Old 9th April 2018, 02:24   #5241  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Try this - https://yadi.sk/d/BmlIoT0_3UDvos
It's create log file if drop and so. Testing without seeking - just open & playback some times.
Old 9th April 2018, 04:28   #5242  |  Link
tyrindor
Getting drops on Dolby Digital 5.1 bitsreaming too, not just lossless it seems.
2018.04.08 21:52:55.392 : CMpcAudioRenderer::RenderWasapiBuffer() - Pad silence 25.00 ms(250000) [4800/19200 (frames/bytes)] for clock matching at 52460000/52710000
2018.04.08 21:52:55.392 : CMpcAudioRenderer::RenderWasapiBuffer() - Pad silence 24.00 ms(240000) [4608/18432 (frames/bytes)] for clock matching at 52470000/52710000
2018.04.08 21:52:55.393 : CMpcAudioRenderer::RenderWasapiBuffer() - Pad silence 24.00 ms(240000) [4608/768 (frames/bytes)] for clock matching at 52470000/52710000
2018.04.08 21:52:55.442 : CMpcAudioRenderer::RenderWasapiBuffer() - Discontinuity detected by 32.00 ms
2018.04.08 21:52:55.442 : CMpcAudioRenderer::RenderWasapiBuffer() - Correct reference clock by 32.00 ms
2018.04.08 21:52:55.492 : CMpcAudioRenderer::RenderWasapiBuffer() - Drop packet, size = 9216, dueTime = 53210000, refclock = 53780000(diff = 570000), sampleOffset = 15360
2018.04.08 21:58:29.911 : CMpcAudioRenderer::RenderWasapiBuffer() - Discontinuity detected by 32.00 ms
2018.04.08 21:58:29.911 : CMpcAudioRenderer::RenderWasapiBuffer() - Correct reference clock by 32.00 ms
2018.04.08 21:58:29.961 : CMpcAudioRenderer::RenderWasapiBuffer() - Drop packet, size = 16896, dueTime = 83830000, refclock = 84580000(diff = 750000), sampleOffset = 7680
2018.04.08 21:58:29.961 : CMpcAudioRenderer::RenderWasapiBuffer() - Drop packet, size = 24576, dueTime = 84050000, refclock = 84580000(diff = 530000), sampleOffset = 0
2018.04.08 22:04:46.634 : CMpcAudioRenderer::RenderWasapiBuffer() - Drop packet, size = 13824, dueTime = 3423500000, refclock = 3424010000(diff = 510000), sampleOffset = 10752
2018.04.08 22:09:41.102 : CMpcAudioRenderer::RenderWasapiBuffer() - Drop packet, size = 10752, dueTime = 6368180000, refclock = 6368690000(diff = 510000), sampleOffset = 13824
2018.04.08 22:13:29.916 : CMpcAudioRenderer::RenderWasapiBuffer() - Drop packet, size = 24576, dueTime = 8656320000, refclock = 8656830000(diff = 510000), sampleOffset = 0
2018.04.08 22:22:13.448 : CMpcAudioRenderer::RenderWasapiBuffer() - Drop packet, size = 15360, dueTime = 13891640000, refclock = 13892150000(diff = 510000), sampleOffset = 9216
tyrindor is offline   Reply With Quote
Old 9th April 2018, 05:51   #5243  |  Link
Aleksoid1978
Very strange. I try check at home(on my A/V reciver) when will be free time.
Old 9th April 2018, 13:54   #5244  |  Link
Aleksoid1978
tyrindor - new test build https://yadi.sk/d/T4RFgrPV3UEyrx
Test on AC3/TrueHD/DTS-HD. For me only drop on AC3/DTS-HD in 5-10m. The problem has not yet been clarified.
Old 9th April 2018, 14:38   #5245  |  Link
tyrindor
Weird no one else has reported this. I'll report back when I get a chance.
Old 9th April 2018, 14:55   #5246  |  Link
tyrindor
TrueHD
2018.04.09 08:48:57.079 : CMpcAudioRenderer::RenderWasapiBuffer() - Drop packet, size = 61440, dueTime = 2296190000, refclock = 2296700000(diff = 510000)
2018.04.09 08:54:24.399 : CMpcAudioRenderer::RenderWasapiBuffer() - Drop packet, size = 61440, dueTime = 5569390000, refclock = 5569900000(diff = 510000)
2018.04.09 08:54:48.901 : CMpcAudioRenderer::RenderWasapiBuffer() - Discontinuity detected by 20.00 ms
2018.04.09 08:54:48.901 : CMpcAudioRenderer::RenderWasapiBuffer() - Correct reference clock by 20.00 ms
2018.04.09 08:54:48.951 : CMpcAudioRenderer::RenderWasapiBuffer() - Drop packet, size = 61440, dueTime = 5667590000, refclock = 5668170000(diff = 580000)
Old 10th April 2018, 02:46   #5247  |  Link
Aleksoid1978
Try this build - https://yadi.sk/d/Qx-8lW1A3UGHT2
Old 10th April 2018, 15:02   #5248  |  Link
tyrindor
So far so good. One hour of TrueHD and one hour of Dolby Digital Plus with no drops.
If I could get a 64bit compile of that build it'd be appreciated and I can test further.
Old 10th April 2018, 15:03   #5249  |  Link
Aleksoid1978
What's about A/V sync - it's good ?? No desync ??
Old 10th April 2018, 15:09   #5250  |  Link
tyrindor
I thought I noticed some slight A/V issues at the end of a dolby digital plus episode, but it may have been the rip. I will have to test further for A/V issues.
This is the log after playing both files:
2018.04.10 07:16:43.716 : CMpcAudioRenderer::RenderWasapiBuffer() - Pad silence 9.00 ms(90000) [1728/6912 (frames/bytes)] for clock matching at 0/90000
2018.04.10 07:16:43.717 : CMpcAudioRenderer::RenderWasapiBuffer() - Pad silence 9.00 ms(90000) [1728/6912 (frames/bytes)] for clock matching at 0/90000
2018.04.10 07:16:43.717 : CMpcAudioRenderer::RenderWasapiBuffer() - Pad silence 8.00 ms(80000) [1536/6144 (frames/bytes)] for clock matching at 10000/90000
2018.04.10 07:16:43.719 : CMpcAudioRenderer::RenderWasapiBuffer() - Pad silence 6.00 ms(60000) [1152/4608 (frames/bytes)] for clock matching at 30000/90000
2018.04.10 07:16:43.720 : CMpcAudioRenderer::RenderWasapiBuffer() - Pad silence 6.00 ms(60000) [1152/1536 (frames/bytes)] for clock matching at 30000/90000
2018.04.10 08:30:42.285 : CMpcAudioRenderer::RenderWasapiBuffer() - Pad silence 1.00 ms(10000) [192/3072 (frames/bytes)] for clock matching at 0/10000
2018.04.10 08:30:42.286 : CMpcAudioRenderer::RenderWasapiBuffer() - Pad silence 1.00 ms(10000) [192/3072 (frames/bytes)] for clock matching at 0/10000
2018.04.10 08:30:42.286 : CMpcAudioRenderer::RenderWasapiBuffer() - Discontinuity detected by -1.00 ms
2018.04.10 08:30:42.287 : CMpcAudioRenderer::RenderWasapiBuffer() - Correct reference clock by -1.00 ms
2018.04.10 08:30:52.485 : CMpcAudioRenderer::RenderWasapiBuffer() - Discontinuity detected by 70.00 ms
2018.04.10 08:30:52.485 : CMpcAudioRenderer::RenderWasapiBuffer() - Correct reference clock by 70.00 ms
2018.04.10 08:30:55.136 : CMpcAudioRenderer::RenderWasapiBuffer() - Discontinuity detected by 97.00 ms
2018.04.10 08:30:55.136 : CMpcAudioRenderer::RenderWasapiBuffer() - Correct reference clock by 97.00 ms
2018.04.10 08:59:44.125 : CMpcAudioRenderer::RenderWasapiBuffer() - Discontinuity detected by -1.00 ms
2018.04.10 08:59:44.126 : CMpcAudioRenderer::RenderWasapiBuffer() - Correct reference clock by -1.00 ms
2018.04.10 09:02:26.001 : CMpcAudioRenderer::RenderWasapiBuffer() - Pad silence 1.00 ms(10000) [192/3072 (frames/bytes)] for clock matching at 0/10000
2018.04.10 09:02:26.002 : CMpcAudioRenderer::RenderWasapiBuffer() - Pad silence 1.00 ms(10000) [192/3072 (frames/bytes)] for clock matching at 0/10000
2018.04.10 09:02:26.003 : CMpcAudioRenderer::RenderWasapiBuffer() - Pad silence 1.00 ms(10000) [192/3072 (frames/bytes)] for clock matching at 0/10000
2018.04.10 09:02:26.004 : CMpcAudioRenderer::RenderWasapiBuffer() - Pad silence 1.00 ms(10000) [192/3072 (frames/bytes)] for clock matching at 0/10000
2018.04.10 09:02:26.005 : CMpcAudioRenderer::RenderWasapiBuffer() - Pad silence 1.00 ms(10000) [192/3072 (frames/bytes)] for clock matching at 0/10000
2018.04.10 09:02:26.005 : CMpcAudioRenderer::RenderWasapiBuffer() - Discontinuity detected by -1.00 ms
2018.04.10 09:02:26.006 : CMpcAudioRenderer::RenderWasapiBuffer() - Correct reference clock by -1.00 ms
Old 10th April 2018, 19:52   #5251  |  Link
tyrindor
More testing, seeing some A/V issues sadly. Seems to get worse the longer something is played. Last thing I watched it started out fine, but about an hour in it was noticeably off.
Kinda starting to wonder if it's worth the headache, directsound bitstreaming works if I select my receiver instead.
Old 12th April 2018, 01:31   #5252  |  Link
yonta
Please add support for opus audio in mp4.
Internal mp4 splitter supports vp9 and ogg in mp4 but not opus audio.
yonta is offline   Reply With Quote
Old 12th April 2018, 03:22   #5253  |  Link
Aleksoid1978
Done.
Old 12th April 2018, 04:07   #5254  |  Link
yonta
Wow! That's fast, thank you.
Old 12th April 2018, 14:50   #5255  |  Link
Aleksoid1978
tyrindor
Try this build - https://yadi.sk/d/CnPLkVxg3UMWj5
it's don't create log file. Just check for drops and A/V sync.
Old 12th April 2018, 20:08   #5256  |  Link
tyrindor
tyrindor
I'll test for a few days and get back to you, perhaps earlier if I see any issues.
Old 13th April 2018, 05:15   #5257  |  Link
Arm3nian
Is there anyway to get smooth seeking? Without delays/buffering/lag. For example, like in premiere pro. I've tried the fastest algorithms in madvr and sw/hw decoding but it's never perfect.
Arm3nian is offline   Reply With Quote
Old 13th April 2018, 06:31   #5258  |  Link
Aleksoid1978
It's not possible.
Old 13th April 2018, 18:06   #5259  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
Premiere does it by reading the entire file start to finish and recording the seek points of each frame. That can take minutes before you can even start watching the movie, no one wants to put up with that just to get slightly faster seeking during a movie.
Old 13th April 2018, 21:29   #5260  |  Link
amayra
Quality Checker
amayra's Avatar
i think is about time to give assfiltermod another chance as experimental for advance user
I love Doom9
