25th March 2016, 09:24 | #37142 | Link | |
QB the Slayer
I know of one scene in The Big Short where it happens, if I have time I will track down which driver introduced this. QB
25th March 2016, 09:42 | #37143 | Link | |
Visual Novel Dev.
Edge thinning alone would make things too thin. I like the effects of ET 8 + ES 4 + AB150 + AR on both background and foreground elements. Though too much edge thinning might change the meaning of some scenes, it is worth it. Especially where are lots of thick black lines. But it improves more!
25th March 2016, 09:51 | #37144 | Link |
Hi and thanks for the work you do here. Does someone has an AMD R9 380 nitro oc 4 go and have lot of lags and drop frames when super res x2 anti bloating and AR are activated ?
25th March 2016, 10:06 | #37145 | Link |
Visual Novel Dev.
How do we use profiles?
I am still having a hard time understanding where to start.
25th March 2016, 12:41 | #37146 | Link |
25th March 2016, 12:45 | #37147 | Link | |
http://screenshotcomparison.com/comparison/166725 it can be way way more harmful then this BTW. but as you pleases. |
25th March 2016, 13:05 | #37148 | Link | |
I find even 4.0 is actually too high for anime but it works beautifully on just thick lines though, but too many unwanted side effects, hence why I keep it at ~2.0 + Awarpsharp. I certainly would not use high values on 1080 content. Works quite well on 480-720 though. Last edited by ryrynz; 25th March 2016 at 13:08. |
25th March 2016, 13:35 | #37149 | Link |
it's not scaled at all.
even 2.0 with a 2x scaling is starting to deform. of cause it looks kind of perfect compared to 8.0. i personally wouldn't go over 0.5 on FHD and 1.0 on UHD(ok UHD is hard to judge). but like always i don't like to change the picture. so nothing new. |
25th March 2016, 14:05 | #37150 | Link | |
Visual Novel Dev.
I think that it is better for many anime out there. Why did it induce aliasing for you? On my setup it eliminates any aliasing that was there before. I am confused. There are very few anime that are 1080 natural, most are lower resolution, even if they are encoded to 1080.
25th March 2016, 14:13 | #37151 | Link |
destroy it your self: http://abload.de/img/00004.m2ts_snapshot_0wju9u.png
sharp edges and line thinning are for sure not hiding aliasing. |
25th March 2016, 14:17 | #37152 | Link | |||||||||
My point in our discussion over the last 3 posts or so is that I consider the sharpening strength and the anti-bloating strength to be independent settings. You can think of the anti-bloating strength to be a slider which changes the sharpening "look". Basically at 0% anti-bloating you get 100% AdaptiveSharpen. If you go to 100% anti-bloating, you get something which looks more like crispen edges. If you use 50% anti-bloating, you get something in between AdaptiveSharpen and crispen edges, so to say. So if you decrease both sharpening strength and anti-bloating strength, you're not achieving a similar end result. Decreasing both sharpening strength and anti-bloating strength at the same time basically changes both the look and the strength of the sharpening (so you get less strong but more bloated sharpening). Quote:
I guess at some point I should probably check if I'm running out of GPU RAM. <sigh> So many things to do... Quote:
25th March 2016, 14:43 | #37153 | Link |
madVR v0.90.17 released
http://madshi.net/madVR.zip Code:
* added a couple of image doubling super-xbr anti-bloating options * fixed: "relaxed" vs "strict" option wasn't properly hidden for upscaling Keep the feedback coming! |
25th March 2016, 14:45 | #37154 | Link |
Hi madshi, I was watching a tv show last night and I got a black screen with 90.16 even with default queues, so I remember that a user said a few posts ago that D3D11 presentation was broken on nvidia and I think it is true (maybe it is a driver problem, I really don't know if it is realted to madVR). I changed to D3D9 presentation and watch 2 more episodes after that and everything was ok.
I would also like to share a nice 4k image to test downscaling: https://imgur.com/6EVXKDB It is a China building with detailed lines everywhere, and the fine details int he roof are perfect for testing downscaling. |
25th March 2016, 15:00 | #37155 | Link | |
but i thought upscaling and sharpening is totally different. super xBR 150 is very cheap and effective but it has some serious issue. but not working great i would say edit: nope i'm totally wrong here. i'm using FHD to UHD: edit:i had crisp edges at 4.0 disabling it fixed it. i played to much around sorry. still a strange artifact. source: http://abload.de/img/00004.m2ts_snapshot_0wju9u.png the images are to big so i have to use a file host. http://www.file-upload.net/download-...perxBR.7z.html it is double lining at the leg. edit2: it looks like it is anti aliasing but takes some power/color from lines. the anti aliasing effect is very welcome and the power/color is not that strong. so i think it is an improvement. super xBR anti bloating: 75 looks most promising. edit: fixed some things... i'm out for today. i'm just confusing my self and the rest. Last edited by huhn; 25th March 2016 at 15:21. |
25th March 2016, 15:12 | #37156 | Link | |
So after dialing down crispen edges, how do you like it? And which serious issues does super-xbr have in your opinion? |
25th March 2016, 15:18 | #37157 | Link |
super xBR 150 has seroius issue not super xBR in general.
some bright colors around dark lines for example. there is no anti bloat 150 anyway. i edit the post. super xBR 75 anti bloat looks very promising! i was using 75 normal before. |
25th March 2016, 15:20 | #37158 | Link | |
25th March 2016, 15:35 | #37159 | Link |
Is there any guide on how to take screenshots for making comparisons, I tried using the save image option from MPC-BE but the final image is really small if you take it from a dvd resolution movie for example. Thanks in advance.
25th March 2016, 15:40 | #37160 | Link | |
if you do this in full screen the full screen picture is save in your clip board. now open a picture program like paint/paint.net and press control+v. you can now save the image. Last edited by huhn; 25th March 2016 at 16:08. Reason: you can know same the image.... |
