14th August 2013, 13:19 | #17783 | Link |
Senior Member
Demuxing and analyzing the audio of the BD-RB output files can help determine what the problem is.
If you find the audio is fully intact after demux, it might indicate a problem with your plackback device. If you find the demuxed audio stream is partial and abruptly stops, or the audio appears full according to the timecodes, but has actual silence at the end, it might indicate a problem with your source or perhaps there was some error during the encoding or muxing process. |
14th August 2013, 14:09 | #17784 | Link | |
14th August 2013, 18:30 | #17785 | Link | |
Yes sir, I do believe that definitely is what contributed to what happened. Thank you again for your help and also for the most EXCELLENT program! Sincerely... Last edited by Lathe; 15th August 2013 at 03:28. Reason: Change subscription... |
14th August 2013, 20:28 | #17786 | Link | |
15th August 2013, 01:39 | #17787 | Link | |
15th August 2013, 20:20 | #17788 | Link |
Need to understand....
What is this log trying to tell me? I have downloaded the most current version of BD Rebuilder and Anydvd. I have ripped 3 different BDs and had the same problem. Can't understand what has changed since last week when all worked just fine.
---------------------- [08/15/13] BD Rebuilder v0.44.15 (beta) [14:55:01] Source: 24S7D4 - Input BD size: 42.99 GB - Approximate total content: [02:59:13.325] - Target BD size: 22.95 GB - Windows Version: 6.1 [7601] - Auto Quality: Good (Very Fast), ABR - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [14:55:01] PHASE ONE, Encoding - [14:55:02] Processing: VID_00361 (1 of 4) - [14:55:02] Extracting A/V streams [VID_00361] - [15:01:47] Reencoding video [VID_00361] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 63,361 frames - Bitrate: 12,631 Kbs - [15:01:47] Reencoding: VID_00361, Pass 1 of 1 - Encode failed. Aborting. - BD-Rebuilder v0.44.15 (beta) - Windows Version: 6.1 [7601] - AVISYNTH Version: 2.5.8.0, Ok - HAALI Splitter: 1.11.96.14, Ok - FFDSHOW: 3882, Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libmpeg2": Ok - FFDSHOW AVC set to "ffmpeg-mt": Ok - AnyDVD Remove Annoying Adverts: Incompatible - X264: Ok - AFTEN: Ok - FAAC: Ok - WAVI: Ok - TSMUXER: Ok [15:01:47] - Failed video encode, aborted Thanks in advance for any assistance. |
15th August 2013, 20:52 | #17790 | Link |
That, and, or, exit AnyDVD (HD) before using BD-Rebuilder since you may use it to remove those. I'd change that option since it could be viewed as Pre-Processing.
15th August 2013, 21:40 | #17791 | Link | |
Aging Video Hobbyist
Anyway my suggestion (question I guess): Is there any way, once your proggie has brilliantly enabled the disc to go straight to the Menu by blanking all the preliminary junk, to now get it to bypass even the Menu, and start playing the movie? I suspect not; I look at the disc structure with BDedit and can't make head or tail out of it... |
16th August 2013, 02:15 | #17792 | Link |
If your intent is to just play the movie only, which I assume is not what you mean, then just a movie only backup.
However, if your intent is to have the disc start with playing the movie, and upon completion go to the main menu, then I can see where this could be an interesting option! |
16th August 2013, 14:48 | #17793 | Link | |
Anyway to not get too far afield from this thread--NO BUGS THAT I CAN FIND in BD-RB's editing features! I say "ship it", but I suspect jdobbs has in mind to set a Guinness World Record for software being in Beta--it will be 5 years in Dec I think! Last edited by laserfan; 16th August 2013 at 14:51. |
16th August 2013, 15:45 | #17794 | Link | |
16th August 2013, 16:10 | #17795 | Link |
BD Rebuilder v0.44.16 (beta)
I have updated the first post of this thread with a link to the latest version of BD-RB (v0.44.16). Changes for this release:
- Corrected an issue in which MKV files that have audio offsets were not being adjusted properly during import. - Fixed a problem in MKV generation on sources with a fairly large number of parts that could result in a "Failed to REBUILD" error. - Corrected an error in which rebuild of MPEG-2 sources could, under certain circumstances, create an audio desynchronization. - Added the ability to import multiple DVDs into a single quick-play structure. In order to do this you must put all the desired DVDs into a single folder -- and then select that folder under the IMPORT function. The name of the folder should describe the DVD set and will be used in the quick-play pseudo menu. - Updated the method used for conversion of XVID sources. Prior releases could lose frames and result in audio desync when importing XVID. - Added code to the IMPORT algorithm that finds illegal audio sample rates, and force encoding to the required 48Khz for BD/DVD. - Fixed an error in which performing encodes with iVTC set, followed by an exit and a follow-on rebuild could result in incorrect framerates and sync issues. - Fixed an issue in which variable framerates in a source to be imported may result in incorrect framerate determination during IMPORT. - Upgraded the tools MKVMERGE and MKVEXTRACT to a newer release (v2.3.0) - Other minor corrections and cosmetic fixes. |
16th August 2013, 18:34 | #17797 | Link |
Hi jdobbs thank you for the updated release, I just noticed this option,
- Added the ability to import multiple DVDs into a single quick-play structure. In order to do this you must put all the desired DVDs into a single folder -- and then select that folder under the IMPORT function. The name of the folder should describe the DVD set and will be used in the quick-play pseudo menu. does this mean we can take a DVD series for example Feast 1-3 and put all 3 video_ts folders in the same folder as mentioned, name it Feast Trilogy and BD-RB will make a menu to choose which title you want? what will it say DVD 1 and so on or the actual title? also do you have a sample image of what the menu would look like? and could we replace it with our own background image? or am I just way off base here lol. Thanks for your time jdobbs and for the great software as usual, this is great stuff and it only keeps getting better! |
16th August 2013, 19:03 | #17798 | Link | |
Here's an example: D:\SOURCE\STAR_WARS D:\SOURCE\STAR_WARS\EPISODE_IV-A_NEW_HOPE D:\SOURCE\STAR_WARS\EPISODE_V-THE_EMPIRE_STRIKES_BACK D:\SOURCE\STAR_WARS\EPISODE_VI-RETURN OF THE JEDI Each of the individual movie subdirectories contain the VIDEO_TS of a DVD structure. By selecting D:\SOURCE\STAR_WARS you could instruct BD-RB to import all three movies into a single BD structure. You could then reencode to BD-R. You could also do this with episodic DVDs, and each title will be included. My intent in the future is to create an actual menu so that large numbers of episodes can be added and be easily selected out-of-order as well. In fact, I'm currently importing several old TV series now, and when I finish the "true" menu option I can just re-import them to create it. Last edited by jdobbs; 16th August 2013 at 19:32. |
16th August 2013, 20:27 | #17799 | Link | |
