22nd February 2016, 00:30 | #36341 | Link |
Also volume OSD is not visible anymore. It just shows the background.
Edit: Looks like the white text comes back in "low latency" mode for some reason. As soon as the Present queue goes up it turns black again and for volume OSD turns transparent. Last edited by FDisk80; 22nd February 2016 at 00:37. |
22nd February 2016, 00:37 | #36342 | Link | |
I thought it had something to do with timings not playing well if one of the monitors had a high (120, 144Hz) refresh rate and happened to be the one the movie was played on... It could've also just been a wild guess at that time. I myself happen to have a 120Hz monitor and I use a projector for movies. Playing @120Hz on the monitor never really worked for me without a lot of visible jerking and judder as well as tons of presentation glitches. The only thing that helped was going back to old path and playing around with the number of backbuffers used. That issue (for me) dates back to when the new render path was introduced. I've never tried upping the GPU queue though, so far I am auto-changing to 60Hz - minor annoyance... Greetz, Unr3aL67 |
22nd February 2016, 01:01 | #36343 | Link | |
22nd February 2016, 01:02 | #36344 | Link |
Image Upscaling JincAR+SL
SOrry for the noob question but for what use is the scale in sigmoidal light in Image Upscaling?
I don't see any noticeable changes in PQ with it on but I notice some slight decrease in performance. And also I'm using the latest version which is v0.90.11 and I experience black colored fonts in the subs and ctrl+j. and also ctrl+j reports that I'm still using Lanzcos3AR even if I selected JincAR as my Image Upscaler so what gives?? |
22nd February 2016, 01:08 | #36345 | Link | |
22nd February 2016, 01:37 | #36346 | Link |
Hey madshi i tried to test supersampling on 720p content on my 1360x768 screen, the doubling is working but upscaling refinements not, no matter what sharpen algo i check dont do any diference on image and on osd don't affect the render times... Same with super resolution!
I even tried to check all the upscaling refinements but has no changes on picture and render times... Remember that on last month i asked why upscaling refinements not working on 720p on 1360x768 screens. You said that because upscaling was very little so upscaling refinements are not activated I was thinking if somewow this can be relate to that (supersampling upscaling refinements not activated because the Target resolution is the same or very near the movie original resolution) By the way thank you again for madvr, every week we get a better picture quality! Its very impressive!
Desktop, i5 2500, 8GB, N570 GTX TF III PE/OC Asus X555LF, i7-5500U, 6GB Ram, Nvidia 930m/HD 5500 Windows 8.1 Pro x64 Last edited by CarlosCaco; 22nd February 2016 at 02:23. |
22nd February 2016, 03:06 | #36347 | Link |
what does this mean? that normal BD playback on a 1080p screen now looks better with all this applied than when just viewing the movie normally?
22nd February 2016, 03:42 | #36348 | Link |
Updated to the newer version and after a while with no problems it gave me the same error.
I used the debug mode to create the log, it created a 69MB file and i compressed it to 3mb and uploaded to mega. Steps i did, opened an episode, went fullscreen, skipped 1, skipped 2 and it gave me the black screen i said earlier, hit esc to exit fullscreen and closed mpc. this is the link: https://mega.nz/#!tAIVEIoL!YjThiXXYo...2yv0isJBuGLuGU thanks in advance. |
22nd February 2016, 04:15 | #36349 | Link |
Potentially yes. The algorithms have a larger image to work on that gets downscaled so the end result should look neater than them being applied to a straight 1080 image.. Then you get the visual benefits of downscaling from one of madVR's HQ downscalers. Essentially you'll be getting as close to 4k as you can get on your full HD screen with today's readily available full HD content.
22nd February 2016, 04:28 | #36350 | Link | |
it is clearly against the creators intent and a good source doesn't need sharpening. |
22nd February 2016, 04:47 | #36352 | Link |
ya same issue here the Ctrl-J OSD stats are black unless the video is paused then it turns white. also as he said something wrong with the volume OSD just showing black rectangle as well.
also if i use the "show name of media files" in the OSD options on MPC-BE is just shows up as a black rectangle when the player opens as well with no white text inside where the filename should b inside the black/grey rectangle |
22nd February 2016, 05:29 | #36354 | Link | |
it's not mastered to be watched this way. whatever someone does with the image is up to the user. if they want to watch it the correct way or in vivid mode is there choice. |
22nd February 2016, 05:38 | #36355 | Link |
Is there any way to set up a profile based on what resizer is used? For example: If you only wanted to use a post processing sharpener if Jinc AR was used as an upscaler.
Intel i5 3470, EVGA GTX 1050Ti SC ACX 2.0, Windows 10 Pro 64 bit, 16 GB 1600 mhz DDR3 RAM |
22nd February 2016, 05:39 | #36356 | Link | |
QB the Slayer
QB
22nd February 2016, 06:06 | #36359 | Link |
for of all you need a profile that is using jinc3AR when the conditions are meet and this profile is using the correct image refinement.
so the first step is creating profiles that are jinc when you want to use jinc. so you are not setting up a profile depending on the resizer you make sure the correct resizer is used with the correct image refinement. same result different approach. |
22nd February 2016, 06:09 | #36360 | Link | |
The content creator did not plan for poor lighting conditions, bad captures, source compression or many other things that go into producing a Blu-ray or broadcast TV series. Image sharpening can bring out detail that is in the source but is hard to see on a typical display without making it look unnatural. However, I'd like to see what supersampling looks like compared to applying light sharpening to the unscaled source.
