27th November 2019, 13:40 | #57882 | Link |
I think you use an ATI card, Klaus
But it would be great if someone who uses this szenario or has the knowledge about madVR internals could answer my one and only question: "is madVR able to switch automatically between 8 and 12 bpc when neccessary on a custom video mode with a nVidia graphic card?" huhn and me both "think" that it "should". When I find the time, I will also upgrade to the latest nVidia driver. Maybe it will work then. I will let you know. |
27th November 2019, 13:41 | #57883 | Link | |
custom resolution and 12 bit are not good friends and it is pretty much not worse the hassle anyway. |
27th November 2019, 17:41 | #57885 | Link | |
But I think it might have to do with the fact that I'm using a 4K e-shift projector which I use at 1080p60hz by default, and then switch to 4k24hz 12bpc when watching videos in madVR. Before, I had been switching from 4k60hz 8bpc, and with this setup I was not able to get NVidia to switch to 12bpc. My workaround might not be useful to those that need to run more than 1080p outside of madVR but I thought it was worth mentioning for anyone that this would work for. Also, I have found that enabling 12bpc color is worth it and visibly better than 8bpc when using madVR debanding on animated content that has banding. If not using debanding I'm not sure there would be a noticeable difference on most SDR content. Last edited by thewildsun; 27th November 2019 at 20:00. |
28th November 2019, 08:53 | #57887 | Link |
Of course. Should have posted initially. Thought it might be a common problem. Note the screenshot is using my monitor but the same thing happens on my C9. Also, the OSD states RGB 8-bit full but I get the same results when using correct output for HDR files.
https://imgur.com/a/HpzcK4E Last edited by YukonTrooper; 28th November 2019 at 10:05. |
28th November 2019, 10:56 | #57890 | Link |
May I ask the reasons why "Full Screen Exclusive" may not activate successfully? How do we address it as well?
28th November 2019, 12:17 | #57893 | Link |
In continuation of the topic of non-working AMD HDR private API (AGS)
Which leads to an unsaturated color in the "AMD HDR" mode with Vega iGPU.
Screenshot.
R3 3200G / Vega8 / Samsung UE40NU7100 Win11Pro 21H2 / 4K RGB 59Hz / AMD last driver MPC-HC 1.9.17 / madVR 0.92.17 / FSW / SM / 8bit |
28th November 2019, 12:46 | #57894 | Link |
It simply goes to full screen window mode in dsplayer. In MPC BE, the app stalls and sometimes blank screen
Asus ProArt Z790 - 13th Gen Intel i9 - RTX 3080 - DDR5 64GB Predator - LG OLED C9 - Yamaha A3030 - Windows 11 x64 - PotPlayerr - Lav - MadVR Last edited by Magik Mark; 28th November 2019 at 13:16. |
28th November 2019, 13:11 | #57895 | Link |
@YukonTrooper: even though the pixel count of your video gives an aspect ratio of 2.39:1, the aspect ratio is reported to madVR as 1.78:1 by whatever is playing/decoding it (line "movie 3840x1608, 16:9") so madVR stretches it to that aspect ratio as instructed.
This is probably a metadata mistake in the source. If this is a MKV, try to open it with MKVToolNix or some other tool and change/remove the 16:9 aspect ratio tag. Edit: often this happens because a MKV has both 'aspect ratio' and 'original aspect ratio' tags, the second one indicating what it was before cropping i.e. 16:9 if the source was a Blu-ray with black bars, and the decoder passing the original aspect ratio to madVR instead of the actual one.
HTPC: Windows 10 22H2, MediaPortal 1, LAV Filters/ReClock/madVR. DVB-C TV, Panasonic GT60, Denon 2310, Core 2 Duo E7400 oc'd, GeForce 1050 Ti 536.40 Last edited by el Filou; 28th November 2019 at 13:14. |
28th November 2019, 14:12 | #57896 | Link |
Hi, anyone else running a AMD RX 5700* in a ageing PCI express 2.0, assuming the PCIe 4.0 will work in the slot I might be getting my hands on one soon, just wondering if anyone has any issues with MADVR in this area, or whether anyone thinks I might see any problems with 2.0/4.0 compatability and MADVR.
28th November 2019, 14:21 | #57897 | Link | |
Also AMD is providing an uninstaller which restarts pc in safe mode uninstall all stuff then you can install the new driver completely fresh. Link is in the first post here: https://forum.doom9.org/showthread.php?t=176013 |
28th November 2019, 14:31 | #57899 | Link | |
LG OLED55BX6LB, Zidoo Z1000 Pro, Yamaha RX-A3060, Polk Signature Fronts & Centre, Wharfedale D300 Atmos surrounds, Polk Signature HTS 10 Sub, DSPeaker Antimode 8033 Cinema |
28th November 2019, 14:36 | #57900 | Link | |
I've done that ever since. Same problem Sent from my iPhone using Tapatalk
