25th January 2013, 01:15 | #861 | Link | |
Software Developer
LameXP v4.07 Beta-2
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 3rd February 2013 at 17:32. |
25th January 2013, 13:18 | #862 | Link |
Lord_Mulder
I was always wondering why this thread (tool) is not in Audio section? Instead it sits lonely in development section like outcast
25th January 2013, 13:29 | #863 | Link |
Life's clearer in 4K UHD
Agreed...
25th January 2013, 14:37 | #864 | Link |
Software Developer
I think it could fit into both sub-forums. Originally I opened the thread under "Development", because it was a tool that I was developing myself and I didn't want to imply that this is a "finished" product. I would have put it under "Audio", if I had wanted to discuss about some third-party audio tool. But that wasn't the case. I'm not quite sure whether it should be moved to "Audio" nowadays. But I think moving the thread, after all the time, might confuse some people...
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 25th January 2013 at 14:40. |
26th January 2013, 12:56 | #865 | Link |
I would suppose that all the people who are really interested in LameXP will have subscribed to the thread... So moving it over to the audio section would make no difference to them
3rd February 2013, 17:32 | #866 | Link | |
Software Developer
LameXP v4.07 Beta-3
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 9th February 2013 at 20:08. |
9th February 2013, 20:09 | #867 | Link | |
Software Developer
LameXP v4.07 Beta-4
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 12th February 2013 at 22:41. |
12th February 2013, 22:42 | #868 | Link | |
Software Developer
LameXP v4.07 Beta-6
http://sourceforge.net/projects/lame...29/2013-02-12/ Quote:
16th February 2013, 21:34 | #869 | Link |
hi
Any idea about mka support in lamexp? I use http://sourceforge.net/projects/aud-subsplitter and the output is mka, for this I have to get it back to origin aac or mp3, etc... To work with lamexp thx Last edited by real.finder; 16th February 2013 at 21:42. |
16th February 2013, 21:42 | #870 | Link |
Software Developer
The problem is that there can be any type of audio in a Matroska file. And all the decoders used by LameXP to decode the various audio formats do not support Matroska files as input.
We would need to demux the audio stream, e.g. via mkvextract (from MKVtoolnox), before decoding, but that currently doesn't fit into the design of LameXP...
21st February 2013, 00:45 | #871 | Link |
Version 4.07 Beta 6 won't start
I just found out that the latest Beta version refuses to start on my (ancient) machine:
The last line in the console window is "CPU_TYPE_X86_GEN". The program exits with the message: "Unhandled exception handler invoked, application will exit". My machine: CPU Intel Celeron Coppermine 1.1 Ghz, MMX and SSE (no SSE2), 576 MB RAM. WinXP Pro SP3, all current updates. Aside from this, I discovered that the latest version of SOX now (kind of) supports large WAV files in the WAVE_FORMAT_EXTENSIBLE format. This is very useful for me because I now can convert large multichannel AAC files to multichannel AC3 with normalization. The following command sequence works: (source is a large (> 5GB) 6ch WAV file) Code:
sox.exe --ignore-length -t wav test.wav -t wav normalized.wav gain -n -1 aften.exe -readtoeof 1 normalized.wav test.ac3 Cheers manolito |
21st February 2013, 00:56 | #872 | Link | ||
Software Developer
At that point, the application does nothing, but extract the binaries. It does not run any of them yet. And even if we assume that it extracts a "wrong" (unsupported) binary and eventually runs it, only the new process would crash - not the LameXP process itself. So it must be something in the extraction/initialization code... I also tried to reproduce the behavior the behavior with: LameXP.exe --force-cpu-no-sse --force-cpu-no-64bit But works okay for me: Code:
LameXP - Audio Encoder Front-End v4.07 Beta-6 (Build #1246) Copyright (c) 2004-2013 LoRd_MuldeR <mulder2@gmx.de>. Some rights reserved. Built on 2013-02-12 at 20:43:58 with MSVC 2012-U1 for Win-x86. [...] CPU flags overwritten by user-defined parameters. Take care! CPU vendor id : GenuineIntel (Intel: 1) CPU brand string : Intel(R) Core(TM)2 Quad CPU @ 2.40GHz CPU signature : Family: 6, Model: 15, Stepping: 7 CPU capabilities : MMX: 1, SSE: 0, SSE2: 0, SSE3: 0, SSSE3: 0, x64: 0 Number of CPU's : 4 [...] Thread is doing something important... Done Selected CPU is: CPU_TYPE_X86_GEN Extracting file: aften.i386.exe -> aften.exe Extracting file: gpgv.exe -> gpgv.exe Extracting file: elevator.exe -> elevator.exe Extracting file: dcaenc.exe -> dcaenc.exe Extracting file: avs2wav.exe -> avs2wav.exe Extracting file: flac.exe -> flac.exe Extracting file: gpgv.gpg -> gpgv.gpg Extracting file: faad.exe -> faad.exe Extracting file: lame.i386.exe -> lame.exe Extracting file: mac.exe -> mac.exe Extracting file: mediainfo.i386.exe -> mediainfo.exe Extracting file: mpcdec.exe -> mpcdec.exe Extracting file: mpg123.exe -> mpg123.exe Extracting file: oggdec.exe -> oggdec.exe Extracting file: oggenc2.i386.exe -> oggenc2.exe Extracting file: opusdec.exe -> opusdec.exe Extracting file: opusenc.exe -> opusenc.exe Extracting file: refalac.exe -> refalac.exe Extracting file: shorten.exe -> shorten.exe Extracting file: sox.exe -> sox.exe Extracting file: speexdec.exe -> speexdec.exe Extracting file: tta.exe -> tta.exe Extracting file: valdec.exe -> valdec.exe Extracting file: wget.exe -> wget.exe Extracting file: wma2wav.exe -> wma2wav.exe Extracting file: wupdate.exe -> wupdate.exe Extracting file: wvunpack.exe -> wvunpack.exe All extracted. http://sourceforge.net/projects/lame...%20%28BETA%29/ Quote:
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 21st February 2013 at 00:58. |
21st February 2013, 02:06 | #873 | Link | ||
OK, just tested almost evey 4.07 version starting with Alpha 4. No success, the last working version is 4.06 final. Every version after this shows the same behavior...
Cheers manolito |
21st February 2013, 02:40 | #874 | Link | |||
Software Developer
Version 4.06 Final is build #1170. The next build I uploaded is #1197 (2012-11-24): http://sourceforge.net/projects/lame...7.exe/download Does that one already fail ??? Quote:
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 21st February 2013 at 03:08. |
21st February 2013, 03:07 | #875 | Link | ||
"Not a debug build. Please unload debugger and try again" Needless to say that there is no debugger running on my machine. Quote:
I'd much rather do without progress reporting than with the current behavior which is simply annoying. When I try to convert such a file LameXP just does its thing for a long time (these are large files) without any warnings. It reports that it has successfully converted the file, but when I check the output I see that the file is truncated. This is unacceptable. Cheers manolito |
21st February 2013, 03:23 | #876 | Link | ||
Software Developer
So do you only get that issue with that specific build? Is it reproducible? And only your "old" machine or on other machines too? Also: With which build that issue is gone and you start getting the crash you described earlier? (BTW: I could also send you a DEBUG build of the latest version, so you might be able to figure out where exactly it crashes...) [EDIT] The code that would complain about a debugger has not changed at all since 2012-03-26 [/EDIT] Quote:
I'm not totally against adding hacks to process such broken files more "gracefully", but only as long as it doesn't cause any bad side effects. As explained before, always ignoring the length, not only brakes progress reporting (probably), but also could cause other valid files to decode garbage. So it's not really a good idea. (Best heuristic I could think of in a few minutes is passing "--ignore-length" only for files whose size exceeds 4 GB)
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 21st February 2013 at 03:33. |
21st February 2013, 21:45 | #877 | Link | ||
OK, those are the results of some heavy testing... I tried the latest Beta on my Netbook Medion Akoya E1210 (the famous Aldi Netbook), and there were no problems whatsoever. The Atom CPU supports all SSE versions, memory had been upgraded to 2 GB. On my desktop computer (Celeron Coppermine, only MMX and SSE, 576 MB RAM) all attempts to run the 4.07 versions of LameXP failed. I uninstalled all resident AntiVirus software and made sure that no A/V service was still running. I made the software run with 256 colors, I tried to run it in safe mode, nothing helped. Version Alpha 4 from 2012-11-24 always gave me the debug build error, and all later versions up to Beta 6 issued the "Unhandled exception handler invoked..." message. And this behavior is reproduceable each and every time. My conclusion is that XP support in Visual Studio 2012 Update-1 is limited. It's probably not worth your time to debug this. Quote:
Cheers manolito |
21st February 2013, 22:24 | #878 | Link | |||
Software Developer
(The default has changed to "/arch:SSE2" in Visual Studio 2012, as has been the case with ICL for a long time)
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 21st February 2013 at 22:27. |
24th February 2013, 02:49 | #879 | Link | |
Software Developer
LameXP v4.07 Beta-7
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 5th March 2013 at 22:45. |
5th March 2013, 22:48 | #880 | Link | |
Software Developer
LameXP v4.07 Beta-9
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 17th March 2013 at 19:03. |
aac, aotuv, flac, lame, lamexp, mp3, mp4, ogg, oggenc, opus, vorbis |
