FLINK=-1
MLINK=0
[00201]
AUDIO=111111
PGS=1011100
M2TS_TARGET=2674784726
RATE=13088
NSTART=27000000
NEND=82788480
NSIZE=2582728704
FLINK=-1
MLINK=0
Old 14th January 2011, 01:34   #10933  |  Link
Use the "code" feature to wrap your text (it's the "#" symbol above where you'r typing when you're composing a reply) and it will make it a lot easier to read. I just did it with an edit of your post. Looks better, eh?
Try not keeping so many languages.
Old 14th January 2011, 01:41   #10934  |  Link
Mr. Movies
I'll try it with just the English main and directors comments track 4.
Sorry about the code thing I normally don't miss that.
Old 14th January 2011, 01:44   #10935  |  Link
I was just thinking that since it is rare that people keep more than a couple audio tracks (to improve video quality) there's always a chance that TSMUXER might be having trouble with it.
In fact... could you list the audio tracks so I can make a guess as to their total combined bitrate?
Old 14th January 2011, 01:48   #10936  |  Link
Mr. Movies
I have friends that speak Spanish so I typically like to keep that and since I'm not close to Quebec or the French Quarter here in the US I don't care about French.
I've restarted it with just English but am allowing multiple english channels. I hope that won't cause issue but I can always limit the Audio to one language if need be.
Original Audio Tracks are as follows:
T1 - English 5.1 DTS-HD Master Audio
T2 - French 5.1 Dolby Digital
T3 - Spanish 5.1 Dolby Digital
T4 - DD 2ch Commentary by Director Ripley Scott
Old 14th January 2011, 01:58   #10937  |  Link
My thinking is that the combined bitrate of all the audios (especially when keeping HD) might be challenging the mux... or possible the total bitrate is too high causing the freeze. Just guessing...
These types of things might sometimes only show up on certain players (depending on internal buffering).
Old 14th January 2011, 02:02   #10938  |  Link
Mr. Movies
That's a definate possiblity and would be a good reason why keeping the DTS doesn't work well compared to converting the audio to AC3. But when converting to AC3 I still encounter problems so do you thing it is still the high bandwidth and tsmuxer? It could be my player as it doesn't have a huge buffer but it can play the original fine so that seems odd to me, I'm not saying it isn't so though.
Old 14th January 2011, 02:22   #10939  |  Link
Capsbackup
Is your PC overclocked? I have done Gladiator and other movies where I have kept the main HD audio and 2-3 commentary tracks, and have never had an issue when playing back on my Sony S360.
Old 14th January 2011, 02:33   #10940  |  Link
HWK
HWK's Avatar
I did Resident evil afterlive with all audio and subtitle included as well and encounter no such problem.
