25th February 2010, 12:08 | #7001 | Link | |
Panasonic BD35 SAP playback broken with v0.32.03 (beta) – update
Now rolled forward to v0.31.08 (beta).... and playback is still working again on the BD35 SAP and so x264 r1400 is working OK. So the issue seems to be from v0.32.01 (beta) and after and so either the x264 version r1442 or the added code to append ExtensionData() information to AVCHD output (BD-5/9) movie-only encodes is the issue... |
25th February 2010, 14:22 | #7002 | Link | |
Panasonic BD35 SAP playback broken with v0.32.03 (beta) – more update
Next test was to see if it’s the new code or x264. I used again v0.32.03 (beta) and not using the optional switch of “FIX_MOVIEONLY=0” i.e. the new code is used. I then replaced the x264 r1442 from v0.32.03 (beta) with the x264 r1400 from v0.31.08. Interestingly I noticed the file size of r1442 was very big at 6.8MB compared to the 1.1MB (typical x264 file size) of r1400. So I ran the same project with the hybrid version of v0.32.03 (beta) and success.. playback is still working again on the BD35 SAP. So the issue seems to be from the x264 version r1442 and not your added code to append ExtensionData() information to AVCHD output (BD-5/9) movie-only encodes... I will make 1 final test just to double check all my findings and run with v0.32.03 (beta) with the original x264 r1442 just to be sure... |
25th February 2010, 15:08 | #7003 | Link | |
Good analysis and reporting. Much appreciated. As an additional test do you think you could try this build of x264 and see how well it does? It's the latest (r1462) with the nal-hrd patch. Last edited by jdobbs; 25th February 2010 at 15:15. |
25th February 2010, 15:46 | #7004 | Link | |
[14:33:43] BD Rebuilder v0.32.03 (beta) - Source: xxxxxx - Input BD size: 29.59 GB - Approximate total content: [01:42:46.201] - Target BD size: 4.39 GB - Windows Version: 6.1 [7600] - MOVIE-ONLY mode enabled - RESIZE 1080p to 720p enabled - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=448 [14:33:43] PHASE ONE, Encoding - [14:33:43] Extracting A/V streams [VID_00262] - [14:40:14] Reencoding: VID_00262 (1 of 1) - [14:40:14] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 147,841 frames - Convert: 1280x720, 23.976fps, 147,841 frames - [14:40:14] Performing CRF Prediction... - Analyzing 22.17 - [14:40:14] PredictAndEncode() 00053 2810 [14:41:21] - Aborted by user request Also both r1462 and r 1442 = 6.8MB file size, why so big?? r1400 and below are all only around 1.1MB.... |
25th February 2010, 16:48 | #7005 | Link | |
Since I don't have a player that has issues, I'd appreciate it if you could try one more thing. Download this version of x264. It is directly from the x264 site and doesn't include patches. In order to make it work you need to add USE_NAL_HRD=0 to the options area of the BD-RB INI file. Please make sure you are placing the file in the right place and renaming it to x264.exe... the error 53/2810 means it "can't find specified file" -- which could mean the source or the exe in the command line. Last edited by jdobbs; 25th February 2010 at 17:01. |
25th February 2010, 17:24 | #7006 | Link | |
X264.exe is defiantly in the correct location, I copy and paste over the top of the old file to make sure both file name and location are the same. I have repeated two times now a run with the patched r1462 and in-between installed the working r1400 just to make sure to check encoding starts ok. Both times now the patched r1462 crashes at encode start for error 53/2810. I am now running the non patched r1462 + the optional switch of USE_NAL_HRD=0 and encoding is now running OK. I Will report back once the encode is finished as to the BD35’s ability to play the DVD or not. FYI - I have now repeated two times (so as to double check) the following scenarios and both come out with the same results: - V0.32.03 (beta) + x264 r1400 = OK BD35 SAP playability - V0.32.03 (beta) + x264 r1442 = NO BD35 SAP playability (plays ok in pc based powerDVD 9) Last edited by Discoboy; 25th February 2010 at 17:43. |
25th February 2010, 17:39 | #7007 | Link | |
I still don't understand why it would get the 53/2810 error, though. If the newer version you are running now works, I will post an update that will use the new patched version. Last edited by jdobbs; 25th February 2010 at 17:58. |
25th February 2010, 18:49 | #7010 | Link | |
- V0.32.03 (beta) + x264 non-patched r1462 + “USE_NAL_HRD=0” = OK BD35 SAP playability |
25th February 2010, 19:09 | #7011 | Link |
I have the following "problem" with 0.32.03:
done two conversion with it so far - FULL movie BD25 works fine - MOVIE only BD9 plays fine with software players but playing the material burned (for testing purposes) to a BD-RE i am NOT able to fast forward/backward or jump to any chapter the picture freezes, sound goes on used 31.06 afterwards and the same movie plays fine again |
25th February 2010, 19:59 | #7012 | Link |
@Discoboy
I've modified the exe to add the additional parameter to nal-hrd. Please download from this link and try running it without the USE_NAL_HRD=0 parameter. Hopefully that means that X264 r1462 fixed whatever was causing the issue -- if not, then I know it has something to do with the NAL-HRD patched version. Thanks. @DK Please try this version also. Last edited by jdobbs; 25th February 2010 at 20:02. |
25th February 2010, 20:07 | #7013 | Link | |
funny how the rip plays fine Last edited by datman; 25th February 2010 at 20:10. |
25th February 2010, 20:49 | #7016 | Link | |
- V0.32.04 (beta) = NO BD35 SAP playability (plays ok in pc based powerDVD 9) Last edited by Discoboy; 25th February 2010 at 22:03. |
25th February 2010, 23:01 | #7017 | Link |
I'm sure I changed something but not sure why this is happening. When I convert movie only it no longer puts the certificate folder in the new folder it creates. I took a chance not knowing if it would work but it did and I copied the original certificate to the new folder and burned it and it worked fine. Any idea why it stopped doing it on its own?
25th February 2010, 23:03 | #7018 | Link |
i have downloaded the newst bd rebuilder and wanted to try an dvd 9 fullmovie Backup... everything works fine... 1.pass run and passed well. 2.pass x264.exe starts and dont encode..it freeze i've rerun this project 4x times and everytime the same shit. But As i switched to bd25 backup everything works fine, and both passes completed sucessfull and now rebuilding is in progress. very strange. |
26th February 2010, 00:01 | #7019 | Link | |
Damn. I'm going to take the NAL-HRD requirement out. The fact is that TSMUXER will add it, but I wanted to use the patch because the way it does it is more compliant. It sure doesn't seem to be true with the latest versions though. I'm pulling the plug on X264's NAL-HRD for a now. |
