20th April 2012, 11:04 | #13022 | Link |
That was a false alarm, guys The 540M is quite OK for everything except that 1080p60 results in 1 or 2 dropped frames over the course of a 3 minute clip. [ CUVID + EVR is fully OK, no dropped frames ]
The issue was that I was trying out in full screen exclusive mode. After I reverted to full screen windowed mode, things started looking up and I got performance similar to the GT430. Apparently, FS exclusive performing worse than windowed is an issue reported by many NV owners to madshi |
20th April 2012, 11:28 | #13023 | Link | |
madVR is not a product that can be assumed to be working flawlessly "out of the box". Sadly, alot of people don't realize this and rather complain. The default configuration seems to be more appropriate for AMD at this time, but it is certainly possible to get flawless playback on NVIDIA. That said, if windowed mode works flawlessly for you, no reason to use FSE.
20th April 2012, 12:22 | #13024 | Link | |
I do know that my GTS 250 (VP2 IIRC) cannot handle 1080p/60 though.
TV Setup: LG OLED55B7V; Onkyo TX-NR515; ODroid N2+; CoreElec 9.2.7 |
20th April 2012, 15:58 | #13025 | Link | |
20th April 2012, 16:15 | #13026 | Link |
IIRC madshi had to add those tweaks in order to cater to NV drivers or whatever was causing the glitches.
MSI MAG X570 TOMAHAWK WIFI, Ryzen 5900x, RTX 3070, Win 10-64. Pioneer VSX-LX503, LG OLED65C9 |
20th April 2012, 17:48 | #13027 | Link | |
_
But I remember in the past he said D3D resolved several problems and then recommended D3D (exclusive). D3D only improves tearing and smoothness or is it doing something else ? |
20th April 2012, 17:58 | #13028 | Link | |
Also, if you use Aero, there is no tearing.
20th April 2012, 19:07 | #13029 | Link |
its mostly about latency but a stable system with Vista/Win 7 (NT 6) these days should have 0 problems anymore in Windowed mode, though for these small latency increase you get a ton of pros with Aero and in Win 8 latency has been further decreased which was absolute necessary due to ultra fast touch responsiveness needed
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 20th April 2012 at 19:17. |
20th April 2012, 23:32 | #13031 | Link | |
_
For noobs like me, I don't see differences between Overlay Mixer and MadVR. I just follow what guys say is the best. I'm not even sure to see a difference between 24Hz and 60 (3:2 pulldown).
A guy like me does not know if it really works... So I just ask what in theory are other advantages of D3D (except tearing and smoothness). Quote:
On my desktop, I often have laggy scroll on browser, until I move a window. So I'm not sure about Aero VSync quality... |
21st April 2012, 19:46 | #13034 | Link |
Here is a sample TS file that contains a mixture of progressive (1080p/25) and interlaced (1080i/25) video. EVR correctly shows the progressive parts (00:00 - 00:16) as 1080p/25 and deinterlaces the interlaced parts (00:17 - 00:44) to 1080p/50. However, MadVR just treats the whole file as progressive and plays it all at 1080p/25, therefore the interlaced parts show combing.
I'm using LAV Splitter and LAV Video Decoder but since it works fine in EVR I'm assuming it's a MadVR bug!
21st April 2012, 20:35 | #13035 | Link | |
22nd April 2012, 00:11 | #13036 | Link |
Oh OK. All Freeview HD broadcasts in the UK are MBAFF and switch between interlaced and progressive as appropriate, so this would be a useful feature to have!
22nd April 2012, 00:39 | #13037 | Link |
quack quack
In some future version of madVR with definable hotkey control, it should be possible for example to setup the D key to switch deinterlacing on/off.
Or tell LAV Video to YADIF it should work, without having to force it on in the LAV Video options (since it can read aspect ratio from stream, I guess it could handle mixed progressive/interlaced material OK too). |
22nd April 2012, 00:56 | #13038 | Link |
No offence but pressing D to switch mid-video isn't any better than pressing CTRL+ALT+SHIFT+D. If I'm watching something on my TV via an HTPC, I don't want to have to get the keyboard out every time there's an interlaced/progressive switch in the stream. Leaving interlacing on all the time is a better solution but isn't ideal either.
I've tried YADIF via LAV Video before but it has visible problems compared to hardware deinterlacing, unfortunately.
23rd April 2012, 17:49 | #13039 | Link | |
My VP4 based GTX-570 has over 150 GB/s. I guess your low bandwidth rather than "only VP4" might have to do with your problem to play 1080p60.. Last edited by Pat357; 23rd April 2012 at 17:51. |
23rd April 2012, 20:23 | #13040 | Link |
Is there anyone using GTX 680 with madVR and achieving glitch free playback? Just when i get one file playing smoothly, another file on the same settings will get frequent tearing / stutter / drop frames / presentation glitches, especially on 23/24hz mode. When i had the 580 i never had to touch a thing everything just worked
