3rd February 2012, 19:11 | #11981 | Link |
Hope somebody can give me a suggestion.
I like the MadVR renderer but one thing I'm missing is the shapen complex 2 shader option in MPCHC. Is there a way to get this feature back or an alternative way of accomplishing the same thing? Thanks in advance. |
4th February 2012, 00:46 | #11982 | Link |
If you can use the same shader/use a function with the same effect in avisynth you can run the avisynth script using your media player that uses madVR and it will send the video with the effect done to it to the player.
4th February 2012, 09:20 | #11983 | Link | |
AV heretic
If your video is smaller than screen size you can try a "sharper" luma scalers - spline, lanczos. |
4th February 2012, 16:06 | #11984 | Link | |
4th February 2012, 16:38 | #11985 | Link |
madshi,
Any updates on any new version of madvr?
SETUP: Win 10/MPC-HC/LAV/MadVR HARDWARE: Fractal Design Node 804 | Xeon E3-1260L v5 | Supermicro X11SSZ-TLN4F | Samsung 2x8GB DDR4 ECC | Samsung 850 EVO 1TB | MSI GTX 1650 Super | EVGA G2 750 |
4th February 2012, 18:43 | #11986 | Link | |
For lower resolution stuff, madvr is clearly superior and all i want is that slight boost in sharpness that I prefer. Last edited by PrayForMojo; 4th February 2012 at 18:53. |
4th February 2012, 18:45 | #11987 | Link | |
I must tell you that I read up some guides online and some of the avisynth stuff is way over my head. |
4th February 2012, 21:19 | #11988 | Link |
btw, I switched to madvr + ffdshow and in ctrl+j it says i'm correctly playing hi10p videos with 10bit and P010 color output, is that really so? Do I need LAV anyway or all is fine?
4th February 2012, 21:59 | #11989 | Link |
get used to it, development and updates of madshis products stretches over a few years of time. there are long periods with no apparent progress (for us).
Laptop Lenovo Legion 5 17IMH05: i5-10300H, 16 GB Ram, NVIDIA GTX 1650 Ti (+ Intel UHD 630), Windows 10 x64, madVR (x64), MPC-HC (x64), LAV Filter (x64), XySubfilter (x64) (K-lite codec pack) Last edited by Thunderbolt8; 4th February 2012 at 22:04. |
5th February 2012, 21:21 | #11992 | Link |
I calibrate TV using native resolution 1360*768 (black bar at 16 in AVSHD709), I start madvr with 1080p23 (1920*1080 23,976 refrsh rate) in list all display mode and appers all black bars in AVS 709. It is normal ? In 1360*768 I use Video Levels in madVR options.
5th February 2012, 22:02 | #11993 | Link | |
6th February 2012, 18:49 | #11996 | Link | |
I don't know if the new mode is meant to be "universally better", but IIRC madshi said that it was meant to be even better regarding tearing (and maybe stuttering?) than the old one. What I know for sure is that windowed mode can also work well enough for some people and that with recent nvidia drivers the old mode is flawless regarding performance and smoothness while the new one suffers from constant presentation glitches (on my machine that is). |
6th February 2012, 19:50 | #11997 | Link | |
With the new mode I don't even dare to watch videos with very high bitrate, it's not an option. |
6th February 2012, 22:05 | #11998 | Link |
MadVR decoder does not play ball with ReClock. I get video stream not found. Note: I only use ReClock for PAL 'Film' speedown. Vsync is off. It would be nice if it worked alongside it. For now I use LAV Filters which work for most video. I think MadVR's decoders also don't work alongside ffdshow RAW filters from what I can tell. I guess my decoding needs are just too esoteric for MadVR to deal with.
6th February 2012, 22:06 | #11999 | Link |
madVRs decoders can't work with ffdshow raw or ReClock. Its just designed in such a way that its impossible. They are not separate decoders, they are directly included in madVR - you cannot hook anything in there, no ffdshow raw, and also not ReClocks video stream detector.
6th February 2012, 22:13 | #12000 | Link | |
The other ffdshow sharpen filters didn't agree with my eyes. LSF/LSFmod and SeeSaw are highly regarded avisynth sharpener's but they weren't usable on anything but SD even when using SetMTMode, too many dropped frames. |
